Old 03-23-2015, 07:59 AM   #1
1971 31' Sovereign
Indian Wells , California
Old style saddle cam spring bar question
I have the old style saddle cam setup but I'm missing the spring bars and a few other parts. I'm watching ebay for some to come up for sale.
I saved an article about different bars and I read about how to set the system up but I haven't found anything telling my how to match the right size bars with the tow vehicle. It seems the tighter the TV suspension, the lighter sprung bars are needed and vice versa.
Can someone tell me how to figure out what size to look for? I have a 2015 Silverado 1500 with the max trailer tow package (up to 11,000 lbs. towing)
Thanks.
CraigCA is offline   Reply With Quote
Old 03-23-2015, 09:00 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile saddles
Thanks.
Need to no what manf of spring bars & parts needed, also weight of trailer. Reese 1 inch bar with cam follower 550 lb. rating. 1-1/8= 750 1-1/4= 1000, cam follower is what sits on saddles, as to what size you need, Andy says 1 inch bow in bar when hooked up, but I do not no what size you need. Also if Reese old style dual cam better than new style as break point at threads new style weak point.
Old 03-23-2015, 09:44 AM   #3
1971 31' Sovereign
I'm looking for Reese bars.
I think I probably need the 1" or 1 1/8" bars. I should look for both and then see which one works best and sell the other pair.
There must be quite a bit of latitude in bar selection since there are only 3 different sizes. My truck isn't sprung as light as a passenger car and not as tight as a 2500 or 3500 truck.
Old 03-23-2015, 09:58 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When the trunnion on my older Reese torsion bars broke, I was able to get replacement ones from etrailer.com - So if you know what you need, calling them may provide you with the answer. Their shipping policy is nice - free shipping for orders over $50.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-23-2015, 10:08 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The bar size is determined by the weight of the trailer. You need 800 lbs bars.
It is hard to buy used bars unless the seller gives a good picture of the trunnions as they wear over time and effect the adjustment. Also you should inspect the trunnions cups on the head before spending money to complete the set. They wear also.
The most important thin to remember when using saddle type bars is to mark the bars as to which side they were set up for. They are not always the same length and crossing them can ADD to sway rather than dampen it.
2004 Excursion 4x4
Old 03-23-2015, 10:22 AM   #6
1971 31' Sovereign
Oh I thought the bars were sized to the TV and the trailer, not just the trailer. I don't have the head, just the part that bolts to the trailer frame. I need all the other stuff too. I was thinking about just buying a new system but from what I read, people like this old setup so I thought it was worth piecing it back together.
I thought these bars were NLA. I'll call eTrailer and see if they have them.
Old 03-23-2015, 10:52 AM   #7
HowieE's Avatar
Images: 12
If you are looking for bars and a head you are better off looking for a complete new system from a cost and condition standpoint.
2004 Excursion 4x4
Old 03-23-2015, 06:53 PM   #8
1971 31' Sovereign
That's what I thought. New Reese systems aren't that expensive.
Old 03-24-2015, 01:11 PM   #9
I have a chart that picks the correct bar size for Reese hitches. It covers from 600 to 1700 lbs. tongue weight. Send me an email; wa3vez@comcast.net .
Howard Lefkowitz is offline   Reply With Quote
Old 03-24-2015, 02:27 PM   #10
1976 31' Sovereign
Oswego , Illinois
Smile Reese bars
Could you post on forums the info from Reese chart of correct bars to use, as it would helpful info for a lot of people w/out emailing you & maybe rec. numerous emails.
Old 03-25-2015, 09:29 AM   #11
I would be happy too but I am not sure how to do it. When I click on the insert image it asks for the URL. I just have a .jpg.
Old 03-25-2015, 09:59 AM   #12
1967 26' Overlander
Richmond , Virginia
Go down to where it says attach files under additional options, then click manage attachments.
bobzdar is offline   Reply With Quote
Old 03-25-2015, 10:07 AM   #13
Here is the Reese Bar Chart.
Name:	Selecting Reese Bars..jpg
Old 03-25-2015, 12:11 PM   #14
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Reese suggests that the bar rating should match the trailer tongue weight. I have a set of 1200 pound (I think) bars that you can have for the cost of shipping them to you from Phoenix.
Old Style Sofa Vs New Style settee Opinions Needed Jim Clark General Interior Topics 3 01-23-2013 02:53 PM
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 07:43 PM
Old style Reese Dual cam help??? Pacerized Hitches, Couplers & Balls 18 04-24-2010 09:03 AM
old style brake conversion to new style Justmeandshe Brakes & Brake Controllers 1 06-23-2007 05:16 PM
