Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 05-20-2008, 09:27 AM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Receiver maintenance, you may want to check.
Greetings.
After a few years of road salt and wetness in the midwest, I decided to sand and scrape some of the rust that was developing on my receiver.
To my shock and I suppose good fortune, I checked the bolts that hold the receiver together. I have a Dalan. About three of the nut/bolts attaching the the cross bar to the the side brackets were quite loose. I tightened them up right away.
It goes without saying that I will be checking connections on our receiver a few times during the season, along with the bolts that loosen on our Equilizer after each trip with the AS.
I think it was a good idea to to clean, re-prime, and top-coat the receiver, to slow the process of corrosion.
Just some advice.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 05-20-2008, 09:37 AM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Good advice. Checking the bolts on the hitch head is on our regular checklist, but I don't think I've crawled under the van and checked the actual receiver bolts in a couple years.
Stephanie
Old 05-20-2008, 11:49 AM   #3
Kevin245's Avatar
I usa a dab of thread locker on my hitch connection bolts. You're correct about the corrosion.
Old 05-20-2008, 04:35 PM   #4
cammur's Avatar
Roseville , California
Our WBCCI unit as a service once did a check of member tow vehicles at a rally. Everyone was susprised at the number of loose or missing bolts and cracks they encountered.
Even the fabled Hensley isn't immune. Last year in Indepencence I encountered a man returning from Alaska that had a torsion bar break (or whatever you call 'em on Hensleys) and on the same trip a crack in his receiver.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
HD receiver for your non-ATSC TV thecatsandi Audio, Video & TV 8 05-29-2008 12:41 PM
Drop Receiver, Yes or No? RBolton Hitches, Couplers & Balls 6 12-11-2007 08:34 PM
class iv or v receiver? 2airishuman Hitches, Couplers & Balls 11 03-08-2005 07:27 AM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
