Old 10-17-2011, 07:26 AM   #1
2012 23' FB International
Grayson , Georgia
Problems with maiden voyage
Hi all-- Left the lot on Friday with no squeaks. By Saturday our hitch was squeaking quite loudly when we slowed down, especially on turns. Is this a breaking-in period or a severe issue?
politicurl is offline   Reply With Quote
Old 10-17-2011, 07:33 AM   #2
Gainesville , Florida
What brand of hitch? Some just make noise. jim
Old 10-18-2011, 11:03 AM   #3
Mojave's Avatar
2011 16' Sport
Tofino , British Columbia
Ours sometimes makes noise as well. Everything looks normal so we also just assumed what zigzagguzzi said, that some just make noise. It seems to be coming from the sway bar.
Mojave is offline   Reply With Quote
Old 10-18-2011, 01:32 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If it is a twin cam Reese, the noise may be coming from the cams and followers. I would put a little Vasoline on them. It quiets them down but does not reduce the coefficient of friction that much. Reducing the coefficient of friction will decrease the hitches ability to dampen any sway by dissipating the energy into heat.
Old 10-18-2011, 01:48 PM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Did You Lube the Ball?
All hitches (Except perhaps the Hensley Arrow) want a couple drops of "On-the-Ball" hitch lube each time you hitch up. Don't over lubricate. Clean the dirt and grime off the ball with a rag or paper towel before you apply the lube.
Reese advises no lubrication at all on the cams of the dual-cam sway control hitch, but like dwightdi advises you may find a lube that eliminates the noise but won't compromise the hitch design. I found a heavy drill-bit wax worked well.
Back to the hitch ball itself, "On-the-Ball" by Reese comes in its own plastic-applicator bottle. A bottle will last for years for most of us.
Equalizer Brand hitches want lube on the hitch ball, where the bars rest in their brackets, and where the bar sockets meet the hitch assembly.
Each hitch set up has different lubrication requirements that you haven't complied with yet. There is no break-in period. What you are hearing are the protestations of an un lubricated hitch.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-19-2011, 10:03 AM   #6
Grayson , Georgia
Thanks for the great advice.
Argosy maiden voyage. shortcake All Argosy Trailers 18 09-29-2011 10:33 AM
Maiden Voyage EricktheSOB Vintage Kin 4 07-19-2011 09:34 PM
Maiden Voyage Chaco Culture NHP JamuJoe On The Road... 10 06-07-2011 08:51 PM
Maiden Voyage Khulse On The Road... 2 03-24-2011 10:13 PM
Maiden Voyage Successful! LawChick On The Road... 7 03-15-2011 02:31 AM
