Old 11-03-2015, 07:32 AM   #29
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If the trailer will fit and you can't do it, ask your neighbor who drive trucks for a living, you might be amazed what he can do.....
Old 11-03-2015, 10:33 PM   #30
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Originally Posted by splyb View Post
We hooked up, zilch. Seller said the lights were fine at last tow and questioned our already-marginal TV, a Honda Ridgeline. Rodney said he was almost sure the problem was excess crud/rust on the ball preventing a good "ground" (The trailer is grounded through the ball? News to me.) Alternatively, he suggested our 7-blade connector, having never been used previously, might be a bit rusty or cruddy, too. He said squirt a little WD40 in there and plug-unplug several times. As for the ball, he said to unhook, squirt a bit of WD40 on top of the ball (any sort of lubricant would do), re-hook, then rock back and forth a few times to establish a solid metal-to-metal contact between the ball and the hitch. We did both and voila! On they came, fully functional.
I love starting with the basic, simple and common sense solution! That approach saves a ton of money in the long run. Good luck in getting your AS in its parking place.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 11-05-2015, 08:15 AM   #31
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There is a GROUND wire in your 7way. The "ball connection" is not reliable... Especially when you need the electric brakes. And it is larger than the other wires in the umbilical for a good reason!!!
On our 1999 I just repaired our ground circuit.. I will attempt posting a pic of the repaired "grounding lugs"..
Peace and Blessings..
Channing
WBCCI# 30676
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
