Old 10-17-2019, 08:55 PM   #1
2017 23' Flying Cloud
Bartlett , Tennessee
One reason I won't let my dealer touch my Airstream
This is one reason why I don’t trust my RV dealer. It was Southaven RV in Southaven, MS. I bought my trailer new and they said they would install a weight distribution hitch as part of the deal. I had them install a Reese Strait-Line hitch with Dual Cam Sway Control. That was 3 seasons and 11,500 miles ago. A couple of days ago, I pulled into a campground in Canada, 1,500 miles from home, and found this. (Narrative continued below the picture.)
Reese specs vs their install:
Bolts 1/2” x 1.5” – used 5/16” x 1”
Grade 5 – used grade 1
Lock washer – nope
Rivet nut – nope, drilled holes and used self threading bolts
Bolt on the backside of other trailer side was tight and had jam nut tight. This side, bolt loose, jam nut halfway up bolt.
I avoided disaster here. One bolt was gone, the other was about 1/4” out from the bracket. Both holes in the frame were stripped out.
I had to drill the holes out and tap them for 3/8” bolts. I did use 3/8” x 1.5” grade 5 bolts and lock washers and tightened the bolt on the back side and tightened jam jut. This was just a temporary fix to get me home. Once home, I will re-do them both to Reese specs.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 10-17-2019, 09:53 PM   #2
2007 27' Safari FB SE
Forest Grove , Oregon
I feel your pain. I can show you pictures of where a prominent Airstream dealer in New Jersey, who many love for their low prices and are so friendly if you are buying a trailer, drilled multiple holes, and still has my passenger side one inch off of where the drivers side bracket is mounted (and no lock washers, rivet nuts, etc. .... nothing to show that they followed the mfg instructions to mount, etc.) but charged me big bucks to install. Now that I am done ranting about the so called wonder dealer in the east.
I had the same issue caused from their install twice in the last 4 years. First time fixed with a higher grade bolt. Now this fall found the bolt holes had elongated so had to get helicorts with some creative work to install because the walls of the frame tubing are so thin. Basically you have to helicort in a bolt and go with a half inch bolt or you push the helicort out (did that twice before I got a little bit of smarts.)
Haven't towed since then so I can't let you know if my fixing the experts fix has worked.
Stupid me to think that dealers you are paying money to do work wouldn't use lock washers, rivet nuts, etc. (per the install instructions which I have checked) and locktight on the bolts..... At least yours are the same distance from the hitch?
What is interesting to me is that on both our trailers it is the passenger side where the failure occurs. I wonder what is going on to put more stress or vibration to loosen the bolts on that side? The drivers side bolts even with the questionable installation are not coming loose. So maybe someone with more smart than me can enlighten me on that question?
bweybright is offline   Reply With Quote
Old 10-17-2019, 10:30 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Your best fix maybe to weld up the holes and re-drill them.
Old 10-17-2019, 11:13 PM   #4
Exactly where I am heading...if my solution doesn't fix it.
Quite honestly that would have been my preferred solution but I don't know how to find a qualified welder who understands Airstreams where I live right now. Nor do I know the right questions to ask ask a welder to determine if I would let them do the work.
So if you have insights to help me to know what to ask and look for it would be appreciated.
Old 10-17-2019, 11:44 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Try this place, outside of Salem, OR.
https://www.shinyshacks.com/
Bill
Just my personal opinion
Old 10-18-2019, 02:39 AM   #6
2016 30' Classic
Lorton , Virginia
lol "Dealers". Glorified salesman holding areas with a couple of high school drop outs drilling holes in your trailer out back.
I wouldn't let any of these idiots touch my trailer with a ten foot pole. The American service industry is an absolute disaster.
Zybane is offline   Reply With Quote
Old 10-18-2019, 10:34 AM   #7
2010 19' Flying Cloud
2020 25' Globetrotter
Fayettville , Georgia
I have a new 25’ GT ordered from Beth at RVOne in Tampa and they are installing a new Stabilizer Hitch for me.
I’ve been very impressed with them so far but I will keep everyone posted.
Mike1948 is offline   Reply With Quote
Old 10-18-2019, 10:40 AM   #8
Bill
Thanks for the lead. Will keep them in mind if my repair doesn't hold.
Old 10-18-2019, 11:05 AM   #9
2003 22' International CCD
East Durham , New York
bad dealers
Feel your pain also. That unnamed NJ dealer did quite a number on my rig a few years back. Burned holes in my dinette seat, left off bolts, and ultimately did not make the initital repair. Once discovered the mess didn't offer refund or apology.
