Ok, so I should probably confess <donning flame suit> I currently do not have any sort of sway control or wd hitch to use with my 'Stream There, I said it. So far I've towed her over 2500 miles with absolutely no issues, up and down fairly significant grades, passing semis, etc. No problems.
I've towed a LOT of heavy trailers in my day, most without trailer brakes, and none with any sort of sway or wd devices and never, ever had any problems. Never any close calls, no sway, no nothing. But I've always towed with big @$$ trucks and drove at reasonable speeds. Same goes with my current truck, it outweighs the 'Stream by about 1k lbs. With the diesel and the 400lb bumper on the front the the ole F250, I don't even think WD is necessary in my case.
However, after reading more than a couple threads on this very forum about folks rolling their TV and 'Stream due to severe sway, I'm going to bite the bullet and get a WD and sway control system. Granted, in my opinion, all the folks who crashed that I've read about, were towing too much 'Stream with too little truck, but I digress.
So, tell me your opinions on the two hitches mentioned in the title of this thread. I'm getting one or the other.
Here are my concerns:
1. I don't like the cost of the ProPride, but I firmly believe you (usually)get what you pay for. I have the cash, so that is not the main issue
2. The weight of the ProPride is, best as I can tell, in the neighborhood of 250 lbs. That is a lot of extra tongue weight, but I'm assuming the a-frame of the 'Stream can handle the extra mass and inertia it brings with it (whether or not it is distributed).
3. I don't want any issues on slippery surfaces which is why I've excluded any friction type sway control. How is the ProPride on slick roads?
4. Reese, from all I've read, can be extremely difficult to set up correctly. Not good.
5. I like overkill, but I don't like throwing money away either. If I had a 34'er, I'd definitely go ProPride, but I only have a 25'er with a big truck. Is the ProPride stupid overkill? A waste of money?
Hi, you may have opened a can of worms. I think the Propride is probably a great hitch and many swear by the Reese too. I'm very happy with my Equal-i-zer, but you didn't ask about that so I will say no more. The weight of the hitch might be more of a concern to me than the price. I also think the high dollar hitches are more suited for the longer than 25' trailers and those who feel a bit insecure while towing. [driver ability] So far it seems to me that you don't fit into this category. Some feel that these hitches are magic for under sized tow vehicles; And for that I say no hitch will make up for that.
Robert, the weight of the ProPride is one of my major issues. That is a lot of extra mass on the tongue. That would put me over 1000lbs of tongue weight. Also, about the Equalizer, it is my understanding it is a friction type sway control and that those are not good in slick conditions. I am going to be doing a cross country trip in late December and I do not want any issues if I encounter snow covered roads. Someone school me if I'm all dorked up.
I should probably say I'm leaning towards the Reese Straight line but haven't made a firm decision yet.
2air, didn't know that about the Reese cams. That muddys the water a bit.
I should say that so far, the 'Stream is the best towing trailer I have ever towed and if I hadn't found this forum, I would probably never buy a WD and sway control system. But after seeing the carnage on these very webpages, it makes me think maybe I've just dodged a lot of bullets. Probably not, but you never know.
I also want my friends and family, who may not have as much towing experience as I do, to be able to tow without me worrying about them crashing my trailer due to sway. After I broke my leg a couple weeks ago at a race, I had to have someone I barely even know drive my 'Stream back to my house. He knew what he was doing, and even commented to me at the hospital that it was the smoothest tow he's ever experienced. But if he hadn't been there, my girl would've had to tow it, and that scared me a little bit. Not because she's a bad driver, but because she has no towing experience.
I tow a 25' also, but with a smaller 1/2 ton truck. I recently switched from a Reese Dual Cam hitch (the new version), to a ProPride hitch. I've towed lots of different travel trailers thru the years and used several different hitches.
My experience with the Reese was it was a pretty good hitch, but a real PITA to get adjusted correctly and if it's not adjusted absolutely corectly, the anti-sway function just does not work. I had the earlier version of the Reese years ago, it worked better because it was much easier to adjust. They both use friction along with increased lift on the bars to control sway. Here is how if finally figured out how to adjust it after a year of using it: About the "High Performance" dual cams...
The ProPride on the other hand, is a totally different devise. By design, it totally eliminates sway. I contemplated spending the money for a long time, researched how it worked, and talked to lots of Hensley and ProPride users before I "bit the bullet". At this point, even though I've only towed with the hitch a little bit, I am VERY HAPPY with it's performance.
One other thing...the Reese sway control depends on weight on the bars for sway control, and if there is not much weight on the bars, the sway control does not work. The ProPride and the Hensley, however, do not depend on weight on the bars to control sway.
Thanks for all the comments thus far. Sean, I may be calling you in the next few days.
What is the recommended bar size for my application (2001 Ford F250 SuperDuty 4x4 extended cab, short bed diesel with a ginormous (and heavy) front bumper)?
Based on Inland Andy's recommendations, I was going to go with 600lb bars if I got a Reese, and planned to do the same if I got a ProPride. I want a soft ride (which I have now).
2 Air
If your claim that all sway control with a Reese Dual Cam hitch is caused by friction then Reese's
statement that the Dual Cam Sway Control is fully automatic and self centering would be false. A friction system would only resist movement, a system that self centers would only occur when there was differential pressure on the trunnion bars.
Thats all for now. Let me hear your thoughts.
Airstream01
The installation instructions are not that complicated. I watched Randy the RV Tech at Weekley RV install the hitch on my trailer. He first centered the Cam Arm Yoke so that there was an equal amount of threads on either side of the yoke. Then following the instructions he measured and marked the position of the frame plates and snap-up brackets, before mounting the components he double check the measurements. We have towed our trailer about 19,000 miles with no problems or complaints about hitch. How you spend your money is your business, but for our $3000.00 we bought a full awning package, a solar package, a $600 dollar hitch installed, with money left over to buy other accessories.
Richard from Noth Branch, MI
20' 2008 Safari SE Silver Dog House
2007 GMC 1/2 ton Sierra AIR # 10494
I would normally recommend a 3P-1000 for a 25' Airstream. Andy's recommendations are based on what he knows to be true with the Reese systems he sells and that does not hold true for either a ProPride or an Arrow.
However, considering your HEAVY front bumper you could use the 3P-800.
__________________ ProPride Hitch "The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
