Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-04-2008, 05:54 PM   #15
denellen
denellen's Avatar
Profile:  2007 25' International CCD
1964 19' Globetrotter
vero beach , Florida
Thumbs up nice install details
Originally Posted by TROPHYJIM2 View Post
. Any feedback would be appreciated in terms of the install. What do you guys think,,,does the install look close? Thanks! Jim
Great detail picts. Tnx. Looks good. Don't forget to cross your chains.
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 06-04-2008, 06:22 PM   #16
Whizzo
Whizzo's Avatar
Profile:  2008 22' Safari
Helotes , Texas
Images: 14
It's a handsome looking unit, almost like it was styled for A/S use. Looking forward to reading about the longer range tow "feel" feedback.
Though the design is the evolution of Hensley's original, there don't seem to be major visible differences, other than the bracing running under the gas tanks, and shorter struts holding the main assembly. Am I missing others?
2008 Safari Sport 22
2003 Ford Explorer NBX, 4.6L, 3.73
Hensley Arrow Hitch, McKesh Mirrors
Whizzo is online now   Reply With Quote
Old 06-04-2008, 09:50 PM   #17
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
As a point of comparison, how far is the truck moved forward from the front of the trailer body compared to the original hitch? (Mine, on an S/S, not A/S, is now at 64").
I copied off a few of those pictures so as to compare to the H/A I have, (still need to get W/D correct), and am, of course, curious to hear all that you'll have to say about the hitch.
It certainly looks good, and I like what I see of adjustment possibilities.
Good luck.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 06-04-2008, 09:54 PM   #18
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Very Interesting!
Looks like a Hensley on steroids! I guess the market has changed.....
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 06-04-2008, 11:13 PM   #19
2airishuman
2airishuman's Avatar
Profile:
hi jim...
-cross the chains and run them INSIDE and under the springbars...
-put a lock of some sort in he trailer tongue cup latch...
-reroute the 7 pin umbilical to the other side and OVER the top...
-the cable/wire for the break-away should really be looped onto something OTHER than the reciever....
-consider putting a dab of paint on EVERY nut/bolt on the stinger and frame brackets,
this will make any movement/slippage easier to see..
-how level is the trailer once connected? it sorta looks nose high in the last pic...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 06-05-2008, 07:25 AM   #20
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Jim! Great install pics. The first time I've seen one in the wild! Ditto 2air's points above. Also, you won't need much extra slack in the umbilical and breakaway wires. Too much and they can get caught on something.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-05-2008, 07:32 AM   #21
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
Great catch on the chains 2air'. This morning I was actually thinking that I didn't look at the chains when I commented on Jim's install yesterday so thanks for catching it.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
Old 06-05-2008, 12:19 PM   #22
TROPHYJIM2
Profile:  2008 31' Classic
Sweet Valley , Pennsylvania
Thanks Everyone
Thanks for the feedback. I thought I might be slightly nose high but not sure, The long shot picture is on pretty level ground I love the idea of marking with the paint. Thanks! Jim
TROPHYJIM2 is offline   Reply With Quote
Old 06-05-2008, 03:15 PM   #23
TROPHYJIM2
More Pics
Old 06-05-2008, 03:18 PM   #24
TROPHYJIM2
I got to find something "more appropriate" than that white Lithium Grease. A little color coordination is in order
Old 06-05-2008, 03:30 PM   #25
2airishuman
Profile:
secure to the trailer tongue?
hi jim
thanks for the pix...
my understanding is that NO HOLES are drilled into the A frame for the mounting?
while that seems like a nice change it also means the frame brackets,
and by extension the strut bars are only held secure to the A frame by the U bolts... at the aft position...
IF that's correct, i'd be VERY uncomfortable leaving the stainless sleeves on the A frame...
not only can water get under the sleeves and cause rust (and it will happen)...
but the secure point created by the U bolts has got to be affected, by the additional loose layer over the A frame...
the rust issue (under the sleeves) is real on the haha,
but the U bolts are backed up by the shear bolts, so the stainless sleeves are less of slippage issue....
is there something different in the new design that makes slippage on the A frame less likely?
neither of these hitches would perform well IF the strutbars n framebrakets move...
cheers
2air'
Old 06-05-2008, 03:34 PM   #26
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Not having ever used a HaHa or PP my question for both is why can't the tensioners be replaced with the Reese chains and hangers. I would think it would be a lot faster hitch up and a much smoother looking installation if they were used. Besides the chains would give a consistent tension for weight distribution.
They have aways looked like an under engineered after thought.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-05-2008, 03:43 PM   #27
2airishuman
Profile:
Originally Posted by HowieE View Post
...why can't the tensioners be replaced with the Reese chains and hangers...
with a bracket modification this could happen...
BUT IT WOULD BE A HUGE STEP BACKWARD...
the screw jacks are a significant improvement over chains...
-much easier to tension
-way more increments of adjustment
-i've measured weight transfers for every turn, which is about 5-6 increments "per link" of conventional chain...
-it LOOKS much better/cleaner imo...
-the "consistent tension" should be indentical for the screw jacks (actually better since chains can be twisted)
-hook up is MUCH faster (related to the screw jacks) because they are "always" on...
-and fine tuning w/d during travel/after hookup is SO MUCH quicker and easier...
-there is NO need to hook up chains ever after the primary installation...
using a power drill is faster than using the manual rachet/wrench but even that is easy...
the funny thing about your observation howieE is that i've always had the opposite view...
and IF using the reese or "sob" hitch, i'd be looking for ways to ADD THE SCREW JACKS!
lastly because of the issues related to hooking up with a hitch of this design,
being able to quickly and in small increments reposition the hitch/stinger box is essential to hook ups...
moving the box with chains would be cumbersome and much less precise...
cheers
2air'
Old 06-05-2008, 04:16 PM   #28
Sean Woodruff
Commercial Vendor
Originally Posted by 2airishuman View Post
hi jim
cheers
2air'
There are no forces directed along the frame that the aluminum cover would make the u-bolt slip. Due to the design of the yoke, the yoke tail forces are almost perpendicular to the frame and against the down tubes of the frame bracket.
One customer did not use the u-bolt plates under the frame bracket. (I'm not sure why but they weren't there when I got the picture.) He only had the 7/16" SAE washers holding the u-bolts in the slot on the bracket. The bracket shifted but it shifts in a side direction and the u-bolts tightened up and secured the bracket. This is not a front to back shift as in the frame bracket on the haha. This shift does not cause the yoke to become loose and allow pivoting on the ball.
All that said, the rust issue under those covers is a real one. I have installed many hahas on Airstreams and there is always rust under those covers.
ON EDIT:
UPON FURTHER REVIEW...The frame bracket u-bolts are not installed over the covers. The jack bracket u-bolts are but there is no sliding force whatsoever on those. They do not take any force ALONG the frame as the haha bracket does.
ProPride, Inc.
800-960-4767
Big DEE hits 1000!!! Buttercup Our Community 6 05-10-2007 06:40 AM
Our new (not so) baby hits the road. Pecos Pete Our Community 10 02-08-2007 05:48 PM
NEW 1948 Suburban hits the market! 85MH325 Off Topic Forum 22 09-10-2005 07:03 AM
