Old 10-13-2008, 07:55 PM   #43
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
QuickBite Coupler is for real
My number of posts and my retired status should qualify me as a disinterested party for this product and others. I speak for products I like and against ones I tried and don't like. (I won't speak against one I haven't tried.)
I've had the QuickBite Coupler on my 2005 CCD 25 since five months ago and have eleven thousand miles on it. BTW, I use Equalizer 1000# w/d bars for weight distribution and sway control. Installation was tough only because a coupler is so fully welded onto the frame and requires a bit of work to grind off. Welding on was sooo quick, less than fifteen minutes.
The QuickBite Coupler has done everything it advertised and has simplified my hitching in one nice respect. Lateral aim isn't too difficult to master, even without special aids like mirrors, cameras, or aiming poles. Getting the distance right on is so cool with the QuickBite. Back into it softly and the coupler latches fully (and audibly -- clack). Then raise the hitch head (and truck, of course), slide the Equalizer bars onto their brackets and latch them, and lower the jack. Done.
Yes, this coupler seems to envelop the hitch ball 360 degrees in the horizontal plane and on the entire vertical arc around the ball. Does this matter? It may not at all. The first one I saw was on a 30' Safari S/O in Florida this past Easter. He swore it tightened up the feel between his towvee and the trailer. I can't speak to this, just can't feel it myself.
We're glad we made this switch to the new coupler. These are for sale at boat and trailer shops. We bought ours locally and my brother-in-law installed it for me. He said I should have kept my money, the original equipment coupler was "good enough". Hey, we're into home improvements and this is our only home. When was good enough all you wanted for your house?
I have two pictures of this (not from mine, but from Pete Abbott's Safari 30 with dual-cam Reese w/d bars) on my website in the Home Improvements album. See if this link and this link work, and if they don't then email me if you want an emailed link to them.
And no, I have no connection of any kind with the manufacturer, the designers, or the sellers of this product or any other product anywhere. You could see other products I like (and dislike) here on our website. (I hope the links work.)
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 10-29-2008, 11:38 PM   #44
Mexray's Avatar
1978 28' Ambassador
Morada , California
Dreamstreamer...I'm a convert now also.
I learned about Quickbite from this thread, and posted some initial comments back in April, as it looked like a great improvement over the common, stamped steel coupler we've all come to live with when we bought our trailers!
A custom trailer dealer I talked with when buying my Quickbite, told me this coupler is well liked and accepted by their customers on new units, and they have been refitting many customer's older trailers as well...I'm talking 'working' type trailers here.
I also picked up a new 10K Equi-l-izer WD hitch...going to get the new setup dialed in next week when I get the AB welded in place...can't wait to try it out!
Love these 'new' toys....
Ray & Pat; Morada, CA
Old 10-30-2008, 01:13 AM   #45
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I've considered it simply for the reactions it would get here
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 11-11-2008, 01:07 PM   #46
Mexray's Avatar
1978 28' Ambassador
Morada , California
OK, here's some pic's of the completed QuickBite Coupler conversion...Backed right in the first time, and as mentioned above, with our new Eaui-L-izer WD rig, after coupling, raise up the hitch with the jack, move the WD bars onto the frame brackets, hook up the chains, breakaway and 7-way electrical cable, and...GOOOOOOOOO! This whole process takes less than 5 min's...I'm a real convert!
Name:	QB Stb [Desktop Resolution].JPG
ID:	71260   Click image for larger version
Name:	QB port [Desktop Resolution].JPG
Name:	QB ready [Desktop Resolution].JPG
ID:	71262   Click image for larger version
Name:	QB open (2) [Desktop Resolution].JPG
Old 11-17-2008, 07:32 AM   #47
Fuil-Timers
Images: 38
Mexray --
How much did you end up paying for installation? Mine was just over three hours labor, more than we had hoped. But glad to have it anyway.
Don't forget to use a good grease on the hitch ball for this coupling just like you would on any other coupler. And, just as with new bearings and races, the new coupler may mark the hitch ball as they mate up the first few tows. Doesn't appear to be continuing, just the initial wear-in.
Your new install ooks sharp, and I like the locking pin you bought. I have the locking pin on my gift list, hope someone (like my dw ) buys it for me. When we leave our Airstream unattended, and not in a campground, I want to lock the coupler closed over the hitchhead, and I lock the drawbar pin hole closed.
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 11-17-2008, 07:38 AM   #48
Fuil-Timers
Images: 38
Is it worth it? It depends.
[ I've considered it simply for the reactions it would get here ]
Is burning off a perfectly good coupler to install a newfangled one worth it? Only if you specifically want the easier hitching/unhitching. I only need get my left-right bearing correct -- distance is automatically confirmed when I bump the back of the jaws and they close and the bail falls and latches. SWEET!
