Old 04-22-2017, 10:19 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Propride Hitch Mod to avoid Jack Post interference
I'm thinking I introduce a piece of hardware to allow for quick removal of the Spring Bar Link from the Spring Bar to swing it away so I can lower the Jack Post where it would otherwise hit the Spring Bar on those tight sites when you can't get totally straight. The hardware would be something like a quick release shackle with a pin such as the one manufactured by Smittybuilt.
http://www.ntwonline.com/QUICK-RELEA...TS-P14127.aspx
Comments? Anyone have another idea?
Ted S. is offline   Reply With Quote
Old 04-22-2017, 10:27 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
How often does that happen? I've had some tight ones but always seem able to move forward a few inches to straighten out the geometry - and my jack stand doesn't have a foot on it so if that's getting in your way, my recommendation would be to take the foot off and have it settle on a stand (I got a great aluminum one from someone here in the forums whose dad made them...).
Otherwise on the pin itself, it seems like that would work - I just wonder if it would affect the workings of the hitch while actually driving the rig.
Would recommend giving Sean a call on that plan for sure. Let us know what you hear! Good luck!
Old 04-23-2017, 12:32 AM   #3
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
I like the idea! In most cases I can back up a bit more, straighten out best I can, then I lock the trailer brakes with the brake control and pull forward. This will usually get it straight enough.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 04-23-2017, 05:47 AM   #4
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
"Lock the trailer brakes with the brake controller". BRILLIANT!!
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 04-23-2017, 06:59 AM   #5
Llando88's Avatar
2016 30' Flying Cloud
That is an excellent idea. Thanks.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 04-23-2017, 08:13 AM   #6
2015 30' FB FC Bunk
Yes, locking the brakes is an excellent idea. The head of the hitch takes a bit of forward motion to straighten out, I'm assuming this pulls it straight real quick?
So I bought one of those aluminum cones, I'm going to remove my jack foot. Between that and the locking brake trick it's should greatly reduce my issue.
We tend to find tight spots, we like remote areas. I just want to be prepared as best I can.
Old 04-23-2017, 09:13 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I quit using the attached jack foot long ago and carry a 4x6 chuck of wood to set under the jack.
It works best for us with the ProPride (or any hitch) to always back into a site, then pull forward a foot or so. This takes out the twist in the tires from backing and relieves sideways pressure on the hitch assembly for disconnecting, so it disengages easier. As stated, it also clears the w.d. bars away when the tongue jack is lowered.
Doug and Cheryl
Old 04-23-2017, 10:15 AM   #8
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
The idea of locking the trailer breaks is a good one....
In our case if I back in and the hitch head is not straight enough to allow the jack post to clear the WD bars. I would release the tension on the opposite WD and that will move the head over enough to clear the corresponding bar. I have used this method many many times and have never had it work.
Hope this help
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-23-2017, 01:25 PM   #9
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Agree with Arcticfox on this one. Loosen the opposite WD lack and head shifts out of the way in most all cases. I too have done this many, many times where the foot would not normally clear due to positioning after backing in and this has worked in all cases.
Chuck
silverlabs is offline   Reply With Quote
Old 04-23-2017, 05:57 PM   #10
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
that is interesting way to take care of the issue. I usually loosen both jacks adn move if possible.. have not tried just one side.
I have one of the alum stands and one of the tire chocks which are the deal. just wish they would make more and use a better grade alum as the stuff they use is quite fragile it seems. mine cracked in middle of the support part on the tire chocks.
also when you screw your jack, i find 6 3/4 to 7" above base a good number.. have not taken to scales just gauging the ride. When we first got trailer i used 5" and the ride was a bit rough in truck, lot of bounce.
how do you adjust yours..??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-23-2017, 07:00 PM   #11
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If the jack post gets in the way try using the Fastway automatic folding foot. What a great device. Never have to reach in the back of the TV and pick up block and lift it over the tailgate.
guskmg
Old 04-23-2017, 07:28 PM   #12
Llando88's Avatar
I suspect it will vary a lot by trailer, but FWIW, I use 7" on my 30' '16 FC Rear Queen.
Old 04-23-2017, 08:15 PM   #13
W , New England
Based on the CAT scales. I go to about 6" because it returns nearly 100% of what's lifted off the steer axle.
Old 04-23-2017, 08:33 PM   #14
2015 30' FB FC Bunk
That's my dream. I warped a stock hitch trying to transfer that much, just replaced it with a Torklift Superhitch, we'll see how it goes.
Tailgate / camper jack interference mefly2 Towing, Tow Vehicles & Hitches 17 11-25-2014 03:54 PM
Hitch Interference Camp-Dog Hitches, Couplers & Balls 14 12-13-2004 04:56 PM
