Old 04-24-2011, 08:15 PM   #1
Astriking's Avatar
1979 31' Excella 500
San Bernardino , California
Questions on hitch set set up for my Dodge
as I have an AS 79 excella 31 ft center bath and TV dodge ram 03 1500 5.7
hemi magnun quad cabin. I would like to know if I have a good TV for shor trips. I will be posting some pics about the TV and my AS. Another question is
I was trying to setup the WDH last night but I tink I did someting wrog because I felt too much tension when I lifted the saddle already chained.
and the only way I can lift the saddle is just using the last link on the chains.
any advise on these.
ID:	128057   Click image for larger version
ID:	128059   Click image for larger version
Javier
Astriking is offline   Reply With Quote
Old 04-24-2011, 08:23 PM   #2
Looks OK to me, BUT, you should add a tosion type sway control, for increased safety.
Old 04-24-2011, 08:26 PM   #3
Astriking's Avatar
some more pics about my TV and my WDH setup
ID:	128077   Click image for larger version
ID:	128079   Click image for larger version
Javier
Old 04-24-2011, 08:30 PM   #4
The air bags, totally defeat the purpose of your load equalizing hitch.
They should be disabled and the air pressure should be at minimum, when your going to tow the trailer.
What you have has in the past caused 1/3 of all the loss of control accidents specifically towing an airstream. Those are facts from the old insurance division of Airstream.
Old 04-24-2011, 08:33 PM   #5
Astriking's Avatar
MR. Andy if there is a lot tension on the saddle chains, that can affect the AS chassis?
Javier
Old 04-24-2011, 08:35 PM   #6
Astriking's Avatar
actually the airbags are empty
Javier
Old 04-24-2011, 08:37 PM   #7
No. The bars should bend at least one inch or even more.
If not, the the bars are to heavy for the tongue weight that you have.
Old 04-24-2011, 08:38 PM   #8
Astriking's Avatar
MR. Andy there are some whasers and a bolt on the WDH . how I sould do the adjust with these
Javier
Old 04-24-2011, 08:41 PM   #9
Astriking's Avatar
washers between the WDH
ID:	128081   Click image for larger version
Javier
Old 04-24-2011, 08:44 PM   #10
Central , Mississippi
You will get lots of "that looks good" and "don't do that" from a post but the only real way to see what you have is to make some measurements like
http://www.airforums.com/forums/f238...-in-17984.html
Nice lookin rig!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-24-2011, 08:47 PM   #11
Astriking's Avatar
thanks moderator what do think about my TV, enough for my AS and long trips
Javier
Old 04-24-2011, 09:05 PM   #12
Astriking's Avatar
can I use the sway control in tight turns?
Javier
Old 04-25-2011, 03:27 AM   #13
Yes.
Old 04-25-2011, 05:03 AM   #14
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
The last pic of your setup seems to be correct. I think I count about 8 links under tension. IF the trailer is level you should be good. Im not just sure what the weight of those bars are but they may be to heavy. ANDY or someone can tell ya what weight they are by the diameter at the base where the bar goes into the head.IF they are 1200 lb bars thats to heavy for that truck. I use 550 lb bars with my 1 ton and a REESE Dualcam Straightline.
I think they only thing you didnt mention is that YOU WEIGHED IT. YOU need to take the truck to the scales,no trailer. WEIGH the steering and drive seperately and then a gross for the truck FULL of fuel ready to go. THEN take the truck and trailer back to the scales and weigh each axle STEER DRIVE and TRAILER TANDEM and a total Gross and do the math. IT sounds like alot of hassle but you will be rewarded with a GREAT OCEAN WAVE RIDE
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Who makes this hitch? btophek Hitches, Couplers & Balls 2 06-03-2011 05:53 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Hitch height Kman Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
