Old 09-02-2014, 08:53 PM   #1
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
My A-Frame/ Hensley project
Finally!! I can check this one off the list!! I know you all love pics, and after all this work I'm wanting to "brag" a bit!
My project started as a refurb project for the Hensley. It's an older model S/N 4662, and I'm the 3rd owner. It was really starting to show it's age and I've been reading the horror stories in the Forums about failures, so I decided it was time. In hindsight, I'm really glad I decided to do this. What I found upon the disassembly of the hitch was terrible corrosion of the bottom bearings, likely due to failed seals. Also, the weight bar bushing was worn quite badly and a previous owner had modified the workings of the way the bars inserted into the hitch head. (there were some round spacers installed inside the holes the bars went into. Basically, it kept the bars from inserting all the way. Then they drilled new holes for the zerks. )
The reasoning behind what they had done was beyond me, but I was replacing ALL wearing parts and starting over. All new bearings, races, seals, bar bushings, pins, clips, etc.... The main parts (upper and lower body, weight bars, struts, frame mounts etc..) all went off to the sand blaster then got new powder coating and decals.
When I was done with all this I could'nt put this beauty on the ugly old A-frame!! I blasted the frame back to raw metal and applied etching primer and a new coat of paint. Replaced the emergency brake module and relocated the gas regulator to a spot under the bottles where it wont interfere with the bottle cover and replaced the gas supply lines with some fresh and flexible lines.
So.... bring on the before & after pics!!
A LOT of Pieces in this thing!
Now for the good stuff!
All in all, it was a worthwhile project. The front of the Airstream and the Hensley got some well deserved attention. I got the peace of mind I needed so that I can now roll down the road in my home without worrying about something drastic happening.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 09-02-2014, 09:49 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Wow! What are you doing next Tuesday?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 09-02-2014, 09:54 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Did you replace the overcenter latches?
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-02-2014, 10:03 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Nice work!!
Old 09-03-2014, 05:58 AM   #5
Kevin245's Avatar
Wow! Very nice work. This doesn't even look like the same unit. Very nice work indeed.
Eleanor Roosevelt
Old 09-03-2014, 06:01 AM   #6
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Is that the little swinging piece that protrudes down into the stinger area?
I'm not familiar with the technical names of this thing. If it is, the latch itself was in good order, but the pin holding it in place was replaced as it was corroded pretty bad.
Hensley Arrow
Old 09-03-2014, 07:26 AM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Very nice job on the hitch and tongue!
After I redid my hitch I now cover it up in the summer and remove it during the winter.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-03-2014, 09:08 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The over-center latches are the round parts you use the wrench to "tighten" / secure the hitch to the stinger. You can screw them in or out to adjust the snugness of the stinger.
Channing
WBCCI# 30676
Old 09-04-2014, 06:16 AM   #9
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Those, I did not. They appeared to have very little visual wear. But I think I'll add them to my list if spare parts, along with one of Hensley's fancy covers!
Hensley Arrow
Old 09-04-2014, 06:54 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The only concern would be wear on the screw threads. Replacing the two parts would "resolve" any wear...
Channing
WBCCI# 30676
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Hensley - Bent shaft on frame brackets? timmaah Hitches, Couplers & Balls 12 04-18-2012 08:28 PM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 08:10 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
