Old 01-26-2014, 05:56 AM   #1
thunderbird's Avatar
1968 26' Overlander
Spijkenisse , netherlands
new reese hitchhead
I recently bought a new head and I want to use the old springbars
are the stubs on the trunnions always the same size? I mean old versus new
to my feeling the trunnions fit a litlle loose on the new head compared to the old head
regards George
thunderbird is offline   Reply With Quote
Old 01-26-2014, 06:33 AM   #2
dznf0g's Avatar
Oswego , Illinois
pics would help. What vintage is your old head? I believe if the old ones were the same weight rating as the new ones, they are fine. The trunnions don't fit tightly into their sockets. Can you post pictures?
-Rich-
Old 01-26-2014, 07:06 AM   #3
1968 26' Overlander
dont know how old the reesehead is, it came with the trailer'' 68 overlander''
the head is the welded type so not adjustable.
I will post pics of the old head later.
is there a difference between old and new trunnions ?
Old 01-26-2014, 07:22 AM   #4
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Depending on the year, yes. The new trunnion bar knobs are larger and don't always fit old heads. Due to wear and tear they may.
Just for your info, new trunnions inserted into a new head will have appr 2-3 "free" up and down play, when not put under load .
I just went through replacing the trunnion bars from 1000# to 800# bars. According to Reese they were not supposed to fit the old 1993 head, but they did. Upon closer inspection of of the old head, i saw a lot of wear and decided it would be best to replace the head with the trunnion bars.
This involved getting a new hitch ball and torquing it to 450 pounds with 1 7/8 socket.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Reese hitch recall!!!!! lewster Hitches, Couplers & Balls 7 08-10-2011 07:34 PM
Equalizer vs. Reese dual cam road test dznf0g Hitches, Couplers & Balls 25 08-02-2011 06:30 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Reese Part Number 26002->26102 thecatsandi Hitches, Couplers & Balls 28 04-19-2011 04:15 PM
Reese snap up brackets Khulse Hitches, Couplers & Balls 0 02-05-2011 01:03 PM
