Old 05-14-2011, 05:33 PM   #1
Plainfield , New Hampshire
New Silverado 2.5 receiver with 6 in drop, what to do?
Help. I have new 2500HD which sits high and has the new 2.5 X 2.5 receiver (and a sleeve to make it 2 X 2). The drop is 6 to 7 inches. I have a very old non-adjustable head. I have 800 pound weight distribution bars and chains, but no sway bar attachment knob on trailer frame. So I have to start over. I have a 1973 27 ft Overlander. Interested in adjustable head/shank with perhaps 8 in drop, plus weight distribution and sway control. Suggestions?
MikeAir is offline   Reply With Quote
Old 05-14-2011, 05:40 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Put your old stuff up for sale on the classified on this site or on Craigslist and buy new or used stuff that will give you the necessary drop to replace it.
Old 05-14-2011, 08:13 PM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I've got the same receiver on my GMC Diesel HD Pickup. I use a Reese Dual Cam, and it works just fine, is fully adjustable, etc. I just changed tire sizes on the trailer, and so had to readjust for purposes of leveling the trailer, etc. ... easy half hour job. There are lots of other options from other manufacturers, however. YMMV.
AirsDream is offline   Reply With Quote
Old 05-14-2011, 08:24 PM   #4
what did you use to adjust height?
The Reese dual cam solves weight distributing and sway issues. What did you use as the drop shank for a 2.5 in receiver?
Old 05-14-2011, 09:06 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This will get you 5.75 drop:
Reese 54977 Titan WD Shank Rating 17000 lbs GTW 1700 lbs TW 2-1/2 Inch Diameter 15 Inch Length 8-1/4 Inch Rise 5-3/4 Inch Drop Camper Trailer RV
Old 05-15-2011, 06:45 PM   #6
New 2500HD with 2.5 receiver, need wgt distr & sway
Thanks for the suggestions. I looked up the Reese dual cam and the Reese 54977 shank, which look like good ideas. One last question, what did you use as a weight distribution hitch? I'm thinking about the Reese 7903. Any thoughts?
Old 05-15-2011, 07:18 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I'm using an older version of the Reese Dual Cam with 750 pound bars. 1200 bars might be too much. What tongue weight is your trailer.
Here's an article that might interest you.
Tuning a Reese Hitch
Old 05-15-2011, 08:39 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Agree with Gary. I also use the old version of the Reese DUAL Cam. My truck is 1 ton so I use 550 lbs bars. We get a great ride. We just return from a 3 day,kinda local,shake down and we still get that OCEAN WAVE RIDE.
GOOD LUCK
RoGer
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 05-16-2011, 09:06 AM   #9
Tongue weight is listed as 500, but that's not including two 40 pound LP gas tanks or anything in trailer. What happens if the weight distributing hitch system is too strong, like 1200?
Old 05-16-2011, 10:43 AM   #10
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Mike, go to the scales and get weighed. It was free where I went if you just want the weights and don't need a certificate. I found my 30' Flying Cloud was over 300 lbs heavier (ready to camp with fresh water, LP gas, 2 batteries, etc) on the tongue than Airstreams official dry weight guess in the specifications.
newroswell is offline   Reply With Quote
Old 05-16-2011, 11:49 AM   #11
AirsDream's Avatar
1999 23' Safari
Yeah, get a weight reading ... bars too "heavy" stiffen the link between truck and trailer too much and roughen the trailer's ride. Airstreams like a smooth, soft ride. My 23 footer uses much ligher bars (I can't remember whether they are 550# or 600#, but work very nicely).
I use a 2" solid shank with the "reducer" on my 2.5" receiver. I believe it's this one:
Reese 3214 WD Shank 14000 lbs GTW 1400 lbs TW 14 Inch Length Camper Trailer RV
Old 05-25-2011, 11:42 PM   #12
2019 22' Sport
High River , Alberta
Is your old hitch head really non-adjustable? Or is it a weld- together type?
If it's the latter, any welding shop could grind out the welds and re-assemble at the correct height. The advantages of this style include the ability to set the height very precisely.
AlbertF is offline   Reply With Quote
sway, weight distribution
Securing drop leaf table during transit Bambi_Bandit Cabinets, Counter Tops & Furnishings 9 09-04-2011 05:30 PM
Blue Ox Drop receiver? indy Hitches, Couplers & Balls 0 04-10-2011 07:48 AM
Big Drop in Gasoline Prices is coming! ALANSD Off Topic Forum 8 04-01-2011 05:27 PM
Best receiver: Curt, Drawtite, or Hidden Pacerized Hitches, Couplers & Balls 7 03-21-2011 09:13 PM
receiver hitch, frame repair projector Argosy Motorhomes 6 02-08-2011 08:04 PM
