Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-04-2008, 11:02 AM   #1
Profile:  Currently Looking...
Salt Lake City , Utah
Wink Best Hitch to pull a 1970 Ambassador with a 85 Ford F250??
Hi,
We are finalizing the search, hopefully for our trailer. Purchased a 1985 Ford Diesel F250, and are wondering what the best hitch would be to purchase for pulling. I believe the dry weight of the trailer is about 5,000 lbs. The tongue weight is 450 lbs. We are also looking for used hitches..Is this advisable? Any advice on what we need?
Thanks!
LucyP
LucyPepper is offline   Reply With Quote
Old 04-04-2008, 11:24 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
You'll likely find that an Airstream of that period would have some sort of weight distribution gear installed. The bigger question would be whether the seller still has the spring bars and the associated hitch bar/ball to go in your receiver. 450 pound (no options, no personal effects onboard) hitch weight will not be too much for a 3/4 ton truck, so technically weight distribution would not be your most immediate need. But I'd use it anyway, especially if you have a topper and carry extra gear in the box. Rear axles on 3/4 tonners don't have the large capacity of 1 tonners.
Antisway of the period would likely have been a friction type -- serviceable but they tend to need regular adjustment. Again, would the seller have the parts? Antisway is a very important component to look for. Modern setups like Reese DualCam HP or Equal-I-Zer combine both weight distribution and antisway.
Old 04-04-2008, 03:35 PM   #3
SteveH's Avatar
Profile:  1975 23' Safari
San Antonio , Texas
Lucy,
If your trailer does not come with a hitch, you might want to check out Craigslist in your area. I see hitches for sale on there here frequently. They are usually in the RV section. Good luck with the search.
Steve
Old 04-04-2008, 04:22 PM   #4
Profile:  1973 25' Tradewind
Romulus , New York
Good chance the hitch will come with the TT. You gotta ask if they have it. You are talking old school with your TT and TV. I would get a WD hitch from craigslist or ebay. No more than 200 dollars.
jayray5 is offline   Reply With Quote
Old 04-04-2008, 08:16 PM   #5
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
If you do the weights you will probably find a WD is going to be complete overkill for a lightweight trailer and a brute such as a F250. My '77 Ambassador tows great on a ball hitch as long as I don't have a huge load in the bed.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 04-05-2008, 05:16 AM   #6
SteveH's Avatar
San Antonio , Texas
For what it's worth, I disagree. It is my opinion the weight distributing hitch is well worth the investment, even if you were using a 1 ton truck. It's not so much the amount of tongue weight vers the capacity of the truck, it's WHERE that weight will be carried, on the bumper, which is about 2 feet behind the rear axle, and that is the problem with not using a WD hitch. The WD hitch as we all know, just moves that weight farther foward on the tow vehicle, and drastically improves the ride and handling of the rig. Unless it was a fifth wheel, personally I would not consider towing for any length of time, a 29' 5000 pound trailer without a WD hitch. But, that's just my opinion.
Steve
Old 04-05-2008, 09:02 AM   #7
Images: 26
That's why I suggested the weighing thingy
MY Ram CTD with WD sets the front axle very close to max weight rating due to the big-o-chunk of clattering iron under the hood. With nothing in the bed of the truck the rear axle has 'tons' of extra capacity
Hi Ho Silver RV!
Old 04-30-2008, 10:46 AM   #8
Profile:  1987 29' Sovereign
Huntsville , Alabama
Pull Rite Hitch
I tow with a 2000 250 crew cab and have a +/_ 45 degree Pull-Rite hitch which I absolutely love because there is no sway at all.
Airstream87 is offline   Reply With Quote
Pingbacks are On
85 Ford F250 diesel pull 27ft. Ambassador?? LucyPepper Tow Vehicles 2 03-23-2008 04:20 PM
Ford F250 Brake Controller Harness for trade thecatsandi Towing, Tow Vehicles & Hitches 6 08-31-2007 09:25 PM
Anybody pull with stock Ford 7.3L Powerstroke diesel? JBCrete2 Tow Vehicles 15 08-07-2007 11:29 PM
Can I pull a 1980 Ford Courier Pickup??? Snadi Airstream Motorhome Forums 3 04-19-2006 02:04 PM
5.9L Jeep to pull 29' Ambassador? MiamiMike Our Community 5 03-14-2003 01:35 PM
SEO by vBSEO 3.1.0
