Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-08-2006, 11:11 PM   #1
bfk
Profile:  1961 16' Bambi
Eugene , Oregon
New single-arm weight distributing hitch
Has anyone any experience with the new Light Duty single arm hitch from Reese?
It's rated at up to 4000# and uses a single spring bar. It's shown on Reese's website, but you have to hunt for it; it's also at http://www.drawtite.com/dt3205.html.
It sounds like just the thing for our Bambi, but I'd love to hear from anyone who has used one.
Brian
bfk is online now   Reply With Quote
Old 07-08-2006, 11:47 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
In the picture the hitch jack has been removed.
I wonder how they work around that. I use the jack on my 2 arm WD hitch to raise the trailer and truck and attach the bars.
Richard
Charter Member Four Corners Unit
Old 07-08-2006, 11:50 PM   #3
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Clearance problem
It sure looks like there would be a clearance problem with the jack. I would check it out. Interesting concept
TIMEMACHINE is online now   Reply With Quote
Old 07-09-2006, 12:35 AM   #4
bfk
Eugene , Oregon
Clearance problem
From the Reese website:
"This light duty weight distributing system is especially designed for use with lighter weight trailers and pop-up campers. The center mount single bar is contoured to avoid interference with center mounted jacks. Easy to set up and use. The lift mechanism is designed to prevent interference with gas bottles or battery trays. Works with any 2" receiver.
The integrated lifter bar feature provides the advantage of allowing a single person to operate from one side of the trailer. This system works with both side and center mounted tongue jacks. The sway control platform allows you to put a friction sway control on either side of the trailer."
I haven't seen one, though I'd like to. I'd post the URL for the Reese page, but it seems to be one of those ever-so-clever portals where everything is run from a database and there are no useful URLs. If you go to http://www.reese.com, click on products on the top bar, then weight distribution on the left, then light duty, also on the left. Maybe I'll call the local distributor and see of they have one in stock on Monday.
Old 07-09-2006, 08:37 AM   #5
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
You won't need to do that with low tongue weight trailers, such that can use this single bar. You can lift by hand, without having to use the electric jack.
Uwe
Old 07-26-2006, 03:14 PM   #6
COArgosy78
Obsessed with Moonunit
COArgosy78's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 45
Friction Sway
Pictured below is what I was talking to one of the Reese customer serv. people about for our trailer. Is this the same as you have mentioned above? I, too, am wondering if anyone is using this type of sway control.
Friction Sway Control
The Friction Sway Control does exactly what its name implies, it uses friction to resist pivotal movement and thereby works against the effects of included sway. It operates on the principle of "stiffening" the coupling between the tow vehicle and trailer. The degree of "stiffening" or friction is adjusted to suit various trailer weights and towing conditions. Its operation is simple and uncomplicated. It doesn't prevent the generation of sway; it simply works to resist the forces once they have started.
R58060
Sway Control Ball
R26660
  • Installs and removes easily
  • Removes with two spring locking pins
  • Heavy construction for added reliability
  • Friction brake keeps trailer & tow vehicle stable
  • Quick attachment to trailer frame & ball mount
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 07-26-2006, 03:21 PM   #7
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
I use that kind of sway control on the Caravel. So far we've never had any sway even in poor conditions, but we have a very long wheelbase tow vehicle as well.
Stephanie
Our family photo blog
Stefrobrts is online now   Reply With Quote
Old 07-26-2006, 05:14 PM   #8
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Brian!
I too suspect clearance problems with the integrated lifter bar mechanism, but not with the tongue jack; rather my concern would be with the LP tanks. I am not as familiar with the 1960s Bambi as I am with the larger tandem axle Airstreams and first generation Argosys, but with the design of the LP tank mount pushed forward to allow for the spare tire to be mounted against the front wall of the trailer (a typical design feature of the early 1960s era Airstreams as well as the first generation Argosy trailers) could place the LP tanks in conflict with the lever arm mechanism (if the original LP tank mount hasn't been modified). One way to determine this would be to check the installation instructions (usually linked to on the Reese site) which should give the measurements for mounting the integrated lifter bar mechanism, and compare those measurements to the geometry of the hitch on your Vintage Bambi.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 07-26-2006, 05:25 PM   #9
overlander64
Anna , Illinois
Images: 104
Greetings Leigh!
I too have utilized the friction sway control in the past, but am not a fan of the technology. The manufactures instrcutions call for adjustments to be made whenever road conditions change -- tighten for high winds/heavy semi truck traffic -- loosen for rain/slick pavement conditions. It was frustrating to have to find safe places to pull off to make the needed adjustments -- with my coach, it was always evident very shortly if the conditions changed and these adjustments weren't made. It is also highly recommended that the sway bar be removed before backing in tight locations -- I bent one of these bars just trying to park my coach in a typical campground before learning that lesson.
Granted, the Reese Dual Cam system is about twice as much as the friction sway control, but once the weight distribution bars have been properly matched to the trailer/tow vehicle combination and the initial installation has been done according to instructions no further adjustments are required until either the tow vehicle is changed or there is a significant change in the way the coach is packed. I immediately switched my Minuet 6.0 Metre to the Dual Cam system when the Reese factory verified that the primary requirement for an effective setup with the Reese Dual Cam system is a trailer with a hitch weight of at least 400 pounds (my Minuet usually carries about 525 pounds on the hitch -- depending somewhat on the amount of water in the fresh water tanks).
Kevin
Kevin D. Allen
AIR #827
Old 07-27-2006, 07:45 PM   #10
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
ok maybe this is the right thread to post these questions....
I have the older dual cam set up with the stirrups and such on the tongue of my 78. I have no bars, and a kind member here has offered me his set which is not in use.
Neither one of us is sure thought that I will have all the parts I need to run with this, and since the shipping will be pretty high...can anyone tell me what I will need?
He has the 750lb bars, and some odd other parts.
I have the pictured set up...maybe someone with the same set up can explain?
(the blue arrow was from a post about the flag holder)
ID:	23961  Click image for larger version
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 07-27-2006, 07:48 PM   #11
ALANSD
missed this photo....
My Music Site:
Old 07-27-2006, 07:51 PM   #12
Anon
Profile:
I would NEVER tow without the friction sway control or my WD bars. The semi-rigid connection that both of them supply gives me better control of my van and trailer. Plus the WD bars distribute the weight to the front of the van. This is what makes it all nice and snug; like one big vehicle going down the road.
Anon is offline   Reply With Quote
Old 07-27-2006, 10:17 PM   #13
uwe
418
uwe's Avatar
Images: 40
Looks like all you need are the straight WD bars with the cams at the ends. For your size trailer, 750lb bars might be just the ticket.
What are you towing with? If your tow vehicle is very heavy duty, then lighter bars might give you more sway control.
I found that the friction type sway control was terrible for my application, while I used it. It put restriction to the bend, but unfortunately both ways, slowed down starightening out of the rig as well. I ended up shelving it, and my rig felt much better afterwards. ( Suburban 1500 towing a 1971 TradeWind)
Uwe
Old 07-28-2006, 06:09 AM   #14
ALANSD
the member that has the bars says he thought he was mising the small bar that connects to the little ball on the hitch. So what does that do anyway?
Do I need it if I have the two long bars.
It would help if I actually saw one of these in use up close, but the photos I have seen don't quite explain to my thick head how it sets up.
My Music Site:
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
weight specs for 68 Overlander 26D PeterH-79MH 1969 Overlander 5 02-08-2003 03:49 PM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volk
