Old 07-11-2010, 08:38 PM   #15
ole81's Avatar
1981 31' Excella II
Richmond , Texas
I am puzzled at the fact that there are no comments about Pullrite in almost 2 years.
We pull our 1981 31' Excella II with our 2001 F-250 diesel and it makes long trips a real breeze....
no more stress from 18 wheelers whizzing by.
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 07-11-2010, 08:53 PM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Pullrite hitch.
Hi, I think I have only seen two of these hitches in my life; And I'm pretty old. But I have never seen one with a trailer connected. Like to see pictures of one connected in straight and turned positions.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-12-2010, 06:50 AM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
By all reports the pullrite works well.
The lack of popularity is due to the need to have one such hitch per TV, and due to the problems with clearance during installation.
I sometimes borrow an extended cab pickup when I need room for more passengers, which is easy enough to work out with the ppppp. With the pullrite I would need two hitches.
Old 07-12-2010, 07:22 PM   #18
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
To get an idea how the Pullrite Trailer hitch works and a short video go to:
PullRite has a SAFER, STRONGER, BETTER designed hitch for you
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 07-13-2010, 08:55 PM   #19
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Always Pros and Cons....
Yes, I admit that the PullRite has some disadvantages....for example, you have to carry your TV spare in the bed of the truck because of the PullRite's configuration.
I have never used a Hensley or other comparable competitor, so I can't make a comparison.
...but in my book, the advantages far outweigh the disadvantages.
I used to be totally stressed out towing before I bought this truck with the PullRite.
31' 1981 Excella II
or
Old 07-18-2010, 07:12 AM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I looked at the PULLRITE and found only two negatives:
1] Weighs over 400# as installed on TV. (If I had to do it over I would have bought a 1T versus a 3/4T truck . . coming close to factory payload capacity isn't difficult with a big trailer and fulltiming equipment aboard).
2] Reduces ground clearance significantly at truck rear. It'll need to be checked against each vehicle, but, a 4WD is a more likely candidate than a 2WD pickup.
What I liked about it -- and still do -- is the ability to pull OTHER trailers with the antisway qualities of the hitch.
As others have mentioned, spare tire needs to be relocated and exhaust system needs to be re-worked.
Doesn't seem so long ago that a PR was about $750.
Old 07-21-2010, 05:30 PM   #21
ole81's Avatar
1981 31' Excella II
Richmond , Texas
PullRite clarification.....
I take issue with the comment about the clearance behind a pickup.
We are pulling with a 2WD F-250 and will attach a picture at the first opportunity, but right now we are disconnected.
(As I write this, we are sitting under a tree at the factory, waiting to have additional awnings installed, as we travel on to Warren, OH to the Packard Museum.)
Yes, it was a bit of a challenge to invert the hitch, but there is NO PROBLEM when you use a ball with a 2" riser, as described in the PullRite manual.
Also, as I recall, the PullRite is attached to the frame of the truck with 8 bolts. Yes, it is heavy.
I never expect to need to move it to another TV, as our diesel only has 111,000 miles.
Bob and Gail
31' 1981 Excella II
or
Old 07-21-2010, 08:34 PM   #22
ole81's Avatar
1981 31' Excella II
Richmond , Texas
PullRite clearance
OK...
Here's a pic of Ole81 connected to the truck....not the best pic because the sun was facing me....but you can get the idea. With the adapter inverted and using a ball with a 2" lift, you have absolutely no problemwith clearance!
Also, the question was raised about the weight. It would be a good Physics exercise to determine the advantages or disadvantage of PullRite's weight being UNDER the TV, versus Hensley;s weight being cantilevered BEHIND the truck.
Maybe there is an engineer following this forum who can analyze it.
31' 1981 Excella II
or
Old 07-21-2010, 08:38 PM   #23
_
thanks for adding user content bob.
no engineers are needed.
simply take the truck to a scale and WEIGH it (steer/drive axles)
then hook up yer stream and repeat.
then be so kind as to REPORT back the figures.
cheers
2air'
Old 07-22-2010, 09:30 AM   #24
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thanks for the info. The pictures I have seen of installations show a fair amount of reduced ground clearance on a pickup truck rear. Nice to see that someone is using it on a 2WD. Now, what is the ground-to-truck-frame clearance, and what is the number against the low point of the PR?
Thanks.
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hensley, Pullrite, etc. markjoandall Hitches, Couplers & Balls 28 09-14-2009 08:51 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
