Old 06-24-2012, 02:08 PM   #1
1977 Argosy 28
here to day gone to Maui , Florida
need help identifying the hitch accessories
First time poster of pics, fingers crossed.
Im totally new to towing an Argosy. The TV is a 96 F250 diesel. The trailer already has some hitch points. Unfortunately funds are low so I want to see if I can use these pics to show what is already on there and reuse it to save money. What kind of WD hitch goes with this stuff?
Thanks for any and all help
Patrick and Heather
ID:	161726   Click image for larger version
GoGoddess is offline   Reply With Quote
Old 06-24-2012, 02:50 PM   #2
Patrick and Heather
The "snap-up" brackets are Reese.
The small round ball is for a "friction type" sway control. BAD!!!
Many different friction sway controls are made.
Old 06-24-2012, 02:59 PM   #3
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
Looks like they might go with a Reese hitch. Draw-Tite Weight Distribution Hitch (600 lb) with Trunnion Bars 7901
saburkha is offline   Reply With Quote
Old 06-24-2012, 03:11 PM   #4
Road Ruler's Avatar
Images: 38
It looks a lot like ours.
Vintage Reese Dual Cam with 750 bars.
Old 06-24-2012, 03:16 PM   #5
1974 Argosy 20
Kooskia , Idaho
Those are Reese snap up brackets. The little ball mount is for a friction sway control.
You will need a hitch ball and spring bar mount, a 2 5/16 ball, Probably 750# capacity spring bars, and you may want a friction sway control.
The most valuable part of what you have are the snap up brackets. Effectively you need everything else. Check Craigs List, you may find a used hitch system at a decent savings, assuming you know what you are looking at.
Old 06-24-2012, 05:02 PM   #6
1977 Argosy 28
Im reading reading and watching videos right now. How do I figure out the tongue weight on a 77 28' Argosy?
Old 06-24-2012, 06:16 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings GoGoddess!
I agree that the "snap-up brackets" are most likely Reese. My suggestion would be to consider a 600 pound Reese Strait-Line hitch that includes Dual Cam Sway Control. My estimate is that your likely loaded hitch weight will be around 750 pounds, but with your heavy-duty tow vehicle the 600 pound weight distribution bars should perform wonderfully with a hitch weight up to about 800 pounds with a 3/4-ton diesel tow vehicle. I utilize 600 pound weight distribution bars with my Strait-Line hitch on my K2500 Suburban and slightly lighter bars would actually be a benefit on my combination, but 600 pound weight distribution bars are the lightest currently available for the Reese Dual Cam setup.
Good luck with your research and investigation!
Kevin
P.S.: The extra cost of the Strait-Line hitch with Dual Cam Sway Control will only be a few dollars higher than a standard weight distribution hitch with the troublesome friction sway control . . . the friction sway control must be adjusted any time that road conditions change including rain/snow (loosen adjustment) . . . wind (tighten adjustment) . . . wet oil/tar (loosen), etc. . . . and it can be necessary to remove the friction device for tight maneuvers as it can be bent if the angle between the tow vehicle and trailer is too great. Once the Dual Cam is properly adjusted, no further adjustment is necessary.
Kevin D. Allen
AIR #827
Old 06-24-2012, 08:28 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Another option is to buy an Anderson WD hitch might be a little cheaper then the rest of the parts you need for that hitch if you buy new parts. I have only heard good feedback from people who have used the Anderson WD hitch.
Old 06-25-2012, 09:01 AM   #9
Check with these guys.
Trailer Hitches - 5th Wheel Hitch - Gooseneck Hitch - Reese Hitch
john121 is offline   Reply With Quote
Old 06-25-2012, 02:15 PM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....
GG,
Here's a foto of the complete set-up. The friction sway bar is between the two long weight distribution bars.
This combo werked well for 18 Seasons towing our first AS.
Until I came here and found out it didn't.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-25-2012, 04:50 PM   #11
1974 Argosy 20
Kooskia , Idaho
Originally Posted by ROBERT CROSS View Post
GG,
Took me 33 years to find out that it didn't work, so gotcha beat. And I never bothered with the friction sway bar, although I have one. Trailers up to 25' anyway. Maybe 200,000 miles towing.
That said, my Andersen should be here today. I wanted to try something new as I get old.
Old 06-25-2012, 04:53 PM   #12
dznf0g's Avatar
Oswego , Illinois
I also used a friction control for 17 years and it worked! BUT, that was a 5500#(fully loaded), 22'er. I wouldn't want a friction control on the big dog I have now.
Actually, I used it on the pop-up before that, now that I think about it.
-Rich-
Old 06-25-2012, 06:05 PM   #13
Yep....small is much easier to control.
Wouldn't consider it for the Classic Beast.
PFC
"Tahawus"
RLC
John Prine
Old 06-25-2012, 06:10 PM   #14
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Go Goddess I have two spring bars...since Robert sold me his set up (the photo he showed) Are you interested?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
