07-27-2015, 06:15 AM
#41
Originally Posted by featherbedder
If you can find clevis with screw in pin proper size simply hook length of chain needed, do not use hammer together loops as they will come apart. A clevis is u shaped with bolt that slips thru eye one side, threads into other eye
Also referred to as a shackle. I would use a properly rated safety Clevis/Shackle that utilizes a threaded bolt and cotter pin.
William C. Swinney
07-27-2015, 06:24 AM
#42
Oswego
I prefer a double clevis link like this:
National Hardware 3248BC 1/2 Double Clevis Link, Zinc | TractorSupply
Properly rated for your chain, of course, for adding length to your chains.
-Rich-
07-27-2015, 08:07 AM
#43
1976 31' Sovereign
Oswego
safety chains
Originally Posted by dznf0g
Better than single clevis. Brain fade this am forgot about dble. I have used many times.
07-27-2015, 05:04 PM
#44
2012 23' FB International
Woodstock
, Ontario
I think a double clevis link is the best option for extending a chain.. You will need to match or exceed the chain strength and size to fit the chains on your trailer
WP161106 Double Clevis Link - Grainger Industrial Supply
JCW
07-27-2015, 05:49 PM
#45
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Twist and cross under the hitch head
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
07-28-2015, 02:15 PM
#46
2007 22' International CCD
Corona
ProPride sells an extension kit with their hitches that includes a set of double Clevis connectors and two lengths of appropriate chain.
Try calling Sean about getting one.
07-28-2015, 02:29 PM
#47
1976 31' Sovereign
Oswego
safety chains
Do not twist chains as makes a weak spot [links] to break.
07-28-2015, 04:38 PM
#48
2013 30' Classic
Greenwood
, Mississippi
Twisting them is the proper way to make them short enough to not drag the ground. A slight twist can't possibly affect the strength of the steel.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-28-2015, 04:48 PM
#49
2012 27' Flying Cloud
W
, New England
I don't know for sure, but this chain manufacturer disagrees with you.
http://www.lacledechain.com/blog/ent...in-quick-facts
08-14-2015, 08:51 PM
#50
2013 30' Classic
Greenwood
, Mississippi
After reading this post, I will no longer twist the chains.
I decided the "key rings" on the chains are to take up slack, just as a "zip strip"/cable tie would do. They also make a product called a chain keeper to take up slack.
I learned incorrectly to twist the chains. I relearned correctly how to take up slack-
TAC #MS-10
Airforums #70955
08-14-2015, 09:34 PM
#51
2015 30' FB FC Bunk
Ayer
, Massachusetts
Take a good look at the loop welded to the frame of the Airstream to which the chains are attached. Does not look like it could hold a run away trailer on the highway, looks like it is strong enought to control the trailer if it rolls away at the campground before you have the wheels chocked but not much more.
08-14-2015, 09:46 PM
#52
1987 Avion 34W owner
Good Ol'
, USA
Good point!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
08-18-2015, 09:29 AM
#53
1995 30' Excella
Bowie
, Maryland
All the chains have to do is keep the trailer relatively close to the tow vehicle so the electrical connection stays in, so you can hit the brakes and have it stop. They're plenty strong enough for that purpose.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
10-25-2015, 08:40 PM
#54
1989 32' Excella
Sharon Springs
, New York
Just a thought on the twisting issue, I agree it may weaken the chain(not sure how much) but couldn't you have a higher rated chain (12,000 lbs) used on your 7,000 lb TT and be safe even if you twist it? I had a TT not properly seated on the hitch ball disconnect and my twisted chains held (my jack wasn't happy though). Fortunately I was only going 40 mph, but I learned to check hitch ball seating for sure. I'm buying new chains for my AS since the ones on it are "1980s era" and thought that heavier chains would be in order since I planned on twisting them to adjust the length.
James
10-26-2015, 09:08 AM
#55
TinCan
2016 30' Classic
Apache Junction
Camping World also sells a rubber thing that you slide over the ball and has two slots for taking up excess chain. Works quite well.
TinCan
10-26-2015, 11:32 AM
#56
2013 30' Classic
Greenwood
, Mississippi
Look at post #50.
Airstream put wire "key rings" to take up slack.
You may already have a drawer with key rings in it.
If not, they can be purchased at a locksmith shop for $1 each or less.
Why did it take me 3 years to notice the key rings and use them?
Maybe this thread caused me to realize the key rings were there, what their purpose was, and to use them.
Works great.
TAC #MS-10
Airforums #70955
