06-04-2015, 07:40 PM
2012 25' FB Flying Cloud
albany
, Georgia
Old cathedral door opening sound.
it would seem that I need to start lubricating the ball. When I turn into an area at low speed I am getting the old wooden creaking door sound. What lubrication grease do I need to use. It had a load on it when I started but has now diminished, messy bloody stuff. So what kind do I need to slap on there chaps.
Help Please.
06-04-2015, 07:49 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
That info would be located in the "lube my balls thread" ;o);o) honest not trying to be cheeky. Someone will post some actual lube info.;o)
Hittenstiehl
06-04-2015, 08:17 PM
Retired.
, At Large
Just slather some wheel bearing grease, or white lithium grease, on the ball. Whichever you use, clean the old stuff off before applying.
06-04-2015, 08:30 PM
2005 28' Safari S/O
Paradise
Steve
"THE OLDER I GET, THE BETTER I WAS"
06-04-2015, 10:08 PM
Help Please.
Are you using a weight distribution hitch? Creaking is common in these systems thus requiring lubrication on the pivot points as well as the ball.
William C. Swinney
06-05-2015, 10:31 AM
2013 30' Classic
Greenwood
, Mississippi
Help Please.
Old cathedral door? My back door at the house sounds like that.
I always liked the reference to the wreck of the Edmund Fitgerald or Titanic sinking.
What type of hitch?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-05-2015, 12:46 PM
albany
, Georgia
It is an Equal-I-zer. I have read the thread Steve, well some of it, thank you for sending it.
I bought a can of the Airstream grey paint earlier this year. Had some rust around the top of the ball housing, cleaned it all up and re painted. Looks like brand new again.
So I shall go and purchase myself some grease and figure a way of covering the ball up when not in use.
Thanks for the help chaps.
We just got a Mercedes ML350 Bluetec this week and I am obviously going to be adjusting the ball height as soon as we pick it up. My Tahoe is a lot higher than the Merc hitch. I have a huge socket wrench but not the socket, another purchase needs to be made.
06-05-2015, 12:53 PM
2006 30' Safari
Divide
Creaking Door
Having towed with an Equal-i-zer in the past, my guess is the sound you are hearing are the bars rubbing against the L-brackets. The metal to metal contact (according to the manufacturer) is the sound of the anti-sway working. You just don't hear it at speed and you aren't making sharp turns so it doesn't sustain the "creaking door" sound.
06-05-2015, 12:59 PM
2013 30' Classic
Greenwood
, Mississippi
Get Sway Jacket Brackets for the L-brackets. Then, grease the hitch head and ball liberally. Re-grease after every trip. No more wreck of the Edmund Fitzgerald.
errrrrr eeeeeee pop pop groooooooaaaan eeeee oooohhhh...
TAC #MS-10
Airforums #70955
06-05-2015, 09:30 PM
2010 27' FB Flying Cloud
Kansas
, Topeka
Cheap Ball Cover
I get a jug of milk at McDonald's with breakfast, toss the lid, slit one side of the jug and remove the label. Put a little wheel bearing grease in the bottom of the jug and put it upside down on the ball when not in use. Also makes a good white target while backing to hook up. Not to mention more visible than a black one and saves on the ol' shinny shin shins.
