Old 07-11-2015, 07:49 AM   #71
SteveH's Avatar
Common Sense , Texas
You actually don't keep the ball "compressed into the front, and the way the yoke holds the head square with the tongue, it doesn't matter, again, unless the yoke slips.
The yoke is held square under the A frame with a bar setup that is clamped to the A frame with "U" bolts, and in extreme circumstances like lagging trailer brakes, it will slip. Think of the yoke as a tongue on an old four wheel wagon.
Regards,
Steve
Old 07-11-2015, 07:51 AM   #72
dznf0g's Avatar
Oswego , Illinois
I need to sit down and study one "live" one of these days.
-Rich-
Old 07-11-2015, 07:57 AM   #73
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I'll have to have Cheryl back it sometime and get out to watch the difficulty I've never noticed.
Doug and Cheryl
Old 07-11-2015, 07:57 AM   #74
K.C. , Missouri
There was an interesting thread over on rv net a few months ago. A fella there was having sway problems with a large white box toy hauler behind a Ram 2500. He went through a LOT of work using a conventional sway control/WD hitch, multiple passes at the CAT scale, etc, trying to eliminate a sway problem at highway speeds. Nothing worked.
He bought one of these pivot projection hitches, and it "eliminated" his sway issues instantly.
One of my take aways from this whole discussion of this design vs conventional design hitches is that if you have a problem child trailer ( and perhaps a marginal tow vehicle, from a stability standpoint ) then one of these hitches may provide the solution you are looking for.
The flip side of this is that if you have a trailer that is fundamentally stable in it's setup, then the added expense and weight may not be worth it. When I installed my "conventional WD/sway control" hitch ( BlueOx ) on my SOB trailer, I took it for a test drive, and tried to make it sway. Yanking the steering wheel back and forth at speed, also, dropped the right side wheels off the edge of the pavement, and pulled back up onto the road. No sway. All I managed to do was re-arrange some loose stuff inside the trailer, and "open some cabinet drawers".
For me personally, I would not hesitate to buy a propride if I felt I needed it from a safety standpoint. But at least for this trailer, and this truck, what I have is working correctly.
Not all trailers tow the same, and not all trucks handle the towing the same. Use what works for your particular lash-up.
And yes, I know what "good towing" feels like. I have four trailers I tow on a regular basis ( two bumper pulls and two different goosenecks ).
gmw photos is offline   Reply With Quote
Old 07-11-2015, 07:58 AM   #75
SteveH's Avatar
Another way to view it is like the old yoke's on early model Fords that held the axles in place.
Or, take the Hensley struts loose from the A frame, and tie them to a common point under the A frame.
Regards,
Steve
Old 07-11-2015, 03:07 PM   #76
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Originally Posted by SteveSueMac View Post
I wish I had taken a picture of it at the Mothership. They moved ours like that with 2 large vice grips - one to each side (left and right) of the center of the head sitting on the trailer. If you just put your hand on the head and move it left and right, you will see where a pair of clamps will keep it straight and prevent it from swinging. Hard to describe otherwise :-)
Steve,
Could this be the set up you saw at JC? After playing with my vice grips, this appears to be the only way to immobilize the head.
>>ron<<
Name:	pro pride hook up.JPG
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 07-11-2015, 03:16 PM   #77
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That looks about right, Ron - does it "freeze" the head from moving? I think Jackson Center used bigger vice grip clamps and the handles weren't pointed out (left and right) but both with handles facing forward of the hitch.
If that locks it, I think you got it!
SteveSueMac is online now   Reply With Quote
Old 07-12-2015, 11:01 AM   #78
fth
2003 39' Land Yacht XL 330 hp w/2slides
Fairlawn , Virginia
I just installed a Hensley last week for the first time. It took longer to read the manual than to actually install it. Much less than an hour and easy to do.
fth is offline   Reply With Quote
Old 07-12-2015, 11:13 AM   #79
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Steve,
Thanks for your reply. I'll try and see if I can lock up the head with the vice grips going the other way. Looks like a trip to Harbor Freight will be on my schedule for next week to pick up some larger vice grips. Now where did I put that %20 discount paper?
>>ron<<
Old 07-12-2015, 11:30 AM   #80
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I have not noticed this backing "thing" at all. For that reason,
I'm not going to spend the time analyzing it.
I have had a lot of opportunity to watch the hitch while backing, because my wife always backs the trailer while I provide guidance and obstacle avoidance. I am 100% convinced, if this phenomenon exists on the ProPride, its effect can be measure in a few inches at most.
Ken
Old 07-12-2015, 11:45 AM   #81
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ken
Yeah... For everyday use this is a nonissue. If you are working with very close tolerances.... That may be critical. Then Again I have a 34'
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-12-2015, 11:47 AM   #82
2016 30' Classic
Erie , Colorado
Don't use the vice grips UNLESS you are using the ball head extension like the factory uses on their tugs. If you clamp it down that way with the the stinger hooked to your truck like normal towing likely you will need your check book handy. Just sayin' ....
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-12-2015, 01:05 PM   #83
W , New England
I don't know where the pic went in Brian's #44 post in this thread - but it showed a tractor with a particular contraption on it for ProPrides - which is different than the one they use for Hensleys- and they have one for PPs with a 2.5" hitch (Sean overnighted it to them when we were in for service and they needed it...).
I don't know exactly how they set it up but your point is well taken. If any questions, call Sean for sure!
Old 07-12-2015, 02:08 PM   #84
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Idon't know what happened to that picture, either. I will repost all of the applicable photos.
Brian
ID:	242777   Click image for larger version
SuEllyn & Brian McCabe
Good deals on 34s vs 30s, pros and cons. Robbie R. 1998 Excella 1000 3 09-01-2009 05:54 PM
'66 Safari or '66 Overlander Pros and Cons yankeemomto3 Member Introductions 10 02-17-2009 08:21 AM
Tandem or single axle. Pros and cons? Yonner Towing, Tow Vehicles & Hitches 18 06-22-2008 10:41 PM
Club Memberships ...pros and cons? Leesure Our Community 12 06-01-2006 10:12 PM
