Old 04-15-2015, 10:02 AM   #1
z , North Carolina
New 16" Tires & WD re-adjustment help plz?
Okay folks, so I got my new tires & rims installed, and now the front end of the TT is really down with the old position on the shank. Several questions I would like to ask.
Let's start with the digits:
TV without TT attached, Front fender: 40" Rear fender: 41 1/2"
TV attached to TT, WD applied w 5 links between the bars, Front fender: 40 3/8" Rear fender: 40"
Level trailer ball height is 22". I am using Reese shank 63978, and the highest I can get the ball with the shank pointed down is 22". If I turn the shank upside down and pointed up towards the tailgate, the lowest I can get the ball is 24".
I called Reese thinking I should get a new ball with a 1" rise. They said to lower the top bolt back towards the trailer by at least 2 ticks, and re-measure.
If every piece of literature I have read says the ball should be 3/4" to 1" higher than the top of the trailer before dropping the TT down onto the ball, why on earth is he telling me to LOWER the ball? I didn't want to argue with them, but that's what I am being told.
I haven't even been to the scale yet. Is the 3/8" increase in height of the front fender cause for concern? It seems to me I need to get more of an increase in the rear height, and a decrease in the front height before I even take it to the scale.
Am I fussing over nothing, and should I just get the rig to the scale?
Do I need to purchase a ball with a 1" lift to make up the 3/4" to 1" I feel it should be set to, before beginning this re-adjustment?
Thank you,
Gavin
FishinHatteras is offline   Reply With Quote
Old 04-15-2015, 10:10 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Put the ball mount in the next higher set of holes in the drop bar, and leave everything else as it was. Then, take a look, and see how it is.
Old 04-15-2015, 10:20 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup.
What is strange is that even tho you have the same 'WD' chain link set as before, the 'weight' is not pushing the front of TV down..
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-15-2015, 10:24 AM   #4
SteveH's Avatar
Common Sense , Texas
I disagree with the previous posters. What Reese is telling you to do is increase the rearward slant of the head which will increase the tension on the bars, which will lower the front of your TV a little, and most probably raise the front of the trailer and lower the rear.
The fact that your front TV measurement is greater with the trailer attached says you do not have the bars tight enough.
However, you did not tell us how low the front of your trailer is compared to the rear.
Regards,
Steve
Old 04-15-2015, 11:17 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That was my take, also, regarding what the Reese guy was telling you. Had to do with the slant of the head, not the drop of the head.
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-16-2015, 11:06 AM   #6
1996 25' Excella
Tillsonburg , Ontario
On my first As the dealer told me the TV ball height was to be 19 1/2 inches. So I set it up for that and then used the bars to pull it all up level. Later I added extra leaves to the rear springs which raised the rear of the TV about 2 ". Still when I hooked up it all came back into line but with less torsion on the bars.
Seems to me if you check the height of your trailer hitch (level trailer) and set the ball on the TV to that height (or correcting up or down for any normal out level of front to back on the TV it should all work out using the bars to pull it into line. BTW if your links are too long and you need only a half a half link adjustment, just insert a high strength bolt and nut (with washers) into a pair of links to shorten the chains
JCWDCW is offline   Reply With Quote
Old 04-16-2015, 11:30 AM   #7
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Will be watching this thread. My Reese setup needs a little tweaking as well, so I will be interested in what works for you.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 04-16-2015, 11:48 AM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
You're using the one I am using, you can also try this one which will give you more downwards adjustment: Reese Weight Dist Shank - Drop Only - 14" Long - 4-3/4", 6-1/2" Drop - 1,500 lbs TW Reese Accessories and Parts RP63971
I was looking into it because I needed to go down, but the 16's may have solved that issue, we'll see.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
AZ, UT, & CO. Help Plz? FishinHatteras On The Road... 21 02-03-2015 02:33 PM
PLEASE help me with towing needs -PLZ tempest2 Hitches, Couplers & Balls 5 06-05-2009 11:22 PM
A&E Awning Is Smarter than I am; Plz. HELP Gael79 Awnings 5 05-18-2008 05:31 PM
Southern Cal is on FIRE!!! Plz help if you Can.... Tim Can Our Community 5 11-04-2007 05:09 PM
