Old 09-20-2017, 06:09 AM   #15
james.mileur's Avatar
Kalispell , Montana
Make sure when installing the tilt washers for the stinger, pick up the end of the stinger, as if the head was hooked up, to remove the slack in the receiver-stinger fit. Then add washers to get a downward tilt, just past horizontal.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-21-2017, 06:29 AM   #16
Tulsa , Oklahoma
Thank you!
David Briggs
Ebb - '15 F-150 Lariat
3.6L Turbocharged w/ 6 speed
3.31 Diff. and Tow Package
Flo - '12 AS International Serenity M-30'
Dlbriggs is offline   Reply With Quote
Old 09-21-2017, 06:57 AM   #17
mojoe7009's Avatar
Green Cove Springs , Florida
Originally Posted by BlueMesa View Post
Ok. Got it.
Easiest way to find it is to remove the 4 screws holding the box in that surrounds the DVD player. You’ll see it laying towards the back. Bring it up through the opening in the left rear corner and remount the box. Remember to turn off the TV antenna on the switch plate behind the TV when you want satellite or you want get a signal to the TV.
Breathe In, Breathe Out, Move On
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 2500 Limited CC 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
mojoe7009 is offline   Reply With Quote
