Old 04-28-2016, 03:00 AM   #1
BW1
1991 29' Excella
Rockwood , Ontario
Need New Drop Hitch Bar?
Hi Everyone!
After much deliberation about which new truck to buy, I bought a new 2016 F150 4x4 Crew cab.
What I would like to know is do I need a new 'drop hitch' or can I use the same one I currently have for my old 2010F1504x4 Crew Cab?
The biggest difference is I now will have 18" Tires instead of the 20" on the current F150.
Thanks again
BW1 is offline   Reply With Quote
Old 04-28-2016, 03:08 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
While empty, measure from the bottom of the truck receiver opening to the ground and compare between the two trucks as a starting point. Note that both trucks should have a full gas tank for comparison purposes.
The changes in the springs between the model years may impact how much the new truck squats under load as compared to the older vehicle. Most drops are in two inch increments which can become problematic in getting the trailer level with the weight distribution hitch systems.
Combining 4" drop reciever to Hensley 8" drop shank Rascal0729 Hitches, Couplers & Balls 18 07-20-2015 05:52 AM
Hensley Tow Bar 6 inch drop streamlynz Airstream Classifieds 0 06-10-2015 01:59 PM
Need Longer Drop Bar Bluto Hitches, Couplers & Balls 13 05-22-2008 11:42 AM
Hitch bar drop size for 3/4 ton trucks Silvertwinkie Hitches, Couplers & Balls 20 09-22-2004 01:37 PM
