Old 11-09-2013, 09:48 AM   #1
anniemaine's Avatar
2011 27 FB International
Belfast , Maine
ProPride bent stinger.
With all the research I did, I never ran across this critical issue. So I'm posting this warning to other newbies. My stinger is significantly bent and slightly twisted. Sean says it is because the chains were over the distribution bars rather than "between" them (meaning under, an illustration would have been helpful). Those buying a ProPride hitch, be aware that your chains are on correctly. I'm currently at a camp ground, waiting for UPS to deliver my new stinger. Annie
anniemaine is offline   Reply With Quote
Old 11-09-2013, 10:21 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If the chains somehow were the culprit, I'm a bit surprised that a cha9n link didn't let go before doing that sort of damage.
Wonder if the same thing can happen with Hensley? If the chain position is what caused it, I would imagine so - never seen that before though.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-09-2013, 10:42 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hmm. Did chains mark the pp anywhere? With the loads required to do that it would "leave a mark" on something.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-09-2013, 10:45 AM   #4
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
I would suggest checking out the receiver on the truck as well. There was a lot of force required to bend the metal...
Stuart
MaxTow is offline   Reply With Quote
Old 11-09-2013, 10:46 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That much bend in the hitch bar also surprises me. I wouldn't have thought that the chains were strong enough to do that.
As far as this happening to a Hensley Arrow, it apparently can. The Hensley Manual has a quarter page CAUTION with pictures stating that the trailer safety chains MUST be routed between and under the spring bars.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 11-09-2013, 11:19 AM   #6
Wingeezer's Avatar
2005 30' Classic
Brian
Good advice. I had forgotten that in the manual - if I ever read it!
I think that is what i do anyway, but will make sure from now on!
Brian.
2005 Classic 30'
Old 11-09-2013, 12:06 PM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Are you sure you weren't backing up on a sharp, tight angle?
I think it would take more than just the chain to exert that much force.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 11-09-2013, 04:10 PM   #8
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Hello Everyone,
Yes, with both the 3P AND Arrow it is necessary to have the chains routed BETWEEN the hitch bars and under the main hitch head. If you attempt to turn, for example 7500# around a corner, and the main hitch head is not allowed to pivot on the links, something is going to bend or break.
Annie, I'm looking into putting the diagram you recommend into the instructions.
The current instructions are as follows…
Page 22 is titled "Hitching and Unhitching"
Step 9 in hitching is…
"Step 9: IMPORTANTIMPORTANTIMPORTANT – Route your tow chains UNDER the Main Hitch Unit and BETWEEN where the Spring Bars insert in the bottom of the Main Hitch Unit. When you are straight in line with your trailer the chains are the longest they ever need to be. When routed properly they should hang about 1” from the bottom of the Main Hitch Unit."
(No emphasis that is not in the instructions has been added here. The bolding is also in the instructions.)
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 11-09-2013, 04:14 PM   #9
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Annie,
Glad you are safe. Thanks for the heads up and I'm sure you and Sean are looking into all possible reasons why.
I will say we all wait and let Sean finish his findings on this situation, that way we don't jump into conclusion too fast. I have never seen such in my years of towing other than load test and other experiment/s in the lab and heavy duty machinery trade shows. PP is always upfront and very demanding of his suppliers when it comes to product specs and integrity.
F450Harley is offline   Reply With Quote
Old 11-09-2013, 04:36 PM   #10
ProPride, Inc.
Just a little data.
Here are the hitch bar stresses with 2000# of tongue weight and 1000# of spring bar weight distribution.
As you'll see the bar does not come close to being overstressed even with 2000# of tongue weight.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 11-09-2013, 05:37 PM   #11
andreasduess's Avatar
1984 34' International
Toronto , Ontario
When I had my instructions from the dealer, I own a Hensley, I was told to always make sure that the chains are routed correctly, i.e as described above, otherwise this kind if damage could happen.
Hope that everything is going to turn out ok and the TV part of the hitch not damaged. I'll make double sure to check my chains in future.
andreasduess is offline   Reply With Quote
Old 11-09-2013, 05:54 PM   #12
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Here's the setup on my 2012 Flying Cloud. Note that the chains share a single "point of origin" on the a-frame. I mention that because people say you're supposed to "cross" the chains under the a-frame so the one on the left connects to the right side of your TV and vice versa. That's not possible with this configuration. However, they do go underneath and between the WD bars. That's how I interpreted the instructions and I'm assuming this is correct as I've had a full year of travel this way and no problems.
If this is accurate, feel free to use this as an illustration, Sean. If not, I'm ready for some education too!
Old 11-09-2013, 06:22 PM   #13
ProPride, Inc.
Attachment 199660
That is perfect.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 11-09-2013, 07:38 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Stuart
Annie,
That photo is quite startling to say the least. It's hard to believe that the tension/binding wasn't noticeable when turning/backing.
Is there any deformation or damage to the chains?
Inspect your receiver very carefully, be prepared to change it if there is any question of it's integrity.
Make SURE the mount bolts are intact.
If it was mine I would change the bolts & chains right off the bat, just to be on the safe side.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Adjustable Hensley stinger dmcummins Hitches, Couplers & Balls 31 03-23-2018 08:53 AM
ProPride stinger weld failure Jammer Towing, Tow Vehicles & Hitches 59 08-14-2013 10:26 PM
How can a bent frame be fixed? Eagle & Bear Repairing/Replacing Floor &/or Frame 7 03-02-2012 11:48 AM
Hensley stinger. BigAl Hitches, Couplers & Balls 4 04-06-2011 06:49 PM
