Old 06-21-2010, 04:30 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Multiple Airstreams? What do you do for hitching?
I own two Airstreams, one a 1972 the other a 1958 (which I just bought). The '72 uses a 2 5/16" hitch ball while the '58 uses a 2" ball. What do you do for hitching up your Airstreams? Do you have separate hitches for each one? Or just use a 2" ball on one hitch to use for both? Just curious.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-21-2010, 04:33 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I switched the Liner, formerly a 2" ball, to a 2 5/16" ball. One hitch for both.
Bill
Just my personal opinion
Old 06-21-2010, 04:35 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I use a different head for each size. You DO NOT want to use a 2 inch ball on the one that requires 2- 5/16. The other option is to have a 2- 5/16 coupler welded on the older trailer in place of the 2 inch
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-21-2010, 04:36 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I have a seperate setup for each trailer. They seem to like their own hitch better.
Don't use a 2" ball for a 2 5/16" trailer, it can come apart!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 06-21-2010, 04:39 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Right, but I was thinking about buying a 2" ball rated for 8,000lbs for my Equal-i-zer and modifying the coupler lock on the '72 to close tighter? Is it possible to make this modification?
1958 Overlander
4CU 1st VP
Old 06-21-2010, 05:02 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Not a chance I would want to take. A 2-5/16 coupler is not all that expensive. Not sure what a welding shop would charge to install since I do that sort of stuff myself.
a normal 2 inch coupler can not be counted on to stay on a 1-78 ball as a friend of mine can testify when they had a breakdown and the wrecker co. hooked it to a 1-7/8 ball. I guess their insurance covered it, but they lost a really nice vintage trailer, and that was only 1/8 difference.
You might be a able to pick up another suitable hitch head at a flea market also.
Not enough money involved here to take a chance on losing a trailer or causing some one else to be hurt
13 Ram 2500 TD
Old 06-21-2010, 08:20 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I have three tow vehicles and two trailers and each requires a slightly different drawbar setup. I keep separate hitch heads for each coach/tow vehicle combination in my garage - - simplifies last minute changes in plans since each coach has a different hitch height and angle as well as ball size - - and each vehicle need a differnt drop or rise in the drawbar. It wasn't as expensive to accomplish as one might think as I purchased the hitch heads at WBCCI International Rally Flea Markets over the years. The biggest problem has been matching up weight distribution bars that don't require resetting the Dual Cam Sway Control hardware on the trailer'r A-Frame. . . .
Kevn
Kevin D. Allen
AIR #827
Old 06-21-2010, 09:59 PM   #8
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
It's easy for us, the Argosy is a 2 5/16 ball and needs a WD hitch. The Base Camp is a 2" ball and no WD necessary, so I just have a bar set up with a ball for that one.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-22-2010, 05:48 AM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Rick. Just wanted to see if doing this was feasible and safe. I'll just buy another hitch for my '58.
1958 Overlander
4CU 1st VP
Old 06-22-2010, 06:15 AM   #10
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
One more thought I had overlooked. There are changeable balls available. Basically a vertical pin and 3 different size balls that can be dropped onto the pin. The one I have says it is rated for 10,000 lbs. I keep mine on a regular hitch insert for dealing with utility trailers, boats etc.
I found it at a farm supply store. Changing the ball is just a matter of pushing a pin and dropping another one on. Might check Tractor supply or a local co-op to see if it might work for you
13 Ram 2500 TD
over hitching and alignment issues Roadtoaster Hitches, Couplers & Balls 20 08-10-2010 08:42 PM
Are you a Multiple? InsideOut Community Polls 37 03-06-2008 07:57 PM
hitching up on slope wasafari Hitches, Couplers & Balls 4 06-11-2007 09:10 AM
W/D hitch: un-hitching and hitching TennisMan Hitches, Couplers & Balls 6 05-11-2007 07:49 PM
Hitching up with a Hensley GreggH Hitches, Couplers & Balls 7 02-04-2006 07:17 PM
