Old 05-03-2009, 10:03 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Pro Series SC WDH, comments please
I am looking at getting this set up etrailer.com/pc-WD2~49578.htm or going with a Reese 66065 and adding the dual cam when funds allow it.
Would appreciate your comments on the Pro Series SC WDH
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 05-04-2009, 01:33 AM   #2
Images: 59
It looks like you're within $100 of the cost of a Strait-Line setup. I would go ahead and spend the extra bucks now. The Pro Series is a friction sway control, with the difference being you can't adjust the friction like you can with a bar-type sway control
The amount of friction will depend only on the tilt of the head. Interesting they didn't address that in the video.
Another thing I don't care for is needing to jack the tongue all the way up and down to set the bars. It looks like a lot of cranking. There's no "snap-up lever" like on the Equal-i-zer type hitches.
Reese Pro Series SC WD/Sway control tetstream Hitches, Couplers & Balls 3 06-28-2011 09:20 PM
WDH spring bar Grease Caps FreshAir Hitches, Couplers & Balls 7 02-19-2008 03:54 PM
Pro Series Hitch manufacturer????? crispyboy Hitches, Couplers & Balls 2 06-21-2007 12:58 AM
Newbie WDH question/advice myoung Hitches, Couplers & Balls 41 01-09-2006 10:12 AM
