Old 11-05-2006, 07:39 PM   #15
1960 24' Tradewind
santa barbara , California
Well you could just get another ball (you have an extra then) and put it in there and that would be really easy to do ,probably could tell alot more without all the weight hanging on it .
Scott
scottanlily is offline   Reply With Quote
Old 11-05-2006, 07:54 PM   #16
millertime's Avatar
Valencia , California
Originally Posted by Canoe stream
If the hitch isn't engaging the ball, weight distribution bars may dislodge. If that doesn't, moving down the road certainly might. Okay -- it's a 10,000# rated thick shaft 2 5/16" ball, right?
The hitch is engaging the ball and I am able to lock the coupler. As a matter of fact when I raise the trailer after locking the coupler, it is locked on there because it starts to lift the back of my TV.
Yes I just looked at it and confirmed that it is a 10,000Ibs rated 2 5/16" ball.
millertime is offline   Reply With Quote
Old 11-05-2006, 07:57 PM   #17
millertime's Avatar
Scott
Yep, figured I can go pick up another ball to test with or better yet instead of stressing out over this, maybe I'll just have to drive back to the AS dealer and have them look at it.
Old 11-05-2006, 07:59 PM   #18
millertime's Avatar
Originally Posted by azflycaster
Inland Andy lists a repair kit on his website
It costs about $30. Looks like you remove the roll pin in the handle and it falls apart. Clean it up and put in the new part.
Thanks for the info! Are these pretty standard? Could I find this at say Camping World or is it specific to AS?
Airstream Life Winter 2006 Issue 66Overlander Airstream "In the News" 14 02-15-2006 06:38 PM
Reese Hitch issue Tin Hut Hitches, Couplers & Balls 1 01-10-2006 04:07 PM
Airstream "sighting" TIME, April 7 issue Kistler Our Community 2 04-02-2003 07:23 AM
Filter issue... Joel Graham Water Heaters, Filters & Pumps 2 03-08-2003 09:52 PM
