Old 04-01-2009, 01:31 PM   #1
2010 27' FB Classic
N/A , Texas
Old Reese Replacement Parts
I'm looking for a couple of cast trunion ends for the spring bars on a 750# Reese set. The mgf. part number is 58030. New would be great, but slightly used is fine. I recently found a set of straight spring bars but the top and bottom knobs are badly worn so I need to replace the whole trunion end.
Old 04-01-2009, 01:42 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Will these work for you:
eBay Motors: USE REESE HITCH PARTS 2 BARS AND 2CLAMPS (item 370179286667 end time Apr-02-09 05:16:52 PDT)
Old 04-01-2009, 02:26 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Reese has about the poorest web site I have ever seen. However you can call the parent company TriMas Corporation @ 248-631-5450 and they will patch you through to Reese customer service.
The last set of trunnions I bought were $54.00.
If you get a new set try to oil them, a drop or 2, before each trip to make them last. Dry they will wear quite fast.
2004 Excursion 4x4
Old 04-01-2009, 03:58 PM   #4
2010 27' FB Classic
N/A , Texas
Ganglin, Thanks for trying but the person who is selling them doesn't have enough info to make a decision if they are the right set.
HowieE,
Thanks for the number. I called and found out that the part number was wrong. The part number I need is 22210. I couldn't get a price from Reese but at least they have them. I'll have to order thru a dealer so I don't know the prices yet. Just put out a couple of feelers and will see what comes back.
brake replacement parts watt1968 Brakes & Brake Controllers 5 07-03-2008 07:17 AM
Replacement Parts for Rockguard? tslanier Windows & Screens 2 07-15-2006 07:38 PM
Exterior replacement parts Kandy Ribs, Skins & Rivets 2 06-22-2006 09:40 AM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Replacement Reese hitch bar davidz71 Hitches, Couplers & Balls 11 02-20-2003 04:22 PM
