Old 12-09-2015, 05:49 PM   #15
1967 22' Safari
Pearland , Texas
Originally Posted by HowieE View Post
You are dealing with 2 completely different issues here.
WD, and it is cot clear that you will need that with this light a trailer.
Sway Control, and you will need to address that with a single axle trailer.
You should install a plate type anti sway device between the AirSafe, that small arm next to the ball, and the trailer tongue. Then try your test run.
Any recommendations? Looks like this Camco has pretty good reviews. Any input would be great.
TexasToaster is offline   Reply With Quote
Old 12-09-2015, 06:02 PM   #16
1967 22' Safari
Pearland , Texas
Also, is there any reason that I should keep these old WD brackets?
Old 01-22-2016, 12:05 PM   #17
Airstreamer67's Avatar
This is an old thread but I hate to see questions go unanswered.
In post 15, that's the friction-type sway control you need for the small ball on the AirSafe hitch. They're basically all alike, so I'm sure that brand would be OK.
And regarding post 16, if you're not going to use weight transfer bars, you can remove the brackets but I'd keep them for possible use in the future. Of course, I keep everything and eventually find most things in my stash come in handy. In any case, the brackets are easy to remove and replace.
Let us know how your towing goes.
Airstreamer67 is offline   Reply With Quote
Old 01-22-2016, 12:37 PM   #18
Gainesville , Florida
Leave the brackets they may work with another hitch if you decide to go thst way.
Crew Cab vs. Extended Cab moosetags Tow Vehicles 43 02-01-2012 03:40 PM
towing with 1/2 ton 07 silverado ext cab Barry Parkof Tow Vehicles 6 02-28-2009 10:42 AM
Extended Cab or Crew Cab 2500HD w/Duramax for TV??? TomR Tow Vehicles 19 01-31-2007 06:27 PM
council about silverado crew cab 3500 frederic.c01 On The Road... 7 08-31-2006 06:38 AM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 06:10 PM
