Old 05-20-2008, 10:26 PM   #1
2010 27' FB Classic
N/A , Texas
Need Longer Drop Bar
I have a Reese weight distributing hitch set up with sway bars. It worked fine with my old truck but I recently got a newer truck and it rides much higher. Know of any good sites to order a longer drop bar or shank to help the trailer sit level? I'm looking for good prices and fast delivery.
Bluto is offline   Reply With Quote
Old 05-21-2008, 02:59 AM   #2
elolson's Avatar
2000 34' Excella
Tucson , Arizona
Have you tried local? The internet is full of cheap stuff and probably better prices, but a good local supplier can offer sound advice and if it is not long enough, you can return it. This is not an expensive part, hard to imagine the savings being worth the hassle if you get the wrong part.
elolson is offline   Reply With Quote
Old 05-21-2008, 03:33 AM   #3
Check out your axles to see if they have added to the problem by lowering the trailer closer to the ground.
If the trailer has been parked for an extended period of time, then the axles could be bad.
The following article will teach you how to check them out in about 30 seconds.
Dura Torque Axle
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-21-2008, 06:51 AM   #4
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
I've got a new Reese extended shank I will sell you for $20 plus shipping. The vertical arm of the shank is 12" long with holes at 1" on center. The horizontal arm is normal length. If you are interested, I'll send pics.
To get it to you fast, I could send it via Greyhound to Ft. Worth and it would be there by this evening.
So Long!
Bob Thompson is offline   Reply With Quote
Old 05-21-2008, 07:22 AM   #5
Images: 67
12,000 pound rated with 1200 pound tongue weight. Here's a pic............
So Long!
Old 05-21-2008, 08:10 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Send a message via Skype™ to uwe
That is an excellent offer from you. I recently bought a similar drop shank for my 07 Suburban at Camping World for close to $ 90.00.
Uwe
www.area63productions.com
uwe is offline   Reply With Quote
Old 05-21-2008, 08:53 AM   #7
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
$20.00 is like getting it FREE
I recently paid $170.00 for a shank like that, plus the bolt kit required for the adjustable mount, in London, Ontario.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 05-21-2008, 09:32 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you don't buy it I hope he sends me a PM because Grayhound comes to Trenton NJ.
Act fast.
2004 Excursion 4x4
Old 05-22-2008, 06:52 AM   #9
2010 27' FB Classic
N/A , Texas
Bob, thanks for the offer. I'll let you know later today as I need to do some measuring.
Old 05-22-2008, 07:02 AM   #10
2010 27' FB Classic
N/A , Texas
Dura Torque Axle
Andy,
Thanks for the heads up about the axles. I was not aware of the problem or how to check them. I'll do it today when I take my other measurements.
Old 05-22-2008, 09:30 AM   #11
2010 27' FB Classic
N/A , Texas
Bob, I checked out my Reese drop and it is the same as the one in your photo. But I did notice I had room to lower it 1 more hole so I might be OK with what I have once I adjust the tilt angle of the head. Sounds like you might have some other takers on your offer. Thanks and good luck!
Old 05-22-2008, 09:45 AM   #12
ScottW's Avatar
2007 30' Classic
Hernando , Mississippi
OK, I admit it...I'm not smarter than a fifth grader! I have seen ads for various hitches and seen the ball tilted at various angles. I simply do not understand why you would want to do that. In my little pea brain, that would, in effect, reduce the coupling area and reduce safety. What am I missing.
Be nice, I have already admitted being less than the sharpest tool in the shed.
Thanks in advance for the education.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 05-22-2008, 10:07 AM   #13
jimmickle's Avatar
2000 31' Land Yacht
You tilt the ball mount to position the weight distributing bars properly. If you have a Reese hitch, go to reeseprod.com for instructions on how to set the head.
jimmickle is offline   Reply With Quote
Old 05-22-2008, 11:42 AM   #14
1976 Argosy 24
Adjustable Hitch 101
Scott:
I was in the same spot as you, regarding lack of knowledge, when I started this recent thread:
http://www.airforums.com/forums/f464...tch-41946.html
Many replies and photos there that will help you understand, as it did me.
Sergei
TowVehicle - the Longer... the better?? byamcaravanner Tow Vehicles 14 05-07-2008 12:32 PM
No longer lurking SoftLanding Member Introductions 4 10-31-2006 01:09 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Hitch bar drop size for 3/4 ton trucks Silvertwinkie Hitches, Couplers & Balls 20 09-22-2004 01:37 PM
parts no longer available! jking Exterior Restoration Forum 2 05-11-2004 06:10 PM
