Old 11-15-2007, 09:33 AM   #29
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Ahh! I had not realized the weight distribution on the GMC's MoHo's was distributed as it is. Thanks for the info.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 11-15-2007, 11:25 AM   #30
_
yea the rears are tandem not dually
i don't wanna get the whole...
'what is torque steering and what causes it'
debate going...
certainly equal length half shaft axles will reduce it significantly,
but t.s. is more about tires/contact patch/steering angles and stuff...
so with so much hp/torque and fwd and funcky side wall treads...
t.s. (quiver) oscillation still happens, as weight shifts and grip changes.
willy
2air'
also static loads change with acceleration,
so that weight over the axles shifts rearward in dynamic situations...
pulling the wagon up hill vs pushing, and all that blah, blah...
ID:	49371   Click image for larger version
Old 11-16-2007, 03:16 AM   #31
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
L.o.c.
Heres a couple of links about the GMC.
Lots of good facts so no need to use imagination.
Reading into topics, some change the Olds for a 500 Caddy.
And the prototypes used stock Toro/Eldo rims and quickly tore them apart.
Interesting that the designer insisted on curved sides, when he saw the first few coming down the line with flat sides he halted production, went straight to management and you see today that none are flat.
GMC Motorhome FAQ
GMC Motorhomes - Cruising America
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 06-07-2008, 11:27 AM   #32
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Custom A/S MOHO
Check this out. The answer to all TV issues, a custom A/S MOHO.
http://www.rvtravel.com/blog/weirdrv...er2-710204.jpg
Gene
Old 06-07-2008, 11:00 PM   #33
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Gene
Two words...Butt ugly.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-08-2008, 01:40 AM   #34
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
The old GMC mohos were a cool idea, and actually share a lot of Airstream design cues. The low floor, semi-rounded shape, and front end profile are all similar to an AS. I've been involved in a complete drivetrain rebuild on one, and the Toronado drivetrain was actually its fatal flaw. The Toronado wheel bearing setup doesn't handle the weight of the big moho very well, and they wear out quickly. It's also absolutely miserable to drive in low traction situations. However, on dry pavement, the low center of gravity makes it handle more like a full-size van than a motor home. The ride from the airbag rear suspension is also smooth as silk. It's unfortunate that GM killed it off after the first generation were built. Would be interesting to see where the engineers would have taken it after working out the known problems that they had.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Anyone have a pic of the Toronado using WD? Xray Hitches, Couplers & Balls 9 12-31-2012 01:42 PM
Toronado/Airstream Mike Leary Off Topic Forum 12 10-31-2011 10:22 AM
