Old 06-14-2009, 04:12 PM   #1
slk
Elk River , Minnesota
Need help with new trailer set-up
I just bought a 25' Excella. It did not come with any stabilizer bars or weight distributing devices. The previous owner said he never used any during the 7 years he had this trailer. I want to play it safe and get what I need to make my trailering experiances a pleasure. So my question is what do I need for this trailer to make towing safe for me and my family??
Steve
slk is offline   Reply With Quote
Old 06-14-2009, 04:23 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
What tow vehicle are you using? Dave
easyride is offline   Reply With Quote
Old 06-14-2009, 05:31 PM   #3
slk
1999 1/2 ton suburban 4X4
Old 06-14-2009, 06:33 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
There are several popular hitch systems available: Equal-i-zer and Reese are the ones most use with a combination such as yours. Reese makes one that looks a lot like the Equalizer (I can only type those dashes once in a while) and one with chains. I have the Equalizer. The Hensley and ProPride and two other brands. The ProPride costs less than the Hensley and appears to be an improvement on it. Contact Sean Woodruff, a Forum member, for more info on the ProPride. Both of those cost a lot more than the Equalizer and Reese and may not be necessary for a 25' Excella.
Understanding the dynamics of these systems can be a challenge and there are threads about how to adjust them. People get very emotional about their hitches too.
But it's important to understand how it works and how to adjust it for proper weight distribution, sway control and getting the trailer level. The instructions for the Equalizer do not tell you enough and if you get that brand, check out this thread, especially posts 13 and 14, for more information how it works:
http://www.airforums.com/forums/f464...ort-34484.html
You can also call the company and talk with them in depth to make sure you're doing it right.
Many dealers either do not how to install what they sell or don't take the time to do it right, so doing it yourself is a good idea. Until you figure it out, you won't know if it's done right, and until you do the whole thing yourself, you won't understand how it works. Setting it up takes a long time and much experimentation. It's tedious and daunting, but necessary. Good luck.
Gene
Old 06-14-2009, 06:52 PM   #5
I would suggest a Reese 600 straight line, which has the torsion sway control.
The 4 X 4 is the killer, because of it's stiff suspension.
If you had a standard 1/2 ton, then a Reese 750 or 800 pound straightline would work just fine.
Problem with trailer light wiring Purchase a set of Wireless Tow Lights Steveusmc Lights - Interior & Exterior 5 10-05-2009 12:47 PM
How to properly set a trailer for extended time chasrahm Jacks, Stabilizers, Lifting and Leveling 9 07-06-2009 09:57 AM
Getting set up BayouFishin Member Introductions 14 08-24-2008 06:25 AM
Help set me straight... JMGAZ 1965 - 1969 Overlander 13 07-08-2005 08:04 PM
hitch set-up? remark83 Hitches, Couplers & Balls 3 05-16-2003 06:24 PM
