09-03-2018, 08:54 AM
2018 23' International
Minneapolis
Newby hitch ball question
I am having a hard time getting the hitch to let go of the ball. It takes a lot of having my wife try to advance and reverse a centimeter at a time while I worry that this is putting too much strain on the hitch jack before it finally and slowly releases the ball.
Is this common? Is there an easy solution?
Thanks for any input!
-John
09-03-2018, 09:11 AM
2016 19ft flying cloud
Spokane
I've found it unhitched easier if you make sure it's greased good and on level ground if possible ,
We fight with it too at times ,,try and be sure and put your parking brake on when putting your TV in park, so the vehicle doesn't go forward when parking
09-03-2018, 09:17 AM
Tampa
Easy solution? I've discovered cursing doesn't seem to help.
I thought I had the mother of all stuck couplers last year.
Usually, if you open the coupler latch, then raise the tongue jack, eventually it will let go of the ball. Mine didn't. Also spraying grease into the coupler, rocking the truck, standing on the WD bars, jumping on the bumper, and rocking the truck in neutral all failed. I even removed the hitch pin and pulled forward so the shank would pull out, it didn't.
Eventually, it just decided the fun was over, and it fell out. (Nearby campers must have thought I'd gone crazy)
My solution? White Lithium grease on the ball so that after driving it's all lubed up in there. Then a rubber cap for the ball and gloves and a "Hitch Grabber" to help keep the grease off you and your clothes.
Princeton
, New Jersey
There should not be anything that would cause the ball to release from the hitch Slowly. Stick yes.
To remove the trailer from the TV, release the latch on top of the hitch, use the the tongue jack to raise the coupler of the hitch off the ball. That should do it.
If the ball refuses to come out of the coupler some times the TV is pressing against the pawl in the hitch and not releasing when you release the latch. In that case, if you are in a valley or on a hill, just put the TV in neutral for a second to remove the rearward pressure on the pawl, or chuck the trailer wheels and put the TV in drive for a second.
This is not a function of lubrication but rather one of reward mechanical pressure between the TV and the trailer not allowing the pawl to move when the latch is released.
The latch allows the pawl to move and increases the opening in the bottom of the coupler less the a 1/4 in. allowing the ball to clear it while jacking the trailer
2004 Excursion 4x4
09-04-2018, 09:27 AM
2019 25' International
Washington
, Washington, D.C.
Wow, what great advice, thank you! I just copied and pasted your instructions into a Word doc and filed it away in my "Airstream" file on my desktop.
09-04-2018, 09:39 AM
2017 20' Flying Cloud
austin
Agree with Mollysdad. I also now use white lithium grease (spray). I've seen others use some type of black goo out of a can and applying with a paint brush (one fellow said it's all around 'grease' he buys from the auto parts store). Still haven't figured out how to get my clothes clean. Am now searching the internet for a hitch grip to see if I really want yet another tool to cart around.
09-04-2018, 09:48 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Short Answer: LUBE it. Lube the ball. Lube the inside of the coupler. Pull handle, LUBE, release it LUBE.
There are various LUBE's and I won't sponsor or say which one is better over the other.
Just LUBE it!
09-04-2018, 10:00 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
That's a good tip about putting the truck in neutral for a bit before attempting hitch release.
Lately after leveling, parking brake on, chocking the trailer wheels, and attempting unhitching, I get a surprise bounce, usually impacting the trailer, which strains the hitch jack assembly. If I can release that tension in advance, so much the better.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
09-04-2018, 10:12 AM
Huntsville
, Alabama
Indeed. I use Andersen's and also found that once leveled and chocked the initial release off the ball could be rather violent. So I too put TV in neutral to let everything settle resulting in much happier detachments. However, the jack assembly is way stronger than you would believe it to be (don't ask how I know).
2017 Airstream 26U Twin
2017 F250 Platinum
09-04-2018, 10:48 AM
2017 28' International
Virginia Beach
, Virginia
I have had a similar challenge - not always so I have noted when I do and when I don't. It seems to be related to the levelness of the TV in relationship to the trailer as well as whether or not it is in line with it. Having those parameters as close in line as possible seems to solve most of the problem. The idea of putting the TV in neutral to release the pressure between the TV and trailer is a good one. Just to be on the safe side I might have someone in the drivers seat ready to apply the brakes in case the TV decides to move further than you need it to. Also I was wondering if not tightly choking the trailer wheels is another way to release some of that tension between the hitch ball and coupler. Since the tongue jack is down the trailer is not going to roll anywhere, but it might move just enough to allow the coupler to release. Just thinking.
09-04-2018, 10:54 AM
2019 27' International
2014 25' International
Boulder City
, Nevada
Just LUBE it!
Works every time after 12 years for us.
Take paper towel and wipe clean when you remove hitch from tow vehicle. Reapply when you connect. I wear a thin latex glove to apply grease on ball and socket. Peel glove off and you are ready to go.
When your trailer is LEVEL after using leveling blocks, your Tow Vehicle is now at an angle to the trailer. This can create tension within the hitch. You may even notice that the jack base move a fraction, when the ball releases, this relieved the tension and the ball drops after a dull... thump.
