04-22-2017, 09:19 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Propride Hitch Mod to avoid Jack Post interference
I'm thinking I introduce a piece of hardware to allow for quick removal of the Spring Bar Link from the Spring Bar to swing it away so I can lower the Jack Post where it would otherwise hit the Spring Bar on those tight sites when you can't get totally straight. The hardware would be something like a quick release shackle with a pin such as the one manufactured by Smittybuilt.
http://www.ntwonline.com/QUICK-RELEA...TS-P14127.aspx
Comments? Anyone have another idea?
04-22-2017, 09:27 PM
2012 27' Flying Cloud
W
, New England
How often does that happen? I've had some tight ones but always seem able to move forward a few inches to straighten out the geometry - and my jack stand doesn't have a foot on it so if that's getting in your way, my recommendation would be to take the foot off and have it settle on a stand (I got a great aluminum one from someone here in the forums whose dad made them...).
Otherwise on the pin itself, it seems like that would work - I just wonder if it would affect the workings of the hitch while actually driving the rig.
Would recommend giving Sean a call on that plan for sure. Let us know what you hear! Good luck!
04-22-2017, 11:32 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
I like the idea! In most cases I can back up a bit more, straighten out best I can, then I lock the trailer brakes with the brake control and pull forward. This will usually get it straight enough.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
04-23-2017, 04:47 AM
1997 25' Safari
Montgomery
, Alabama
"Lock the trailer brakes with the brake controller". BRILLIANT!!
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
04-23-2017, 05:59 AM
Tavares
That is an excellent idea. Thanks.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
04-23-2017, 07:13 AM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Yes, locking the brakes is an excellent idea. The head of the hitch takes a bit of forward motion to straighten out, I'm assuming this pulls it straight real quick?
So I bought one of those aluminum cones, I'm going to remove my jack foot. Between that and the locking brake trick it's should greatly reduce my issue.
We tend to find tight spots, we like remote areas. I just want to be prepared as best I can.
04-23-2017, 08:13 AM
2012 25' Flying Cloud
Battle Lake
I quit using the attached jack foot long ago and carry a 4x6 chuck of wood to set under the jack.
It works best for us with the ProPride (or any hitch) to always back into a site, then pull forward a foot or so. This takes out the twist in the tires from backing and relieves sideways pressure on the hitch assembly for disconnecting, so it disengages easier. As stated, it also clears the w.d. bars away when the tongue jack is lowered.
Doug and Cheryl
04-23-2017, 09:15 AM
2013 28' Flying Cloud
Central
, Canada
The idea of locking the trailer breaks is a good one....
In our case if I back in and the hitch head is not straight enough to allow the jack post to clear the WD bars. I would release the tension on the opposite WD and that will move the head over enough to clear the corresponding bar. I have used this method many many times and have never had it work.
Hope this help
Cheers
Doug
Trying to use my camera to create memories - not photographs!
04-23-2017, 12:25 PM
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie
Agree with Arcticfox on this one. Loosen the opposite WD lack and head shifts out of the way in most all cases. I too have done this many, many times where the foot would not normally clear due to positioning after backing in and this has worked in all cases.
Chuck
04-23-2017, 04:57 PM
2005 31' Classic
Garner,
, North Carolina
that is interesting way to take care of the issue. I usually loosen both jacks adn move if possible.. have not tried just one side.
I have one of the alum stands and one of the tire chocks which are the deal. just wish they would make more and use a better grade alum as the stuff they use is quite fragile it seems. mine cracked in middle of the support part on the tire chocks.
also when you screw your jack, i find 6 3/4 to 7" above base a good number.. have not taken to scales just gauging the ride. When we first got trailer i used 5" and the ride was a bit rough in truck, lot of bounce.
how do you adjust yours..??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
04-23-2017, 06:00 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If the jack post gets in the way try using the Fastway automatic folding foot. What a great device. Never have to reach in the back of the TV and pick up block and lift it over the tailgate.
guskmg
04-23-2017, 06:28 PM
Tavares
I suspect it will vary a lot by trailer, but FWIW, I use 7" on my 30' '16 FC Rear Queen.
04-23-2017, 07:15 PM
W
, New England
Based on the CAT scales. I go to about 6" because it returns nearly 100% of what's lifted off the steer axle.
04-23-2017, 07:33 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
That's my dream. I warped a stock hitch trying to transfer that much, just replaced it with a Torklift Superhitch, we'll see how it goes.
04-24-2017, 02:01 PM
2015 30' FB FC Bunk
Golden
6.5" 1,400 pound bars on 2,500 HD for 30' Bunk
04-24-2017, 04:50 PM
Green Cove Springs
I just pull the pin on the foot when hitched up. It drops out as I retract the post. When unhooking I place the foot on a couple of 2 X 6's and lower the post until the foot slides in, replace the pin and and raise to unhook height. Foot is never above the bars this way. That's how Sean at ProPride told me to do it. Simple, works.
Breathe In, Breathe Out, Move On
04-24-2017, 07:07 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I'm curious what 6.5" means?
I see that on a lot of Propride hitch threads. Is that the total distance you raise the jack? Where is the starting point? When I unhitch, my jacks are already up 3-4" -Thanks
04-24-2017, 07:11 PM
Green Cove Springs
That's the height to raise the WD jack pistons (located on either side of the tongue behind the propane tanks) as measured from the top of the frame.
04-24-2017, 07:15 PM
2002 30' Classic S/O
Fleming Island
That's what I've been doing for a while. I needed a longer foot for my 25 and the 2500, but it was too long to leave on so I do what mojoe does.
Al
04-24-2017, 08:36 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
That's interesting since I understand every trailer will have a different starting point on the jack. My jacks are 3" extended with the trailer unhitched. I read the Propride instructions carefully and he is saying when unhitching, the jacks may not lower entirely, they may be slightly extended.
So I have been reading these threads very confused. My jacks are 3" up at no load, then 8" fully loaded when hitched and ready to go. So I jack 5", but my jacks are 8" off the frame.
So I think it would be good to note how much jack you apply. Not how high your jacks are above the frame.
