Old 07-18-2009, 02:58 PM   #1
1969 27' Overlander
Ehrhardt , South Carolina
purpose of the hitch attachment
I have a 1969 27' Overlander that came with a hitch attachment the owner called tortion stablizer I think.
Its heavy and has connections that go from the pivot back about 3 feet on each side. What is this for??
I have towed the trailer several hundred miles now and havent used this attachment.
It seems to tow fine.
Am I missing something here???
oldcar29 is offline   Reply With Quote
Old 07-18-2009, 03:09 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Depending on the weight and length of the trailer and the type of tow vehicle it is a good idea to use a weight distributing hitch. This type of hitch transfers some of the tongue weight to the front axle of the tow vehicle and some to the trailer axles. The reason to do this is to reduce potential swaying of the trailer.
I will not attempt to enplane in detail detail the method of adjusting but rather advise you to do a search on Weight distributing hitch, read through those and then come back with questions. Let me add do not go to a dealer for advise on this adjustment because I have never found a dealer that has any idea of how to set a WDH up correctly.
2004 Excursion 4x4
Old 07-18-2009, 03:10 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We would need to see a picture of the unit to tell for sure. It sounds like weight distribution and/or sway control hitch system of some type.
Yes, you do need this properly installed and set up. The fact that you have towed without it and have had no problems is just luck on your part.
Brian
SuEllyn & Brian McCabe
Old 07-18-2009, 03:19 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings oldcar29!
It sounds like what you are describing may be twin friction sway control devices. While not a common practice, friction sway controls can be used in pairs. They also might be the bracket mounted Reese Dual Cams.
A friction sway control device is pictured below:
The older bracket type Reese Dual Cam Sway Controls are pictured below:
Good luck with the identification of your hitch components.
Kevin
Kevin D. Allen
AIR #827
Purpose of rear rock guard? Maryw164 Rock Guards, Segment & Window Protectors 20 01-20-2011 03:56 PM
What is the purpose toastie Repairing/Replacing Floor &/or Frame 16 11-12-2009 03:26 PM
door purpose? goransons 1963 Safari 2 11-29-2008 09:41 PM
Industrial Utility bed / hitch attachment question team_no Hitches, Couplers & Balls 9 12-08-2007 11:59 AM
