Old 08-25-2012, 03:00 PM   #1
Old School Young Gun
ElCamino Man's Avatar
Olney , Illinois
Necessity of a WDH
Hey guys! I recently purchased a 31' Excella II. Its a good 7 hours from me and Im going to borrow a buddies weight distributing hitch to pick it up. My question is: how important is it to use a WDH? Are these trailers built good enough (as in "biased" correctly) to not need one on short trips or is it a good idea to use one everytime? Iv pulled a roll-back trailer with a race car on it 60 miles without a WDH and it did fine. I think my truck will "carry" it fine without sagging to the ground but Im more worried about sway than weight distribution...
And on a side note: what size ball do I need for my AS?
No Airstream Yet...
ElCamino Man is offline   Reply With Quote
Old 08-25-2012, 03:14 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
On a scale of 1 to 10 in importance weight dist. is 10. 2 5/16 ball size. Good luck and be safe. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-25-2012, 03:20 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I have a dodge 3/4 ton pick up. I brought my 31' trailer home from the dealer with just a ball hitch. However I live only 10 miles from the dealer. I personally would not tow it that way any further than that. I did that all at or less than 35 MPH. However I imagine my trailer is heavier than yours. I will let someone who knows more about that trailer tell you what size ball you need.
Ken
Old 08-25-2012, 03:29 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
With a 250 you will not need a WD hitch for that tow. I am not saying not to get one for future tows but the time it takes to correctly install a WD hitch is not something you are going to want to do on the road.
2004 Excursion 4x4
Old 08-25-2012, 04:05 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Check the weight rating of your receiver for tongue weight without WDH many factory hitches are only rated for 500lbs and an 81 31' Airstream probably is 600-800lbs empty.
Old 08-25-2012, 04:58 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the receiver hitch, the part bolted to the frame is a Class III hitch. You need WD. Also check the rating of the ball and the ball mount (stinger). The latter (both the ball and stinger) needs to be rated for the tongue weight.
Old 08-25-2012, 05:08 PM   #7
richinny's Avatar
2011 34' Classic
IMHO, 7 hours with a never-towed-by-you-before-trailer needs the WD.
a gust of wind or a blown tire sure can ruin a day.
Ricky
Old 08-25-2012, 05:25 PM   #8
Ag&Au's Avatar
Since you are fairly new to Airforums, I will to make another comment.
Just about anytime the subjects of hitching, weight distribution, and sway control are brought up, you end up with a wide range of opinions. They range from always err on the side of caution, (that's where you will find me), to I've seen it done and nothing bad happened and/or it seems like it ought to work and just about everywhere in between. You will have to decide where your comfort level is on the wide range of opinions. There will never be a finite answer given to these questions. So evaluate everything presented and decide what you feel comfortable with.
This statement was probably not necessary, but sometimes I like to read myself write.
Ken
Old 08-25-2012, 05:26 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If there is a Airstream that will sway it is a 31 footer. My 32 foot (probably the same length) gets a little shaky with the WD is not set up right. And the WD will probably be needed to meet the hitch weight limits. WD generally doubles the tongue wt and tow weight ratings for a hitch. If you run without WD speed is your enemy. 45 or 50 gets to be awful slow after a few hours. Take some wrenches to fit it and take time to adjust the WD. Probably ought to take a pigtail for a 7 pin connector and time to splice it in for the brakes and lights. And you need a good battery for the breakway brakes. My 1988 32' was a 9 pin from the factory. Get a wiring diagram ahead of time. A blowout at speed sometimes does a lot of damage to these trailers, so check the tires. I had to go 600 miles with mine and it had been sitting a long, long time. The original tires, 22 years old or so. I found a guy from a tire shop to come with his mobile truck and grease the bearings and install new tires on site for an attractive price.
Bill M. is online now   Reply With Quote
Old 08-25-2012, 05:28 PM   #10
JimGolden's Avatar
1977 31' Excella 500
I towed my 34' triple axle over 700 miles home on just the ball, and that was also across the Great Smokey Mountains on 40 going from Kingston to Statesville. It towed just fine.
An F250 is heavy enough that you really won't need much weight distribution. It's the antisway that's nice. Plus, you only have two axles which will pivot better....with a triple axle they have to "scrub" a little to turn, and so they naturally track straighter.
If you do tow it home on the ball, make sure you've got it loaded nose heavy. In other words, a trailer will be more naturally stable if it's front heavy. If you get one tail heavy, that's when you're really asking for a crash.
I now use a 14,000lb capacity Equal-I-Zer, and can say that it does tow more solidly with the weight distribution and antisway (some would say the Eq has NO antisway but I'd argue with them) than just on the ball. But mine actually towed pretty nicely just on the ball.
If you can get the WD setup on there, I'd do it. If not, put something heavy in the front of the trailer (not sure where the fresh water tank is on that model, but if it's in front of the axles, fill it to the gills and put your blacksmith tools on the front couch) and take it easy and you should be OK.
Be careful,
- Jim
JimGolden is offline   Reply With Quote
Old 08-25-2012, 06:09 PM   #11
Olney , Illinois
I usually am on the side of caution... but Iv done some pretty stupid stuff in my days lol. My biggest problem is now this: If I borrow my buddies WDH, then Ill have to adjust it, correct? I am unsure on how to do this although Im sure I could figure it out. As for fine tuning... The finest tuning Iv ever done was sighting in a .22 lol. I have zero experience with anything more than the ol Reese hitch. I tow a lotta trailers, but Iv never used a WDH. And once the WDH is set-up to where I need it, wont it throw everything off for my buddy? I can see him (or anyone) getting pretty irritated about that...
No Airstream Yet...
Old 08-25-2012, 06:42 PM   #12
Ag&Au's Avatar
I've got an idea. Talk your buddy into going with you.
Ken
Old 08-25-2012, 06:50 PM   #13
Olney , Illinois
Lol hes a genious when it comes to mechanical/electrical... anything! That might be an idea lol
No Airstream Yet...
Old 08-25-2012, 06:53 PM   #14
HowieE's Avatar
Images: 12
I believe you meant to say that the ball and stinger need to be rated in excess of the weight of the towed unit. Typical a 2 5/16 ball will be rate for 12,000 lbs and most stingers are rated at at least 10,000 lbs. A ball and stinger rated at tongue weight would last about 5 miles of slow traveling
2004 Excursion 4x4
