Old 05-13-2013, 09:33 PM   #1
2013 28' International
Bozeman , Montana
Noisy Propride Hitch
So, I finally picked up our 28' International Signature a couple of weeks ago. The dealer installed and configured the hitch for me and I noticed a bit more bounce then I expected. The drive home, backing in the driveway, etc. was all fine and quite. This weekend I towed the trailer to a local truck stop after cranking up the WD jacks up further. When backing up and doing slow speed maneuvers there was a bit of loud creaking from the hitch. I would expect a bit of noise from other hitch designs but was pretty surprised with the Propride.
Is this normal to have some noise from the hitch?
HeadWest is offline   Reply With Quote
Old 05-13-2013, 10:34 PM   #2
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
Some creaking seems to be the norm...but do you have it "dialed in" correctly...not too much height on the jacks...is the weight on the TV front axle the same hitched and unhitched....have you greased the zerts? ( this should be done every 1000 miles or so) Zigi
Zigidachs is offline   Reply With Quote
Old 05-13-2013, 11:41 PM   #3
JFScheck's Avatar
Rockville , Maryland
Images: 33
What zerts on a ProPride?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-14-2013, 12:03 AM   #4
richinny's Avatar
2011 34' Classic
the weight distribution bars have a fittink where they pivot.
Ricky
Old 05-14-2013, 12:27 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I would check all of the mounting bolts to see if they need to be snugged up a bit and/or call Sean.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-14-2013, 04:18 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
HeadWest - the grease zerks are located just above the weight distribution bar heads (where they connect to the hitch head near the tow vehicle side). My dealer installed mine and I had some creaking after about 200 miles. Grease solved that. After about another 1000 miles I needed to do it again.
While I have zero sway, I have learned there is a sweet spot for me in terms of dialing down porpoising. How high up are your jacks? I've posted about several adjustments after going to the scales a few times and 5.5-6" seems to be the "Goldilocks" area for my set up. I haven't figured out how to link to a thread here but search for "at the scales" and the "unofficial PP user guide" threads for much more info.
Last - do you have the PDF of the installation/user guide or did the dealer give you the hard copy? That will help and it includes Sean's phone number. Call him for help - you won't be disappointed. My dealer missed something and Sean walked me through the fix by phone/photos....and helped me make the tweaks I needed to dial it all on properly, along with the amazing folks in this forum who responded publicly and privately to my thousands of questions.
A little tweaking - a lot of asking - you'll get it all dialed in!
SteveSueMac is online now   Reply With Quote
Old 05-14-2013, 08:33 AM   #7
Zigidachs's Avatar
2011 30' Classic
Sean advised that the weight on the TV front axle should be the same both hitched and unhitched, which can easily be accomplished at a scale, CAT or otherwise. (We have a state road scale close to us and it is free, so that part is easy.)
With our long bed truck our jacks were cranked up to about 5.5 inches, but with our new short bed TV, the jacks have to be at 8" to shift the tongue weight back to the FA as when unhitched. After adjustments the TV was properly balanced and the ride was perfect! ( make certain that you have a full tank of fuel, and that all the "stuff" that you plan to take on a trip is loaded in the bed of the TV--also take the co-pilot and the dog!)
Old 05-14-2013, 11:22 AM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Had the same issue, and as others have already posted....you need to get a grease gun onto those zerk fittings. Your squealing/squeaking will disappear. It did for me (and taught me a lesson that these need an occasional treatment. I had a small grease gun in my toolbox ... about a 10 minute job.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-20-2013, 04:55 PM   #9
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
It has already been addressed but it is definitely the spring bars not being greased.
The dealer may have not greased them at all during the installation. It has been known to happen more than once with a dealer install.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 05-20-2013, 05:52 PM   #10
Zackybilly1's Avatar
2009 34' Panamerica
Poplarville , Mississippi
I just ordered a ProPride 3P today and can't wait to get my hands on it. I took delivery of a 28' Intn'l Sig on Friday (my 4th AS) with a dealer installed Eaz-Lift Trekker hitch...it was good enough to get it home but am less than enchanted with it. Saturday, I un-did everything the dealer did and started from scratch. The anti-sway drag nuts weren't torqued properly (off by 100%), the torsion bars were way off (too much deflection in them...porpoised like crazy) and the torsion arm brackets on the A-frame were loose. I feel sorry for those not handy with wrenches as they are just at someone else's mercy.
With every thing dialed in, it still seemed sub-standard compared to my TV & AS and I considered it the weak link between two fine pieces of equipment. Frankly and not trying to offend anyone, it just isn't a very good design to start with (Mickey Mouse would even be ashamed), too much hassle to tweak and too much slop to fine tune it. I preferred Eaz-Lift's old design over this POS. It will, however, make a fine boat anchor.
I don't want to control sway...I want to eliminate it from the equation. I design/build equipment for a living and know a good design when I see one. I had no reservation about ordering the 3P and considering what I am getting, found the pricing very reasonable. Good Lord willing, I'll have it on the scales Friday and my package will be complete.
Z
PS...Nice forum.
Zackybilly1 is offline   Reply With Quote
Old 05-20-2013, 06:16 PM   #11
Central , Mississippi
Originally Posted by Zackybilly1 View Post
I just ordered a ProPride 3P today and can't wait to get my hands on it. ...
Z
PS...Nice forum.
Welcome to the forums!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-20-2013, 06:39 PM   #12
BAB
BAB's Avatar
2015 30' Classic
Since I also have a 2012 28' Intl, trust me when I tell you that you are jaw will drop after you have your PP all installed and dialed in. I'm sure Sean has taken as good care of you as he has all of us who have equipped our trailers with this hitch. Having just returned form a 4 week, 6,200 mile trip with my Intl, and going through wind, rain, mountains, you -name-it, I can tell you that I can't imagine being more satisfied. Since our trailers have a VERY heavy tongue weight (heavier than a 30' Classic), do make a voyage over to the CAT scale so you can determine how many turns to put on your WD jacks...which you can easily alter based upon how much "stuff" you're hauling....and if you do have a question, call Sean. Sad to say, he even answers his phone on the weekends....great for us, not so much for his family!
_________________
ProPride 3P
AIR# 58452
Old 05-20-2013, 10:08 PM   #13
Zigidachs's Avatar
2011 30' Classic
One cannot laud Sean enough for his attention to detail and relentless support of his customer base.,,,NONE better!
Old 05-21-2013, 08:26 AM   #14
2009 34' Panamerica
Hope this is semi-relevant...
I contacted Sean about concerns I had on the drop of the standard 3P hitch bar.
I'm rigging up the 3P on a 2013 3/4-ton Suburban where the top of the receiver box is 25-3/4" above ground level. The standard 3P hitch bar will not cover that range of adjustment therefore he will be shipping an extended hitch bar. Additionally, since the weight of the hitch is cumulative, he has advised me to go with the 1,400 lbs torsion bars.
Z
