Old 10-19-2010, 08:28 PM   #1
1965 28' Ambassador
Malta , New York
Pro Series 600 lb tongue Weight?? Looking for some help
Found a 1965 Ambassador picking up Saturday. Wanted to know if I can use the weight distribution hitch that I bought for my Jayco trailer or is there a better choice for Airstreams. My current distribution hitch is a Pro Series 600 lb weight distribution hitch. Not sure if it makes a difference. All I know is I want to prevent it from being beaten apart as I travel down the road without enough give in the supension of my 2007 Toyota Tacoma Tow vehicle. Interested in everyones thoughts on the subject
Airstreamdmb is offline   Reply With Quote
Old 10-21-2010, 04:22 AM   #2
Airstreamer67's Avatar
I would try out the new trailer with your present hitch and see how it does. The 600-pound weight-distribution bars would seem to be OK, depending on the capabilities of your tow vehicle.
Bars of this size work well for many people. They may technically be a little light for your tongue weight (but I don't know what your trailer's tongue weigh is), but they probably transfer enough weight to get you in the ballpark for your tow vehicle (but I don't know what the capabilities of your tow vehicle is).
Make sure that you have a sway-control system installed too. I have a friction sway-control bar on each side of my hitch which work quite well for me.
Airstreamer67 is offline   Reply With Quote
Old 10-21-2010, 06:04 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I was informed that for my 71 Overlander that weight bars between 600 and 800 pounds would be fine. IMHO, since Airstream's like a soft touch, I would think the 600 bars would be a good combination in your case. I am sure, as others chime in, you will get a multitude of information.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 10-23-2010, 06:48 PM   #4
1965 28' Ambassador
Malta , New York
I see some people suggest sway bars too. are these recommended in addition to
weight distribution bars?
Old 10-23-2010, 08:52 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Airstreamdmb!
The specifications listed for the hitch that you are considering indicate that it has built-in sway control. I approach my sway control (Reese Strait-Line with Dual Cam Sway Control) as a standard part of my safety equipment. Your trailer/tow vehicle combination would likely benefit from a hitch with built-in sway control.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-24-2010, 04:50 AM   #6
1965 28' Ambassador
Malta , New York
link
do you have any link you can post that would be the hitch combination you recommend in your previous post. Thanks so much for contributing. Much appreciated. Steph.
Reese Pro Series SC WD/Sway control tetstream Hitches, Couplers & Balls 3 06-28-2011 09:20 PM
600 Series Dometic Penguin A/C #600315.421 kentuvman Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-07-2010 08:36 PM
Pro Series SC WDH, comments please bmklawt Hitches, Couplers & Balls 1 05-04-2009 01:33 AM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Pro Series Hitch manufacturer????? crispyboy Hitches, Couplers & Balls 2 06-21-2007 12:58 AM
