Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 03-26-2008, 08:48 AM   #1
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
dearborn , Michigan
2 TV's, one HAHA?
Brand new HAHA owner.
Still in the box.
Installing this weekend.
Q:
Is it possible to (easily) configure this hitch to be swappable between to trucks?
That is, will I need to buy a second set of anything?
The two trucks have identical receiver heights (so ball heights should stay the same?)
But that’s where the similarities end
Suburban 2500 & Dodge 3500
I’m hoping its just a matter of marking where the settings are (after I scale each rig)…
Any thoughts?
finalcutjoe is offline   Reply With Quote
Old 03-26-2008, 09:17 AM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
Still in the box.
Any thoughts?
Both vehicles have different suspenions. they will squat differently under the same load.
Give Roger Willliams AS (in TX) a call. I know David swaps between different TV and trailers.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 03-26-2008, 10:01 AM   #3
2airishuman's Avatar
Profile:
..Is it possible to (easily) configure this hitch to be swappable between to trucks?...
the hitch STAYS attached to the trailer, not tv....
so if the receiver height is the same and you went with the 1400lbs w/d bars...
the only adjustment between the 2 towing units is jack tension....more for the sub, less for the ram.
there are other minor details that have been covered elsewhere, like the potential of needed 2 different stingers...
see posts #407-409 on this issue.
INSTALLATION is covered well with photos by jim clark earlier in the thread...
the ultimate haha users guide...
on the sub side, the stock receiver is INADEQUATE for a 30/slide tongue mass, and should be upgraded to class 5 capacity.
cheers
2air'
on other related note, the a/s site no longer shows the 30/slide unit, HAVE THEY DROPPED THIS MODEL for the coming year?
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-26-2008, 10:26 AM   #4
dearborn , Michigan
cheers
2air'
you're not kidding the OEM was inadequate... I upgraded to a Reese 'Tow Beast' class V...
thanks.. i'll check the thread...
no slide for 2009??
wow... sounds like nows the time for deal$
Old 03-27-2008, 08:17 AM   #5
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
Q:
Yes, you lucked out with your tow vehicles being the same height.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
Old 03-29-2008, 05:04 PM   #6
dearborn , Michigan
thanks all... can't wait to try the HAHA... i've got about 5500 miles with this rig using an equalizer brand hitch... looking forward to evaluating the performance difference... btw- the equalizer hitch performed flawlessly during that time (the chevy receiver is a whole 'nother story)
Old 03-29-2008, 06:13 PM   #7
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 26
Thumbs down Weak Link
no slide for 2009??
Me Too, Me Too
Just got the Tow Beast for our "new" tv. That GM reciever was the only
weak link in an otherwise great rig.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 03-30-2008, 06:57 AM   #8
Commercial Vendor
Hensley Ron's Avatar
Profile:  Currently Looking...
Oxford , Michigan
I need to upgrade the receiver on my Avalanche, too. The receivers in question were supposed to be in the '98-'06 model (give or take), but the one on my '07 Avalanche looks like the same one. Even had a rep from DOT up to the shop and he agreed that it looked the same (took him for a ride with the 33' Sunnybrook on a very windy November day, he was very impressed).
Did you guys compare the Reese with the Putnam heavy duty? Just wondering what pushed you toward Reese.
Ron Estrada
Hensley Mfg., Inc.
Hensley Ron is offline   Reply With Quote
Old 03-30-2008, 07:35 AM   #9
THE FRANTIC BANANA
W.N.Y. , "
Images: 26
Reese/putnam
The difference I noticed was the mount channel. The Putnam from what
I could tell from several different photos only had three small mount tabs.
The Reese looked more substantial all around the price was comparable,
and the Reese was in stock at the local shop.
FWIW, I included a few photos of the OEM recievers. You can make up your
own minds.
You can plainly see the difference.
Name:	Reese Beast.jpg
ID:	57263  Click image for larger version
Name:	2001 SUB #1.jpg
Name:	2007 ALALANCHE #3.jpg
ID:	57265  Click image for larger version
Name:	2007 AVALANCHE #2.jpg
Name:	2007 2500 HD #2.jpg
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 03-30-2008, 10:10 PM   #10
Commercial Vendor
The Reese Titan will require a reducer sleeve to get the 2.5" opening down to a standard 2".
The Putnam XDR is already a standard 2" receiver tube.
ProPride, Inc.
800-960-4767
Old 03-31-2008, 07:16 AM   #11
Commercial Vendor
Oxford , Michigan
The adaptor sleeve might be another source of noise. Other than that, not a big issue. This is my third GM truck (well, 4th since I totaled Avalanche #1 last fall) and I've seen cracking around the welds on one of them. I probably abuse my trailer more than the average weekender, though. I take it back on the two-tracks for hunting camps and such. For the full-timers, I'd definately recommend an upgrade. It's not just GM, either. We've heard of a few high end SUVs with really substandard receivers.
Which is why I'm not terribly concerned about OEM brake controllers. They'll go with the lowest bidder and the aftermarket will be there to pick up the slack.
Ron Estrada
Hensley Mfg., Inc.
Old 03-31-2008, 03:20 PM   #12
THE FRANTIC BANANA
W.N.Y. , "
Images: 26
Thumbs down Missing Sleeve
Supposed to be ordered with the reciever but some how got overlooked.
There going to weld it in for nutt'n, but I had hoped to have it installed
by now!
But don't it feel good, work'n on suppin nue
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 03-31-2008, 03:39 PM   #13
dearborn , Michigan
half dozen of one.... actually, if i'd known the other make had a 2" receiver, i would have gone that way... can you see any issues with permanently welding (AOT just a few tacks) the sleeve in there?
Old 03-31-2008, 03:43 PM   #14
dearborn , Michigan
i didn't visualize any cracks in my GM receiver... but the tube steel receiver itself was bent upward so severely- it was essentially zeroing out any WD from my 1200/12000 equalizer brand hitch...
Pingbacks are On
the ultimate haha users guide... 2airishuman Hitches 597 07-09-2008 03:36 PM
not another new guy....haha zenith Member Introductions 8 02-17-2007 08:55 AM
LCD TV's jcanavera General Interior Topics 58 11-19-2004 07:27 AM
Anchoring tv's and stuff Rog0525 Our Community 20 02-21-2004 08:16 AM
Tv's and such zduke4x Airstream Motorhome Forums 3 09-26-2003 08:43 AM
SEO by vBSEO 3.1.0
