Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 02-27-2008, 10:10 AM
arm4
arm4's Avatar
Profile:  2008 25' Safari FB SE
cazenovia, New York
Auto leveling on tow vehicle...
I have a chevy avalanche...when I connect the hitch the auto leveling pump engages and levels out the truck. How does this effect the towability of the AS and TV and the weight distributing hitch. Any insight? Thanks, Randy
Get rid of these ads... register today, it's FREE
Old 02-27-2008, 10:26 AM
Goin camping
Profile:  2007 25' Safari FB SE
valencia, California
Interesting question.
I'm curious about that too.
Should not be too long before someone who knows answers.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Old 02-27-2008, 10:48 AM
SteveH
SteveH's Avatar
Profile:  1975 23' Safari
San Antonio, Texas
Don't know for sure, but it seems you could end up with too much weight on the rear axle, or too little on the front.
If it were mine, I would disable the auto level, adjust the hitch properly, and then turn the auto level back on, but those are just my thoughts.
What does the owner's manual say about the situation?
Old 02-27-2008, 10:53 AM
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown, Connecticut
When we went from our 2004 Tahoe to our 2006 we had to make adjustments for our Airstream setup. When we first hooked up with the new truck our tongue was up about 4" too high. We had to purchase a lower hitch and reset the WD. Now all is great!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
Old 02-27-2008, 11:00 AM
CanoeStream
CanoeStream's Avatar
St. Cloud, Minnesota
Randy, we have the same trailer. I still count myself as having at least 900# hitch weight with the front loading of installed WD (weight distribution) gear, propane in the tanks and light clothing/bedding at the front. It's more when I pull with the water tank full -- which I do fairly often when leaving home. Your Avalanche's axle restrictions (GAWR front & rear) are on the driver side door or frame. 900# hitch weight has to be shared with the front axle via WD gear. Just guessing -- but I'd say hitch up, engage the WD bars, then start 'er up and let the auto leveling do its job. I'll certainly bet that such a system would require strictly staying within the vehicle's GVWR. See this -- 'Cargo Weight' is the weight added to the tow vehicle by humans aboard, options, tongue weight, and ...uh ... cargo. I'd take that understanding back to the dealer, walk into the service department and double check this premise until you find somebody who understands what you're asking.
Birds sing. Aluminum warms!
Old 02-27-2008, 01:10 PM
AlbertF
Profile:  1975 27' Overlander
In the Kootenays, BC
I can't remember . . . does the auto-leveling work with the key off, or just when you turn the key on again?
If the latter is the case, you shouldn't notice the system working if the WDH is set right. You want the WDH leveling the truck, not the air shocks.
Old 02-27-2008, 01:18 PM
CanoeStream
Exactly!
Old 02-27-2008, 01:42 PM
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton, Missouri
Since the WD hitch is supposed to distribute the hitch weight between the tow vehicle and the trailer, my advice would be to disable the system (if you can) and allow the WD hitch to do its job properly.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
2008 Moraine View Rally
June 13-15, 2008
Make your reservations now!
Old 02-27-2008, 09:02 PM
safari 28
safari 28's Avatar
Profile:  2004 28' Safari
holland, Michigan
I do not think you can turn it off. If this is if the same as my last GM, you have a true air ride system. It has no coil or leaf springs and small air bags similar to a semi. The system has a compressor, leveling system and all automatic. If it is turned off, eventually the air bags will deflate and you are sitting rock bottom on the axle.
I would set the ball height as per specs, hook it up, let the system level, then if using a reese dual cam use 5 chain links. You will then release weight on the rear of the vehicle and it will compensate by releasing air pressure in the bags, this should allow weight transfer to the front of the vehicle. It is a sweet system and I miss it sometimes for the smooth ride it gives. How it will work towing heavy tongue weights and constantly trying to compensate I have no idea. I do know if the compressor run too long it will shut down due to thermal protection. In theory however it will protect your Airstream better than any truck I can think of.
Old 02-27-2008, 09:56 PM
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula, Montana
Is there any way to disable it? It WILL mess up the weight distribution of the WD hitch. I have manual air bags on my truck and they are fully deflated when towing.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 02-28-2008, 12:57 AM
Inland RV Center, In
Commercial Vendor
Profile:  Corona, California
Automatic leveling destroys the function of a load equalizing hitch.
The automatic leveling, "MUST" be disabled, and the pressure set to minimum, which is usually 20 psi.
That will allow the load equalizing hitch to function properly, "IF" it's the correct rating, properly installed, and, properly adjusted.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 02-28-2008, 10:55 AM
safari 28
safari 28's Avatar
holland, Michigan
Interesting Andy I have thought about this many times. ARM 4 do what inland says, and as I recall towing the boat the front end of the vehicle always felt light. This has to be a very common problem as the system is popular in the GM line up. I wonder how many rigs are going down the road thinking they are set properly and the WD has been eliminated? Still, when just driving it empty it was smooth as can be. Weight distribution is the key to a happy tow with an A/S so heads up to all.
Old 02-28-2008, 11:12 AM
TheLuvShack
Profile:
I have a 2004 Suburban 1500 w/autoride and pull a 1971 28' Avion w/Hensley Hitch. I have pulled for 2 years with this set-up and it works great for me. Here's how I set up. Load the TV with whatever you'll take on your trip. Start the engine and let autoride level the TV load. Shut off engine. Hookup TT and set up whatever WD you choose to use. Start engine and you may hear autoride engage for just a few seconds. Drive away and enjoy your trip.
Daryl
"If the women don’t find you handsome, they better find you handy.” Red Green.
Old 02-28-2008, 11:31 AM
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
You want to disable that system and set the truck and trailer up per the hitch instruction. If you set the rig up correctly there will be no need for the leveling system.
If you rely on the leveling system to level the rig you have no idea where you are carring the weight and as noted above may be puting weight on the wrong axles.
Just pull the fuse on that system while you are towing. If it is not clearly marked on the fuse panel any "Stealer" should be able to tell you which one it is.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
vB code is On
Pingbacks are On
tow vehicle howardP Tow Vehicles 14 12-11-2004 01:49 PM
New Tow Vehicle available... 85MH325 Tow Vehicles 17 09-19-2004 06:13 AM
where to look for tow vehicle remcolent Tow Vehicles 5 07-13-2004 10:39 PM
new tow vehicle whistler On The Road... 10 04-14-2004 07:07 PM
Tow Vehicle hrnicho Tow Vehicles 22 10-23-2002 12:20 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
