Old 03-13-2013, 06:22 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Receiver locks
A lot has been written about coupler locks but what about receiver locks. I am thinking about purchasing a new one. The one I bought last year, Reese Professional series was a bear to take off. The lock froze and I was only able to get it off with the use of graphite and a wrench to lossen it. It was on the receiver for about six months.
I do not want to go through this each time i want to remove the receiver so i was wondering what others recommend.
Thanks.
urnmor is offline   Reply With Quote
Old 03-13-2013, 06:44 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Graphite is good. Gun oil works, too, but use one or the other, not both.
I can't use most receiver locks. My receiver has the seven-pin connector welded on too close to the reciever to use a lock that requires a key inserted in the end, and manipulaing a combination lock in that small space is problematic as well. I have to use one that has the key inserted at right angles to the pin. This one is made by Master, and has a cover for the keyhole to keep out dirt. When I use it, I have to hold the lock in that small space between receiver and seven-pin connector, from underneath, and then insert the hitch pin into the lock.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-13-2013, 07:13 AM   #3
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
I got this. Both are keyed alike with dust covers.
LifeLong Stainless Receiver & Coupler
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 03-13-2013, 02:12 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
If you only remove the hitch seasonally, just use a 5/8" grade 8 bolt and a locknut. It will come off in a few minutes with a socket wrench but is time consuming enough to remove with a Leatherman and a crescent wrench that it will deter theft.
Most receiver locks can be broken off quickly with a large punch or chisel and a 2 pound hammer because they cut the locking ring so deep in the pin that it weakens it. One good hit will do it.
Old 03-13-2013, 03:44 PM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
A spot weld will take care of that. I replaced my rear bumper with a www.southtexasoutfitters.com bumper and had them spot weld it to the frame. The hitch itself is welded to the bumper so no worries there.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 03-13-2013, 03:45 PM   #6
So a lock is no good because it can be knocked off with a hammer and chisel, but a bolt is fine because it's a pain to remove with a Leatherman and crescent wrench?
I would think that if a thief is carrying around a hammer and chisel, he's probably got a whole toolbox— including a socket set— with him, too, so a bolt is no more of a deterrent than a lock in that regard.
WBCCI #1105
TAC LA-4
Old 03-13-2013, 04:26 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
The point was that there's no real reason to use the lock because it doesn't offer better security than a bolt and locknut.
I was also providing some advice for the next time someone can't get the receiver lock off.
Not sure why I bother.
Old 03-13-2013, 04:36 PM   #8
S.E Lower Michigan , Michigan
I use a stainless steel lock by Trimax. Have had it for about 8 years and no problems at all.
Barney
SXT5 Premium 100% Stainless Steel 5/8" Key Receiver Lock 3-1/2" Span
Barneys is offline   Reply With Quote
Old 03-13-2013, 04:48 PM   #9
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I have been happy with the Trimax Receiver Lock model T3. This has the solid 5/8" stainless steel shaft.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 03-13-2013, 04:56 PM   #10
Apologies if my response caused you any heartburn. I didn't take what you said the way you meant it. Guess I'm just too literal-minded; the curse of being an engineer.
WBCCI #1105
TAC LA-4
Where to put satellite receiver xo1rider Audio, Video & TV 23 11-23-2015 06:48 PM
Best receiver: Curt, Drawtite, or Hidden Pacerized Hitches, Couplers & Balls 7 03-21-2011 08:13 PM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
