Old 09-03-2017, 03:46 PM   #29
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Originally Posted by Llando88 View Post
Yep: Cheap insulation for the cable rubbing on the front edge of the PP yoke.
Love-it
Another good use for the P N.
Keeps the trash out.
Name:	LET'S KEEP THE CRAP OUT 008.jpg
ID:	293953   Click image for larger version
Name:	LET'S KEEP THE CRAP OUT 005.jpg
OOP's .....
"I'm a confirmed beginner in just about everything that other folks are expert in...."
RLC
Old 09-03-2017, 05:22 PM   #30
FishByFly's Avatar
2005 30' Safari
Oak Park , Illinois
Bob, is that white spray paint? I was thinking something a bit reflective would help. Have you put a white stripe on the top of your "stinger?" That would complete the image in the backing camera.
FishByFly
because I catch fish on a fly...
2005 30' Safari Bunkhouse
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 09-04-2017, 05:12 AM   #31
Titusville , Florida
Bob Cross. I am loving your fixes. Gonna have to steal your ideas. Thanks for posting and for the photos. Totally cool.
Lauri
kendrick.l.j is online now   Reply With Quote
Old 09-04-2017, 08:18 AM   #32
Thumbs up
TYVM......
Here's another tip for the "Classic" you may find helpful.
The lip on the battery compartment is a real PITA when it comes time to remove a battery, (esp the Lifeline AGM's).....this helps a lot.
Strap attached to the back side, running underneath, held up out of the way with velcro until needed.
ID:	293984   Click image for larger version
ID:	293986   Click image for larger version
OOP's .....
RLC
Old 09-04-2017, 04:41 PM   #33
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
Originally Posted by Pat Cassity View Post
After three years of towing our 27' FB international, we are starting to get the Moho itch. But for what may be for a somewhat different reason than for others. We are the type of Airstreamers that prefer to go to one (and not more than two) final destinations and camp for 7 to 10 days. Enroute to these destinations we will stop for the night and not unhitch. Sometimes we arrive early enough in the afternoon that we would like to take in some of the sites and maybe a local restaurant. However, we really dislike the unhitching and rehitching each day before arriving to our final destination. So, we frequently miss out on the local sites and restaurants. I currently have a Blue Ox hitch. My question. Other than the obvious advantages of the Pro Pride and Hensley, is the process of unhitching and rehitching the next day an easier or at least, a less tedious process? So much so that unhitching, each evening isn't such an ordeal?
Back to the original question. (But Mr. Cross I do like your idea about making it easier to get the batteries out of those holes.) I can't compare a Hensley or ProPride to other hitches as I have had my Hensley for 8 years. But it only takes a few minutes to hook up or unhook the Airstream and we do it all the time, even for one night stays. And if you were in a motorhome, you would have to unhook your toad in order to go to any local restaurants or local attractions, wouldn't you? So what is the difference? Or maybe you were not looking at towing a vehicle behind the moho?
TSchleff is offline   Reply With Quote
Old 09-04-2017, 04:50 PM   #34
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Good point T! Unhitching and hitching a toad would probably take just as long!
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 09-04-2017, 05:57 PM   #35
2018 28' Tommy Bahama
Silver City , New Mexico
I had a ProPride on a SOB. (BTW, the ProPride is an embellished Hensley. Old man Hensley sold the Hensley-hitch company but, kept the patents and knowledge of inherent 'problems' and became the key designer of the current ProPride hitch.)
I found that it was a 'piece of cake' to unhitch but, hitching was like trying to do a turbulent in-air refueling at 500 knots...or threading a needle without seeing it. There are lots of tips and tricks to getting the stinger aligned and practice makes it easier. My wife insisted that she could do it nearly every time. She would move the TV closer to 'alignment' by one or two foot increments. Hop out - take a look - hop back in the TV - make corrections as necessary - move back another foot or so - and repeat the process until the stinger was in its' nest. Did I say this process took awhile and a bushel of patience?
The ProPride is an excellent hitch - an almost perfect eliminator of sway - all at a steep price. If you can afford it, I'd recommend you go for it - otherwise, the Equalizer 4 hitch does a very nice job for a lot less moola.
Just my dime - which still makes a pretty good screwdriver.
If it ain't broke I can fix it
journeydog is offline   Reply With Quote
Old 09-05-2017, 07:17 AM   #36
1996 25' Excella
Tillsonburg , Ontario
That was how I did it...usually only took a couple of repeats but then there are days....
Still do the same thing with my Easy Lift because now I'm single handing it!
JCW
JCWDCW is offline   Reply With Quote
Old 09-05-2017, 09:01 AM   #37
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
In my mind a Hensley or ProPride would be about the same number of steps/same level of difficulty to couple or uncouple as my Equal-i-zer Original 4-point Sway control hitch, which is easier/less steps than the EazLift I had before.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-05-2017, 10:41 AM   #38
NCMEDIC's Avatar
2010 27' FB Classic
LINCOLNTON , North Carolina
Here's how I made it easier for myself. It was hard at first trying to visualize the angle between the stinger and the receiver. This makes it much easier to get in the ballpark and then I fine tune the connection at the end.
http://www.airforums.com/forums/f464...id-171968.html
NCMEDIC is offline   Reply With Quote
Old 09-20-2017, 09:08 AM   #39
Springtown , Texas
I got my Hensley to tame a unruly SOB trailer and short wheel base tow vehicle.
I dreaded the hookup from reading stories on the web but quickly found they are unwarranted if you have some tools.
The #1 tool is backup camera. This is paramount and you will kick yourself so much for not getting one sooner.
#2 is cordless drill for the jacks.
These two make hitching/unhitching effortless.
I find this hitching to be as easy or easier than my Equalizer and without the drama of latching the weight bars.
I don't doubt there are certain situations where the TV and trailer angles are going to be extreme which might cause some issues but so far no problems.
CarterKraft is offline   Reply With Quote
Old 09-21-2017, 12:03 PM   #40
T , Oklahoma
Toad?
David Briggs
Ebb - '15 F-150 Lariat
3.6L Turbocharged w/ 6 speed
3.31 Diff. and Tow Package
Flo - '12 AS International Serenity M-30'
Dlbriggs is offline   Reply With Quote
Old 09-21-2017, 12:24 PM   #41
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Originally Posted by Dlbriggs View Post
Toad?
That one took me a while, too. Slang for "towed"--as in the small vehicle being towed behind a motorhome.
DaveMc is offline   Reply With Quote
Old 09-21-2017, 04:55 PM   #42
T , Oklahoma
Yep. Thanks!
David Briggs
Pro pride or Hensley? (humor) FCStreamer Fun & Games 2 09-16-2016 09:35 PM
Hensley - Pro Pride sales & deals 369goose Towing, Tow Vehicles & Hitches 20 11-27-2015 11:09 AM
Pro-pride (Hensley) Hitch for sale Schilling Airstream Classifieds 0 06-06-2014 08:56 AM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