DIY from now on.
bluvalley is offline   Reply With Quote
Old 10-18-2019, 11:11 AM   #10
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
WOW the Reese system is a great system and we love it - makes me want to double check it (dealer installed)
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 10-18-2019, 11:11 AM   #11
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
DIY from now on.
I must express some surprise since I have been on this forum for over 6 years and that is the very first comment like that I have seen about your unnamed dealer in New Jersey. As you are well aware, there are many, many comments praising them.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-18-2019, 11:26 AM   #12
rideair's Avatar
Please understand, I'm not trying to defend poor workmanship, but do try to remember one thing. The person working on your trailer and who built your trailer, (my guess) earns between $15.00-$20.00 and hour or a yearly income of $30,000-$40,000 and at that income level, (most likely) would never be able to purchase new the very trailers of which they build and service. Though you maybe paying the dealer $100-$120 an hour or more, the guy doing the work doesn't get paid that, and you know it.
Yes, most likely they are, as someone said "high school dropouts" or at best, education level of high school only, maybe trade school if they are lucky. You don't see many folks with 4-year degrees lining up at the local factory or service center for a job.
If you don't like the quality of work, I'd suggest either doing it yourself in the first place, or employee a top-notch craftsman personally and pay tem twice/three times as much to have the work done correctly.
If nothing else, you could always hire someone out of college that has a degree in gender studies with a man-bun to do it for you. My guess, it will still be crappy work, but at least they'll have a degree.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 10-18-2019, 12:00 PM   #13
Mollysdad's Avatar
We'd all like to believe the dealer has highly trained experts who graduated from the Airstream master mechanic class.
One step below NASA.
In reality, these guys are under pressure to work quickly, be able to work on everything from a Prevost electrical system to a Airstream Bambi's plumbing, and work for not a lot of money.
I guarantee you know more about your trailer than they do, not to fault them, but you only have one trailer to memorize.
Maybe the mechanic read the directions, asked his supervisor where they kept the grade 5 bolts, and was told, "Just use self tapping, it will be fine. I've got a motorhome slide waiting for you next."
Know those clips we all use to prevent our euro hinges from falling apart? I took one to my service manager, he showed it to his techs, including the "Airstream expert" and nobody had a clue what it was. So I sent photos so if they care, now they know.
Old 10-18-2019, 12:08 PM   #14
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I think I see something seriously wrong with this installation, other than the obvious. You should not have had to drill out the holes and tap them. There should be a Rivet Nut installed into the holes in the frame that the 1/2" bolts thread into to secure the bracket to the frame.
Name:	Annotation 2019-10-18 110309.jpg
thewarden is offline   Reply With Quote
Old 10-18-2019, 12:08 PM   #15
My comment is actually the second on this short thread about that dealer. We can't all have perfect experiences.
Old 10-18-2019, 12:50 PM   #16
2017 16' Sport
Canyon Country , California
Go to NASA repair shop in FL?
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 10-18-2019, 01:47 PM   #17
2006 28' International CCD
Saint Paul , Minnesota
Hensley installed incorrectly by dealer in 05 (Shorewood RV, Anoka MN). Reinstalled by Hensley factory in Romeo MI year later. Amazing how badly the dealer had screwed up, COMPLETELY! Hensley, and many other factories, have Technical Support lines which can guide you as you or another facility install your hitch. The help line's assistance is invaluable and have used them for tweaks and tune ups many times. Oh, and 200k miles on the hitch, pricey hitch but it works perfectly, 15 rt's ME to AK.
Mhphhoward is offline   Reply With Quote
Old 10-18-2019, 02:17 PM   #18
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
With almost any WD hitch, there's also an anti-sway component. On surface streets/roads in the US and Canada, right turns are generally far sharper than left turns which creates tremendous forces on the anti-sway components on the right side (curbside or passenger side) of the trailer.
The Ice Man is offline   Reply With Quote
Old 10-18-2019, 03:01 PM   #19
Makes sense. Thanks for clarifying.
Old 10-18-2019, 03:26 PM   #20
1993 21' Sovereign
SILVERDALE , Washington
Thumbs down Dealers fault, really?
This is why you should not pull your airstream without checking conditions end to end . Or you could just be lazy and blame it on your dealer. Really???
ELKHUNTER is offline   Reply With Quote
Gray Touch-up Paint Won't Dry OB Bambi Clearcoat, Exterior Paint & Trim 14 12-15-2015 08:20 PM
One Reason Why I Bought My Airstream ! Safari-Rick Off Topic Forum 17 02-29-2008 08:46 PM
One PC won't let me in! Astrodokk Forum Admin, News and Member Account Info 6 04-04-2004 09:37 PM
