Old 01-20-2011, 12:53 PM   #1
fmrcaptevil's Avatar
Weldon Spring , Missouri
Question for our hitch experts:
During periods of extended travel (days/weeks), can hitch remain connected (including w/d bars) without causing harm to any component involved?
fmrcaptevil is offline   Reply With Quote
Old 01-20-2011, 01:11 PM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I see no reason why not, as long as everything is hooked up within specs in the first place.
I routinely leave mine hooked up during multi day cross country trips.
At times I slacken the WD bars and use the tongue jack to level for and aft.
Ken
Old 01-20-2011, 01:16 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes.
The bars will not be damaged by remaining flexed.
Over a period of many months or more, regular maintenance, particularly lubrication, would be something to consider.
Old 01-20-2011, 01:17 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I agree. But I disconnect the umbillical. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-20-2011, 01:28 PM   #5
Ag&Au's Avatar
I do also, especially when not hooked up to shore power. I don't want to drain the TV batteries as well as the trailer batteries.
However I am assuming that if the trailer was plugged into shore power and the umbilical was left in, the converter would maintain the charge on the TV battery as well as the trailer battery as long as there was not a battery isolator in the circuit. Is that correct?
Ken
Old 01-20-2011, 01:39 PM   #6
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Most vehicles produced for a good while now have a relay on at least the 12v feed for the 7-way. When you turn off the key, that line is disconnected from the vehicles electrical system. So no battery drain or charging from 7 way connector. To be sure though, check your 7 way with a voltmeter when the key is off.
newroswell is offline   Reply With Quote
Old 01-20-2011, 02:36 PM   #7
Thanks, guys.
Old 01-20-2011, 04:22 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Totally onboard with this. Stress vs strain (stress does not alter the physical characteristics of the spring bars).
Modern vehicles are supposed to have a diode to prevent night-time flow from truck to trailer. But in my memory Foiled Again has woken up to a dead tow vehicle by leaving them hooked up.
Unhook the umbilical at night just to be safe. I do.
5 meter Langford Nahanni
Old 01-20-2011, 06:47 PM   #9
JFScheck's Avatar
Rockville , Maryland
Images: 33
Concur, but I too would disconnect the umbilical so not to drain the auto battery...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-22-2011, 02:15 PM   #10
dznf0g's Avatar
Oswego , Illinois
None that I have ever used. I frequently go to the storage lot, no batteries in the AS, no shore power. I plug in the umbilical so I will have lighting to perform some project. Keys are in my pocket. Charge line to trailer is hot at all times.
Equalizer hitch benefits Moonstruck Hitches, Couplers & Balls 34 01-19-2011 08:03 AM
Hensley Hitch Value L4740 Hitches, Couplers & Balls 5 01-18-2011 08:05 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 07:22 AM
