Old 04-16-2007, 08:39 PM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
new reese dual cam
I have a 34 foot airstream and plan to buy a reese dual cam. Can someone tell me how much of a drop i need as I am pulling it with a 2000 Excursion 4x4. The trailer is 1200 miles away so I need the height of the hitch from the ground to the top. The excursion has a height to top of hitch of 19". Also should I go with 1000 lb. or 800 lb. bars? Any help would be appreciated.
Bing-Bing is offline   Reply With Quote
Old 04-16-2007, 09:06 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You can find your hitch ball height and advertised tongue weight here:
http://www.airstream.com/airstream/p.../weights-1.pdf
I'd go with the 1000lb bars. The published weight is more than likely for a dry trailer with no personal items or water in it.
Uwe
www.area63productions.com
Old 04-16-2007, 10:17 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I have 1200 pound bars for my 10,000 pound trailer. I have the reese dual cam hitch. I am using all the drop on my "stinger" (shank)..
What ever you do make sure it is set up correctly. With the Tow Vehicle at its towing weight and loading. If it is set up wrong you will very likely sway. Mine was not set up correctly at first and my trailer swayed.
Michelle TAC MT-0
Sarah, Snowball
Old 04-17-2007, 05:07 AM   #4
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I have the same Reese hitch. I would think you need the 1200lb bars. Typical the lighter the TV in relationship to the tongue weight the heaver the bars need to be. With a 34' I would think it would be the 1200lb. I talked to Reese teck support and they where very helpful. When you call you want to know the trailer weight, tongue weight, tongue hight and TV height. You also need to take the load behind the rear axle into account.
Phil Gobie is offline   Reply With Quote
Old 04-17-2007, 05:54 AM   #5
Towdaddy's Avatar
2007 34' Classic S/O
Kalamazoo , Michigan
Hi Bing-Bing,
Does it have a slide? I have 34' with the slide and my dealer set me up with 1200# bars. The hitch height on mine is 19-3/4". Hope this helps.
Vickie (Mrs. Towdaddy)
Jeff/Vickie
Air #5970
2001 F250 CC 7.3 PSD 4x4 ("Bubba")
2007 34' SO Classic ("Betty Lou II")
Towdaddy is offline   Reply With Quote
Old 04-17-2007, 06:29 AM   #6
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
We need more info. What year is the trailer? The trailer weight and subsequent tongue weight vary tremendously over the years. They got heavier with the wide-body trailers, and heavier still with the slideouts. A new wide-body with a slide has a tongue weight that exceeds the Excursion's rated capacity.
I towed my '94 standard-body non-slide tri-axle with my Excursion using 1,000 lb bars.
A couple of really good ideas... first, the rear spring stack on the Excursion allows for rear-axle steering. It isn't strong enough to hold the axle in place. It will cause you fits towing. Get Land Yot radius rods. If your Ex doesn't have a rear anti-sway bar, have a 36mm Helwig installed. If you haven't already, make sure your Ex has "E" load range tires (this is critical or you'll experience sidewall failures and blowouts towing) and if you have stock Ford shocks, get some decent ones installed. These mods will improve your towing experience tremendously. If you don't do them, you'll not be happy with the Excursion as a tow vehicle, and your 34' will drag you all over the place.
Roger
Old 04-17-2007, 09:19 AM   #7
2006 30' Classic
Farmington , New Mexico
Images: 14
Roger
It seems that if that many mods.$$$ are needed it would be cheaper to go with a "Hensley Arrow"-----pieman
Mike Lewis is offline   Reply With Quote
Old 04-24-2007, 01:21 PM   #8
1992 34' Limited
Falls Church , Virginia
Mods are going to be needed anyway...
Pieman etal -
I read Rogers comments - the sense I get it from reading it is, those mods/additions/etc... will be needed to be done regardless of the hitch that is installed. Those mods are needed to make the Ex the best TV that it can be.
The hitch is an additional item.
My reading of it, of course, may vary with your reading of it - and both of those may vary from Rogers intent as well.
Did I muddy the water sufficiently?? Sorry if I did....
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 05-27-2007, 10:40 AM   #9
Bing-Bing's Avatar
1994 34' Excella
Thanks for all your help. I have d rated tires so I guess I will have to buy 4 new ones.
Old 05-27-2007, 11:46 AM   #10
85MH325's Avatar
Tipton , Iowa
Images: 37
Axel is correct. The Excursion should have those mods done regardless of the hitch used. Without them, the rear end will wallow and be very "vague" while towing. As a matter of fact, without those mods, the Excursion handles "vaguely" anyway. With them it handles more like a sports car. The mods are mostly routine maintenance except for the Helwig sway bar, $130, and the Land Yot radius rods, $300. You definately want the E rated tires.
You still haven't answered regarding the model and year of the 34' you have. That will make a huge difference in tongue weight and subsequently what you need to make your Excursion tow it.
Roger
Old 05-27-2007, 12:35 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Ditto on the Load Range E tires; these are a MUST.
Also check the factory receiver on the Excursion and make sure that it is a Class IV or Class V. GM trucks come with a Class III receiver that is not up to a real towing job. The welds cracked on the factory receiver on my 2005 Suburban 2500 (see photo) pulling a 7500# 25" with about 750# of tongue weight.
SuEllyn & Brian McCabe
Old 05-27-2007, 12:40 PM   #12
moosetags's Avatar
Oop! I forgot to attach the photo of the receiver. Here it is.
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
