Old 03-16-2012, 10:19 AM   #1
2005 30' Classic S/O
la mesa , California
Pro Pride or Hensley with F350 4X4 Crew Cab
Am considering one of the two hitches. I tow a 30' Classic Limited Slide. Which hitch do you recommend and what weight torsion bars? Any help would be appreciated. Don't want to tear apart trailer!
vetdr is offline   Reply With Quote
Old 03-16-2012, 10:35 AM   #2
Both of those hitches are good products.
However, the smallest bar rating they have, will be extra heavy duty, in your case, because you already have a super heavy duty tow vehicle.
At best, a Reese dual cam 800 pound hitch would do a very good job for you.
Old 03-16-2012, 10:44 AM   #3
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
A 600# bar would be extra heavy duty? Really?
vetdr - there are plenty of customers who have towed with both. Check out this thread - http://www.airforums.com/forums/f464...ide-57179.html
Also, there are reviews on the 3P product page from customers who have had the Arrow and the 3P.
Finally, there is a ProPride Blog post from a customer with a 28' Airstream and an F150 who has had both the Arrow and the 3P.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 03-16-2012, 10:48 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Look up contributor 2Airishuman's detailed thread on the ProPride and enjoy the long read. He switched from an Arrow (as will I) since the design improvements distinctly affect WD adjustments. (There will also be a benefit to reading his earlier thread -- "CAT Scale" -- to see how some of the discussions/arguments around hitch rigging for an A/S are formed).
You'll also want to read his comments about the Ford brake control system as it actually works, plus one would be well-advised to read on trailer disc brakes from this contributor.
That's a trailer with a heavy TW, IIRC, so the preparation to make a VPP hitch work best also coincides with best WD adjustments (as with any hitch).
http://www.airforums.com/forums/f463...ams-72455.html
Old 03-16-2012, 10:49 AM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Bear in mind those bars will transfer UP TO the weight specified. You don't need to crank 'em down until they scream for mercy to get the effect you need.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 03-16-2012, 10:56 AM   #6
SteveH's Avatar
Common Sense , Texas
vetdr,
Although not exactly the rig you have, I do have a simular rig and towing with a ProPride hitch and am totally happy with the setup. I have a '10 31' Classic and a 3/4 ton GMC Crew Cab pickup, and using the 1000 pound bars.
I would suggest to you to use whatever bars are recommended to you by the manufacturer of the hitch you decide to purchase.
Old 03-16-2012, 11:05 AM   #7
dznf0g's Avatar
Oswego , Illinois
Can you verify that? I have asked 2 different hitch manufacturers whether their ratings mean:
1) the bars (pair) are capable of rated force being applied to the bar before overloading the bar.
2) will handle a trailer tongue weight at the rated figure per pair.
There is a big difference in the two in our never ending question of proper bar "stiffness".
Neither could answer the question.
Sean, I never asked you.....what say you?
-Rich-
Old 03-16-2012, 11:28 AM   #8
ProPride, Inc.
The bars are rated as a pair. They are capable of distributing weight UP TO that tongue weight rating.
A 1000# rated system does not distribute 1000#. If the tow vehicle steer axle is unloaded by 400# you will not be able to replace that weight with an 800# or 600# bar.
The 3P and Arrow hitch WILL handle the tongue weight at the rated bar. They "may" handle the tongue weight at a lower rated bar but the bars WILL have to be jacked up more than the properly rated bar.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 03-16-2012, 11:35 AM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It's all about using a certified weight scale, and not relying on guessing. Once hitched well (and tire pressures perfected; plus aligned & balanced wheels/tires) then questions about weight bar rating take on their import.
Stay with recommendations on how to do it (manufacturer) and then work with the more experienced around here to get it the way you want it. Experience with ones rig means records, and records means numbers. Floundering around (lack of hitch rigging numbers) is just a prescription for headaches.
Old 03-16-2012, 11:39 AM   #10
dznf0g's Avatar
Oswego , Illinois
This still really bugs me!
So a pair of 1000# bars are capable of distributing 1000#s? Also, why then, do we continue to see recommendations for 1400# bars for a trailer rated at 1000# tongue weight max?
Seems to be inconsistent rating methodology among manufacturers. My 800# Reese bars "handle" my 1000# rated tongue load max, just fine, and with room to spare. They're only flexed about 1.5" with a proper WD per scales.
Paragraph 3 contradicts paragraph 2
This is the same unclear answers I got from Reese and Eq. Why no industry standard and test methodology. No two mfrs bars which carry the same rating, behave anything alike on the same rig.
I have now tried EQ (1000#) and Reese (800#) and soon will try Hensley (not sure what bars...bought used...pick up tomorrow)
-Rich-
Old 03-16-2012, 11:47 AM   #11
ProPride, Inc.
I'm with you... once I read it -
NO a 1000# bar DOES NOT distribute 1000#. If the tongue weight is 1000# it will distribute enough weight to reload the front axle of the tow vehicle. That may only be 300#. I've never completely maxed out a bar and weighed the front axle because that isn't realistic. I don't think I'd be able to get more than 400-500# of a 1000# tongue weight shifted to the front axle with a 1000# bar.
It would probably REALLY bother you to know that the same bars I purchase and rate at 1000# are sold rated at 1200# by two other brands. Same bar. Same bar manufacturer.
But, don't REALLY let it bother you. Just get the front axle loaded properly with whichever bar you need to do that with your tow vehicle.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 03-16-2012, 11:52 AM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
. . get the front axle loaded properly with whichever bar you need to do that with your tow vehicle.
Just the facts, ma'am (certified scale readings)
Old 03-16-2012, 12:18 PM   #13
dznf0g's Avatar
Oswego , Illinois
Well, that goes without saying....BUT....getting the flexibility and ride characteristics WITH proper WD per scales is heavily dependent upon bar selection within a particular manufacturer and is not consistent among manufacturers. That's my only point. I just get tired of having to guess..and buying more bars.
We otta have a swap area for stuff like that on the forum.
-Rich-
Old 03-16-2012, 12:24 PM   #14
SteveH's Avatar
Thumbs up
Oh no! Now you are insinuating that different manufacturer/style of bars distribute different amounts of weight????? And then, possibly some are more flexible than others???????? Oh the horror!
I do like the swap area idea.
newbie with a tow question echo44 Tow Vehicles 47 06-12-2013 04:42 PM
New LED light kit with sealed lights Dan@LED4RV Commercial Listings 18 08-26-2012 11:18 PM
Looking for 1967 or 1968 Safari if Anyone Sees One, Thank you! Mary Burris 1966 - 1968 Safari 5 04-27-2012 04:38 PM
Need advice before buying a Sovereign with water damage emanboulay Trailer Values 17 03-14-2012 01:48 PM
Questions about towing a 25FB with a F-150 barrettjl Towing, Tow Vehicles & Hitches 32 03-13-2012 11:13 PM