A close friend of ours tows solo since his wife died. He's another of these Hensley Hitch advocates who can, unaided, back into his hitch perfectly. He doesn't want any other coupler and like many Airforums people, doesn't need anything to make it easier. Interestingly enough, though, HAHA people also only have to get their left-right bearings aimed because distance is controlled by sinking into the socket all the way.
Like Mexray said, buying some toys is fun. And this one is fun and helpful too. The jaws and the 5/16" jaw pivot pins are stainless steel and easily replaced although we doubt this would become necessary. We removed and inspected ours at over 11,000 miles and found no noticeable wear.
We also think QuickBite looks cool but wouldn't have bought for that unless we gained functionalities too. And the claim of superior strength over a normal coupler doesn't swing anything for us. If we have the misfortune to flip the truck and trailer then all bets are off anyway. And we've heard several examples of the traditional couplers staying hitched too.
IMHO, this QuickBite project is worth doing if you want the ease of automatic latching. We like it.
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 11-18-2008, 04:53 PM   #49
Mexray's Avatar
1978 28' Ambassador
Morada , California
Mine took about three hours also to complete...
http://www.airforums.com/forums/f464...day-46178.html
I wanted to remove the old hitch entirely, clean things up and make sure the new QB coupler was 'glued' on real good!
I had to 'shim' each side of the QB coupler, in the rear along the frame sides, which was no big deal...also had to move the lower jack brace aft about an inch to match up with the jack hole in the QB.
I sent Mark at QB the thread with my pics for his comments...he mentioned that the QB angle type coupler is made to be welded right over the old coupler if desired - you just cut off the 'nose' of the old coupler, grind the sides flat, lay the new QB coupler on top, and weld...
While I didn't measure, if you installed the QB in this 'over old coupler' method, you'd probably wouldn't have to move the lower jack brace...
I wish I'd known about that installation 'feature' as it would have been a much quicker install...and if prepared properly, it would be just as strong...
I'm really happy with the design...and performance of this great new coupler!
Old 07-27-2009, 04:14 PM   #50
2005 22' International CCD
Winston-Salem , North Carolina
I travel solo and have always dreaded having to hitch up. No More. F250 Diesel 4wd 4 door with a 2005 22' International CCD. I do not even use equalizer bars or sway bars: my AS is only a few inches longer than my truck. Tows beautifully. And the ease of hitching is hard to describe.
mikesprinkle is offline   Reply With Quote
Old 07-27-2009, 05:53 PM   #51
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
Hey Mike, I was going to email youto see if this was like yours. Its on my wish list.
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 03-16-2013, 11:22 AM   #52
Fuil-Timers
Images: 38
Update on QB Coupler
It has been over three years since last posts to this thread, although a lot of discussion about it has been on the newish Andersen WD hitch thread. I thought it advisable to update this one with some facts, not fancy.
We installed our QB coupler, with brother-in-law's expert welding assistance, in May 2008.
We have towed over sixty thousand miles so far with our quick bite coupler with Equal-i-zer hitch. We've been in almost every kind of conditions in that period, from Del Ray Florida to Fairbanks Alaska and most everywhere in between. The QB has given us no mechanical problems, no "gee I wish it was just a little different" in any way. This is the setup for us.
Any questions, feel free to PM or email me, dreamstreamr at gmail.
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 03-18-2013, 07:12 AM   #53
floridalarry's Avatar
1966 20' Globetrotter
Ormond Beach , Florida
QuickBite Measurements
Would any of you who have a QuickBite, please measure the width (inside dimension) of the rear of the coupler or the width of your A frame (outside dimension) where the rear of QB meets the frame and let me know. Thanks
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline   Reply With Quote
Old 03-18-2013, 10:44 AM   #54
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is quite a difference in the measurement at the rear of these 2 couplings. You do not want to rely on those measurements while placing the QB coupler on the A frame. You want to position the QB over the Atwood to make sure the jack will clear the gas bottles after installation.
Look at posts 1396 and 1415 on this tread to see how to use the jack position the coupler for welding. Yes there will be a gap that has to be fill but if you do not take this approach you will have a conflict with the gas bottles.
http://www.airforums.com/forums/f464...92131-100.html
2004 Excursion 4x4
Old 03-18-2013, 01:29 PM   #55
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
And the reason for "instant" hook-up is?.......
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-18-2013, 11:44 PM   #56
mefly2's Avatar
2015 25' FB Eddie Bauer
I guess that if it is easier, then that's the selling point.... it works for me. I would like more info / feedback from users as well as best suppliers. An online search doesn't yield much.
Trailer Coupler Lock - which one? norsea Hitches, Couplers & Balls 17 09-22-2016 05:22 PM
When hooking up to electric which amp would we use?? 30, 50? ckelly617 All Argosy Trailers 2 03-15-2008 12:12 AM
Midwest Hooking up Solar Panel Jurgena Boondocking 3 06-22-2007 04:39 PM
hooking up new radio powd Audio, Video & TV 15 07-20-2004 08:37 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