If truck is at an angle to the trailer, even without leveling blocks... expect this bind, as well. You cannot have everything perfect, all of the time.
On flat surfaces, smooth and easy.
Just keep in mind when you level the trailer, expect some tension before the ball releases. The ball fits very snug into the hitch socket. I grease the inner hitch socket with good bearing grease and wipe it also on the wear area on the ball, which is above the center of the ball. You will easily see the wear ring.
I replace our ball, before the ball gets scoured in this wear area. Grooves from turning while towing. The lack of chrome plating is the first clue. The ball is inexpensive. The trailer side IS expensive to replace. Dust gets into this ball/hitch area and the grit will wear the surface, a little at a time.
Some people have a hitch ball that looks like someone took a grinder to it. They also heard you are not suppose to grease it AND use wax paper or some other option to grease.
Once you recall how you released the ball from the trailer, you will recognize what to expect. This will repeat itself. Once you understand... you will be giving better advice than I can offer.
Human Bean
09-04-2018, 12:11 PM
2005 28' International CCD
Camarillo
When you back into the spot where you want to park, with your foot on the brake, put the truck in D (drive), then put it in park. This will release the pressure which built up when you were in reverse. Then raise the hitch to disconnect your WD bars, lower the hitch to unlock the hitch ball coupler, then raise it off the ball.
09-04-2018, 12:24 PM
Tampa
Keep a good attitude. The time will come when all the good advice here will fail.
BTW, I find this a good tool to move the WD hitch once it's got some grease on it.
If I was designing it, I'd make it a little wider but it balances nicely
09-04-2018, 03:57 PM
Herndon
, Virginia
As others have noted, the attitude of the tow vehicle has a large impact on how easy/hard it is for the hitch to uncouple. Also as noted, be aware and take the tension off the hitch by small ajdustments to the TV. If the last thing you did when hitched was pull slightly forward, the hitch will be tight, and backing off/up just a smidge will lower the tension. Another trick is to be sure you use a "tall" enough support (brick, wood, plastic blocks) under the jack foot, so the jack can rise up higher. Etc., etc.
However, a newbie word of warning. Be sure your chocks are set behind the trailer wheels before you lift the hitch off the tow vehicle. Several years ago in our first major trip with our IS 27, I did not do so. The hitched trailer was pulled back hard against the hitch ball, the trailer pointing just slightly downhill. When the trailer sprang off the hitch ball, the "spring loaded" trailer jumped back about 2-3 inches, and without chocks, the trailer started to roll (jack sliding with a sound like God scraping a shovel across the pavement). The wife is at the camp laundry, the dog is inside the trailer, and I am trying to stop the trailer with my bare hands (screaming cusswords with no effect) as it rolls back toward the pond that's opposite our space. It finally stopped, with assists from the fresh water line and the shore power line. Helpful fellow campers ran over and asked what they could do and I said "CHOCK IT!" It made for a great story later, but it was real scary, especially (I think) for the dog. Chocks first, then unhook......
09-05-2018, 07:32 AM
Stettler
, Alberta
I read about this event or a similar one on another thread - I've adapted my unhitch routine so the last thing taken off is the safety chains - just in case the chock is defeated.
WBCCI #6679
09-05-2018, 07:45 AM
2013 31' Classic
billings
, Montana
This was covered last year under greasing your balls
09-05-2018, 07:52 AM
1976 31' Sovereign
Oswego
If you use chocks that big trucks [semis] they will not fail as 1 goes in front of tire other behind and tied together w/chain. Almost impossible to pull over w/tv also they will not slip, only thing they are a little heavy, not like little plastic chocks.
09-05-2018, 10:03 AM
1973 Argosy 24
hartselle
, Alabama
I am a fan of the black grease from a can. I like being able to apply the grease thick with a brush. For what it's worth zippo lighter fluid does an excellent job of removing grease from clothes. Just saturate the greasy spot with lighter fluid and rub the cloth together to agitate then toss it into the washer. This trick has worked with black grease to gas station fried chicken grease and many in between [emoji3]
09-05-2018, 11:17 AM
2007 22' International CCD
Corona
On chocks:
For a dual axle trailer, the best way to chock it is to use the ones (X-chocks brand is only one example) that go between the two wheels and clamp the tires together. I have an anonymous set that uses a screw and two yellow plastic wedges that tighten between the tires. Once they are set, the only way to move the trailer is with a lot of force, and the tires skid when you try to move it. That is the safest situation. Lock it from moving BEFORE you disconnect from the tow vehicle.
On a single-axle trailer, as pointed out, the best ones are the big blocks that are chained together, or if you can find them surplus, the adjustable double chocks with a tie bar the Navy uses to secure aircraft on a carrier deck would work nicely. A single chock can be climbed by a trailer on a sufficient slope, or with some force from the tow vehicle. The idea is to make movement pretty much impossible when the AS is chocked.
09-05-2018, 09:11 PM
2012 25' FB Flying Cloud
Celina
, Ohio
I started putting a zip lock plastic bag over the hitch when I take it off and leave it on when re-installing on TV. I also leave it on when towing, it provides a nice friction free surface
