Old 06-03-2009, 04:33 PM   #1
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
Quick Question
I'm putting in a new cable.
Do I stick it in the MARVEL hole or just let it dangle underneath?
ID:	81475   Click image for larger version
Sheridan is offline   Reply With Quote
Old 06-03-2009, 04:35 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I don't think it matters. It might have less chance of damage if you bring it through the hole. But put something around the edge to protect it from rubbing.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-03-2009, 04:38 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I'd let it dangle. There's less chance of it chafing or being pinched that way.
Roger
Old 06-03-2009, 07:50 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you run it through the hole put in a rubber grommet to prevent chaffing.
Old 06-03-2009, 08:09 PM   #5
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
surely they put the hole in there for a reason. i used black plastic split wiring channel
take care
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Quick probably dumb univolt question! DanB Batteries, Univolts, Converters & Inverters 16 04-14-2009 12:54 PM
quick question 1967 Overlander ren walker Our Community 9 01-09-2007 10:10 AM
Quick boondocking question.... Kestrell Water Heaters, Filters & Pumps 8 07-30-2005 08:20 PM
Quick 12v Question Dave-O Electrical - Systems, Generators, Batteries & Solar 8 03-05-2003 03:37 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 07:21 PM
