Old 04-14-2010, 09:16 PM   #1
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Old style Reese Dual cam help???
Last year I purchased a new Reese round bar hitch with the integrated cam WD bars that are made to add the dual cam system. I found a great deal on a new set of anti sway cams but they're the old style that requires U bolts to attach to the frame. The instruction sheet that came from Reese offers very poor instructions. I found the following link from Reese that is nothing but the same set of poor instructions. You can't even tell the right side from the left from the instructions. http://65.196.229.70/pdf/N26001.pdf
Anything else I've been able to find online only shows instructions for the new style dual cams which are considerably different. I've searched through the forum going back 15 pages to no avail. I think I have these figured out but I'd like to be certain. Does anyone else have the old style Dual cams (part 26001) installed and if so could you share some pictures? I'm specifically confused on how the bend in the WD bars ride on the cam arm. Any help would be greatly appreciated.
Thanks: Charlie
Pacerized is offline   Reply With Quote
Old 04-14-2010, 09:34 PM   #2
Ottawa , ON
Not sure what you're looking for here. The image in the attachment is how they work, but I will admit that they make it sound more complicated than it is.
Put it together as they describe, making adjustments so it fits well around your tanks etc on yout A frame, then adjust the stirrup so that it's vertical when all is put together.
I had to jack up the vehicle to be able to put the bars on, maybe that is your difficulty?
Sorry, no pics of that, and it's a ways from where I am now.
Old 04-14-2010, 09:46 PM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I think I have the instruction sheet for the Reese Old Style Dual Cam. This is what I run behind my F350. The bars are 1" square at the base,just behind the trunion. These are the 550 lb bars.I really think thats all you need. I run 6 chain links under tention and get a great ride.
I am not sure where those instructions are but I will look for them for you.
The system is easy assembled. Ubolts hold the brackets just to the rear of the coupler.The winch brackets are mounted on the A frame 1 on each side.The trunions go into the hitch head and the palm shaped hands are on the pads below the winches.
I hope Im about to find the diagram.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-14-2010, 09:57 PM   #4
Ottawa , ON
ps: you say you can't tell right from left from the instructions: there is a picture of one cam arm that's clearly labelled "right hand". That's right hand when you are facing towards the tow vehicle, with your back to the trailer, of course.
There IS NO RIGHT OR LEFT to the BARS themselves. They are ambidextrous, to coin a phrase: either bar works on either side.
Now, my bars are the 1,000 lbs ones, I have a different set-up than Mike or you, my TV is a Ford Freestar, so more transfer is necessary.
Old 04-14-2010, 10:04 PM   #5
1977 27' Overlander
Trotwood , Ohio
Aage.
Would you believe I had never seen my F350 or the Airstream when I bought that set up. I really bought it for a 24 box trailer I never took delivery of.LONG STORY.
I'm not sure What a Free Star is, but Im sure it works for you. Every setup is an individual,seems to me,No 2 are setup alike, I know mine could not be more perfect.
Works for me.
Roger & MaryLou
___________________
KA8LMQ
Old 04-14-2010, 10:12 PM   #6
Ottawa , ON
OK, you made me remember that I DO have a photo that shows the hitch, from a distance though.
I wanted to show you the Freestar, its a van, Mike. You can sorta see the hitch, Pacerized. Blow it up a bit more if you like, that may help.
Here's a photo I took outside the Jackson Center service building:
Click on the photo to make it bigger, then click once more to see an even Bigger version.
Old 04-15-2010, 03:33 AM   #7
1976 25' Caravanner
Campton , New Hampshire
http://www.airforums.com/forums/f464...ies-62009.html
Some good pictures here. page 2 . One question , I thought the dual cam came with the square bars , you mention round bars? The curved end of the weight bar should fit centered on the dual cam saddle when the TV and trailer are in a straight line and the chain is perpendicular to the A frame.
ticki2 is offline   Reply With Quote
Old 04-15-2010, 03:57 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Interesting little article that may help you...
Tuning a Reese Hitch
Old 04-15-2010, 05:48 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I don't think the old style saddles can be used with the new style bars.
Old 04-15-2010, 07:21 AM   #10
Ottawa , ON
HOLD ON A SECOND: I need to clarify this, sorry, my feeble memory strikes again!
To be able to get the WD bars on, I had to raise the A frame using the Airstream's electric jack, after connecting the TT and the TV together.
It has to be raised to the point where it reduces the loading on the TV's suspension, i.e. raise the body of the tow vehicle somewhat.
At no point did I use a jack to raise the TV.
It's pretty clear how far you need to raise things when you do it. On my rig, the WD bars won't go on until the right height is acheived.
Sorry for the earlier fuzziness.
Old 04-15-2010, 09:39 PM   #11
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Thanks to everyone who replied. The info and links have been very helpful. My confusion was with the instructions not specifying which side of the cam head would face the bend in the WD bars. It seemed to make more sense that the curved part of the cam head would fit into the the curve of the WD bar. When I face the cams as shown in the instructions the flat part of the cam head actually fits against the WD bar instead. Upon reviewing this further and comparing to the pics in the link showing the airstream hook up with the trunion bars this now appears to make sense.
Regarding my using the old style cams with the new style WD bars, the instructions specify that this is o.k, I just don't need to use the bolt on adapters for the WD bars.
I think I have this figured out now so I'm going to attempt to install these on Sunday, wish me luck.
Charlie
Old 04-16-2010, 06:37 AM   #12
richinny's Avatar
2011 34' Classic
good luck! and remember that these things are under great pressure when loaded. watch for something snapping or shifting. keep your arms clear of the bar you use to hook up the chains that connect to the arms. if it flips down and hits your wrist, you may end up wearing a wrist cast ;-)
Ricky
Old 04-16-2010, 09:33 AM   #13
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Charlie!
Thanks: Charlie
I concur the Reese instructions for the classic Dual Cam installation are a bit sketchy. I was fortunate to have a friend who was able to point out the finer points of the installation. The photos below are of the installation on my Cadillac Eldorado/Minuet 6.0 Metre combination:
The photo above shows the relationship of the cam to saddle before the snap-up bracket is locked.
The photo above shows the relationship of the cam to saddle prior to raising the chain bracket.
The photo above shows all components connected ready to attach safety chains and raise the tongue jack.
I hope that these photos help to show the relationship about which you are inquiring.
Good luck with your installation!
Kevin
Kevin D. Allen
AIR #827
Old 04-16-2010, 10:04 PM   #14
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Those are excellent pictures Kevin. Thank for posting them. It appears that the shape of the saddle portion of the cam on yours is a little different then mine but the concept is the same. Perhaps the design changed in a final version of the old style cams before they were replaced by the new style cam. From what I can see I think I can get these on this Sun. in a short time. Then I only need to spend 20-30 hours adjusting the new setup so it rides as well as it did before I added the cams.
Charlie
new reese dual cam Bing-Bing Hitches, Couplers & Balls 11 05-27-2007 12:40 PM
Reese dual cam HP junbe Hitches, Couplers & Balls 12 04-07-2005 06:10 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
