Old 03-19-2013, 06:34 AM   #57
floridalarry's Avatar
1966 20' Globetrotter
Ormond Beach , Florida
QuickBite Install
Howie, thanks for the info. How much higher does the coupler now sit and is there a repair kit for the jaws? I'm almost there in the decision process. I's now down to the Atwood 91911 or the QuickBite. Hugh price difference, but both will accommodate the Andersen.
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline   Reply With Quote
Old 03-19-2013, 08:42 AM   #58
1971 29' Ambassador
guyton , Georgia
one thing nice about this all of these post . if you like it and it works get it just sayin
a lot of good help here and for one I enjoy all of them then I do it my way with some in site and it works .
r.swanson is offline   Reply With Quote
Old 03-20-2013, 01:20 PM   #59
Andersen with QuickBite
Just spoke with the makers of the QuickBite (Lippert) and there is no repair kit for the QuickBite. Waiting for confirmation from Andersen that the Atwood 81911 coupler is the one they use in their testing. No repair kit for the 81911 either. But the $$$$ difference is astounding . . . QB $179 plus shipping and tax and $220 for installation. Atwood - $28 plus shipping and tax and $100 for installation. Huge difference for easy hook up.
I'll keep you all posted.
WBAC #1021
Ormond Beach, FL
Old 03-20-2013, 01:40 PM   #60
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If it 'aint broke, fix it 'til it is....
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 03-20-2013, 02:02 PM   #61
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes you can buy a repair kit for a coupling that will not work. There will be no need for a repair kit for th QB
2004 Excursion 4x4
Old 05-26-2016, 10:17 PM   #62
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Unfortunately, the losers at Lippert have purchased the patent and discontinued production of the QuickBite coupler.
I'm suspecting that the purchase contract was based on paying the inventer X dollars per unit sold, and they've figured out a way to screw him in the process.
Old 08-07-2018, 07:33 PM   #63
2018 25' Flying Cloud
Roseville , California
QuickBite
Does anybody know if there's any way to replace the QuickBite coupler pin with something that locks?? It appears that there are no hitch or coupler pins that are long enough to go through the coupler, and that are the same diameter as the original pin.
Larry
graywhale is offline   Reply With Quote
Old 08-07-2018, 10:31 PM   #64
drboyd's Avatar
1978 25' Tradewind
https://store.lci1.com/pin-qb-700-sa...b-model-qb-700
Old 08-08-2018, 07:28 AM   #65
HowieE's Avatar
Images: 12
Larry
I assume you are interested in anti theft protection as there would be no reason to lock the trailer on while towing.
Consider drilling a hole through the front of the bail that secures the jaws in the locked position and putting a pad lock through it. If the bail can't be lowered into the locked position there is no way they can tow the trailer away.
2004 Excursion 4x4
Old 08-08-2018, 08:27 AM   #66
Mexray's Avatar
1978 28' Ambassador
Morada , California
I’ve been using my QB equipped rig for 10 years now & there is no wear to the jaws that I have found...
I use the QB locking pin when the trailer is stored along with a hitch ball that I’ve cut off ‘flat’ on the bottom - that I insert into the jaws & close, so there is no opening underneath that someone could try to ‘hitch’ with a small ball, etc...
The QB locking pin is of course always used when hitched up to secure the jaws from opening & someone trying to remove the trailer...!
I’ve always used a measuring ‘stick’ to set the height of the trailer neck when hitching up...
1. Set stick next to hitch ball - use thumb to hold stick at top of ball...
2. Move stick next to hitch & raise/lower jack till your thumb matches the height you need to fit into the jaws...
While some have mentioned the possibility of jack damage, I’ve never seen that to be an issue... You don’t ever have to ‘slam’ into the QB to latch the jaws shut...a gentle mating is all that’s needed... I always use a small portable camera that has a magnetic base when hitching by myself with a small screen monitor to insure a good alignment, after setting the proper hitch height with the jack... Easy, peasy ...
Old 08-08-2018, 09:15 AM   #67
Mollysdad's Avatar
So I followed the link in post #1, and found it no longer viable.
It may have been a great idea (probably not) but now those of you who bought them are left to buy the next great idea.
Old 08-09-2018, 10:45 AM   #68
Thanks for the tip/s; I just ordered the locking pin from Lippert! I just assumed if they weren't marketing the hitch, that likely they wouldn't have any "accessories." I like having it locked on even while travelling, just in case I make a stop where the rig is not in view!!
Old 10-04-2018, 05:37 AM   #69
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
I use breakaway chains to lock my hitch head, turned under, up into the QB coupler. I have an old carbon steel short shaft with holes both ends I lock through the QB coupler’s 1/2” pin hole. No one can drive up and easily hitch to it. An organized thief will take my trailer regardless of any countermeasures I set, if the rig is unattended. So we mostly don’t leave it unattended if we can avoid it. Everything within is replaceable and we have so-so insurance. Sorry this fine coupler no longer available. Installed mine May of 2008, right after seeing first time on Pete and Karen’s AS at WBCCI Easter Rally in St Augustine that same March. 141,000 miles on this QB and no sign of wear. The SS jaws grind on hitch balls a little but we replace our hitch ball every year or two so no worries there.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Trailer Coupler Lock - which one? norsea Hitches, Couplers & Balls 17 09-22-2016 05:22 PM
When hooking up to electric which amp would we use?? 30, 50? ckelly617 All Argosy Trailers 2 03-15-2008 12:12 AM
Midwest Hooking up Solar Panel Jurgena Boondocking 3 06-22-2007 04:39 PM
hooking up new radio powd Audio, Video & TV 15 07-20-2004 08:37 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
