10-20-2019, 03:09 PM
2016 22' Sport
Swedesboro
, New Jersey
New Shank ? TV
Recently purchased a new TV, 2020 Jeep GC with tow package, Sting Gray ( old TV: 2014 Jeep GC with after market hitch, white) towing a 22FB Bambi
The new hitch port is 4 inches higher than the old. Added a drop shank to level Bambi. The new shank is 3 inches shorter ( horizontally) , meaning the hitch ball is 3 inches closer to the TV. all looks level, (photo) handled well on a short test drive.
Will this cause any issues?
Towed with my old Jeep almost 15,000 miles no issues.
10-20-2019, 03:49 PM
2016 27' International
Sherwood Park
, Alberta
As long as you can make full turns without the rear corners of you Jeep hit the front corners of the trailer you are good. The shorter distance to your TV is desirable as it creates less weight on your Jeeps rear axle as well. Not that this is an issue with a Bambi's hitch weight.
Based on your photo's, your setup looks good.
10-20-2019, 06:34 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
I agree that the shorter the shank the better. When CanAm set up mine, they actually drilled a new hole in the shank so the ball would be as close to the rear axel as possible. I tow a 30 with a 2014 Jeep GC and currently have about 200,000k on it. No negative towing issues.
10-20-2019, 06:55 PM
2017 16' Sport
N/A
, N/A
Less weight then the 22’Bambi, the JGC makes for a comfortable ride for my 16’ Bambi
10-20-2019, 10:05 PM
2019 22' Sport
High River
, Alberta
The new setup looks a lot better to me than the old. The closer to the bumper of the tow vehicle, the better.
Don’t be afraid to play with the tension. In my experience with an Eaz-Lift setup, one can really optimize handling and stability through small adjustments. Having said that, I don’t have any experience with the Equal-i-zer hitch.
10-21-2019, 06:41 AM
2016 22' Sport
Swedesboro
, New Jersey
Thanks for the info
Thanks to all for the affirmation on my set up. Good observation to Albert on the Equalizer,( I should have included that info in my request) Dave
10-21-2019, 09:30 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Yep, No Worries looks good IMHO
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
10-21-2019, 10:57 AM
Tampa
It's close to dialed in.
To my eye the trailer looks a bit high in front and the TV a bit low in back.
Since you have an Equalizer hitch, I'd try going one hole lower on the shank and add another washer to the rivet.
10-21-2019, 02:44 PM
Sherwood Park
, Alberta
That could be a bit of an illusion. The best way to tell if it is level is park it on a level spot and use a carpenters level on the floor of the trailer.
10-21-2019, 07:06 PM
2017 16' Sport
N/A
, N/A
New Shank ? TV
Someone suggested carrying a marble in your pocket, haven’t seen a ‘cats eye’ in a long time
10-21-2019, 07:40 PM
2016 22' Sport
Swedesboro
, New Jersey
Interesting
Mollysdad, thanks for the reply, I do believe it may be an illusion from the way the photo was taken. Contractors level is very close and measurement by tape is within 3/4 of an inch between Front and back.
10-22-2019, 08:04 AM
Sherwood Park
, Alberta
Front to back level is not critical on a single axle trailer. As long as there is a proper amount of tongue weight, the angle of the trailer doesn't matter. However, level, or close to it, does look a lot better traveling down the road.
11-02-2019, 05:55 AM
2017 16' Sport
N/A
, N/A
New Shank ? TV
I don’t agree with your assessment if the single axle trailer weight is not distributed evenly this will be seen as a leaning to the rear or front of the trailer, to the rear is dangerous as well as excessive tongue weight can lead to porpoising.
11-03-2019, 10:48 AM
Sherwood Park
, Alberta
That is why I said "... as long as there is a proper amount of tongue weight". It is also pretty near impossible to wind up with excessive tongue weight on a 22ft, single axle trailer, resulting in porpoising.
11-03-2019, 04:53 PM
2017 16' Sport
N/A
, N/A
New Shank ? TV
removed
