Old 06-20-2015, 11:46 PM   #15
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
I use the trailer's stabilizer jack wrench on my ProPride WD jacks and it works well as I count by turns, and not necessarily inches, which enables me to get where I want without measuring with a third hand. Standard set-up for me is about 50 turns. Works for me, maybe not for others.
But since it's not very practical to hit a CAT scale every time you hitch up, I let the trailer tell me if that starting point is good. Sometimes when I'm traveling a little heavier, 50 revolutions aren't enough, and I still get a little instability on a bump or in a curve. At these times, I crank an additional five turns and all is right in the world as the rig finds it's rails again. I've never had to go above 55 revolutions and I've rolled close to gross more than once.
YMMV.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
ProPride WD Bars SteveH Hitches, Couplers & Balls 14 06-13-2013 04:10 PM
Propride adjustment question. laynlow Hitches, Couplers & Balls 5 05-20-2010 04:25 AM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
